Installation C_S v4.0
Re: Installation C_S v4.0
hi it's me again . I meant the winrar file intaller of C_D - 4.0.1?
clalgourdin
Thanks a lot for your help, Now I can open Code_Saturne,
I will work with Salome for the pre-processing, so I try to run the tutorial "Pipe",
I export from Salome the file : "pipe.med"
In code saturne, in the section "Calculation environment" I check the mesh but I have this error :
"Error while loading shared librairies : libple.so.O: cannot open shared object file : No such file or directory"
I have already seen this error in an other topic in this forum :
http://code-saturne.org/forum/viewtopic ... bple#p8808
So, I have made the command : sudo ldconfig (and restart my PC) without success.
Do you have any idea ? (for information I don't work with Syrthes)
Claude
For Sante,
I hope, Yvan can confirm my words, the setup file was created, when you run for the first time the file "code_saturne.py" in the directory separated of the source code.
Claude
For Sante,
- check mesh.pdf
- (27.88 KiB) Downloaded 895 times
What files are present in your:
/home/halton/Code_Saturne/4.0.0/code_saturne-4.0.0/arch/Linux_x86_64/lib
directory ? What is your "configure" command (at the top of your "confi.log file) ?
I have already encountered this issue, though it is not always reproducible.
Did you/could you try installing from a clean (empty) build directory ?
clalgourdin
In the directory : /home/halton/Code_Saturne/4.0.0/code_saturne-4.0.0/arch/Linux_x86_64/lib :
- 8 files :
- libple.la
- libple.so
- libple.so.1
- libple.so.1.0.0
- libsaturne.la
- libsaturne.so
- libsaturne.so.0
- libsaturne.so.0.0.0
- 2 directories :
- code_saturne (empty)
- python2.7
For the file config.log, I have 2 files in my build directory (I don't know if it's normal).
N°1 : /home/halton/Bureau/code_saturne/C_S_4.build/config.log
This is the configure in the "first" file config.log :
$ /home/halton/Bureau/code_saturne/C_S_4/configure --prefix=/home/halton/Code_Saturne/4.0.0/code_saturne-4.0.0/arch/Linux_x86_64 --with-cgns=/usr --without-metis --without-scotch PYTHON=/usr/bin/python --enable-french --disable-static CC=/usr/bin/mpicc FC=/usr/bin/f95
N°2 : /home/halton/Bureau/code_saturne/C_S_4.build/libple.log/config.log
This the configure in the "second" file config.log :
$ /home/halton/Bureau/code_saturne/C_S_4/libple/configure --disable-option-checking --prefix=/home/halton/Code_Saturne/4.0.0/code_saturne-4.0.0/arch/Linux_x86_64 --with-cgns=/usr --without-metis --without-scotch PYTHON=/usr/bin/python --enable-french --disable-static CC=/usr/bin/mpicc FC=/usr/bin/f95 --cache-file=/dev/null --srcdir=/home/halton/Bureau/code_saturne/C_S_4/libple
concerning your sentence :
"Did you/could you try installing from a clean (empty) build directory ?"
I think but I'm not totally sure !
In : /home/halton/Bureau/code_saturne/
I have the build directory (C_S_4.build) but also others directories ...
Claude
- 8 files :
- libple.la
- libple.so
- libple.so.1
- libple.so.1.0.0
- libsaturne.la
- libsaturne.so
- libsaturne.so.0
- 2 directories :
- python2.7
Claude
Things seem OK, but I would recommend starting from a clean build, meaning:
"running the configure script or automatic installer inside a previously empty directory"
(if you did many tests in the same directory, it is not empty, and might have conflicting traces of previous tests).
clalgourdin
Good job ! I have re-run the automatic installer in a clean directory and no error appear !
Thank you sincerely
Claude
Thank you sincerely
Claude
hello Clalgourdin ,
please you can give me the complete procedure to install C_S - 4.0.1 ? whether the attachment file
Thank you .
Thank you .
This forum is useful fo feeback and recommendations for specific cases, but for the whole procedure, I remind you we have an installation manual on this web site: http://code-saturne.org/cms/sites/defau ... ll-4.0.pdf. We may also improve this documentation based on your feedback and suggestions.
Hello
I Code_Saturne - 3.0.1 installed. I would like to install 4.0.2 - C_S automatically but I did not manage to execute install_saturne.py .
please help me
please help me
Could you provide more details, as described in the forum recommendations ?
