Dear Code_Saturne team!
I'm new on this forum and I have never had the experience of installation of CS before, so my questions are may seem obvious to you.
I have "successfully" installed version 4.0.2 on our lab system with all necessary libraries:
For your information :
CAELinux2013
Code_Saturne version : 4.0.2
hdf5 yes
cgns yes
med yes
scotch no
libxml2 yes
The problem occurs once I try to add .MED file into GUI. It seems like the med library is not installed correctly. However, I have tried installation within the "standard" installation process as well as downloading and installing libraries separately. Same error (screenshot attached) appears every time.
Could you suggest what can be the problem?
Thank's a lot for your help
Best Regards,
Valeria Marinova
CS 4.0.2 on LinuxCAE installation problem
Valeria Ver
Re: CS 4.0.2 on LinuxCAE installation problem
Could you post the installation log files as recommended in the forum guidelines ? It will help understanding why MED support was not enabled correctly.
Valeria Ver
Dear Mr. Fournier,
Thank you very much for your support! However, we have installed last Ubuntu version on our machines and now Code Saturne 4.0.2 is installed successfully.
Thank you again and my apologies for the disturbance!
Best Regards,
Valeria Ver
Best Regards,
Valeria Ver
