Coupled three meshes
stage75
Re: Coupled three meshes
Post by stage75 »
Thanks Yvan,
Yes I have the 2.0 version!!
I'll try to put names in the 'namsat = '
No, forget the names in 'namsat': there is no way in version 2.0 for an instance to define its own name, so it won't work. The comments in the reference usdcpl are false, but the examples are correct: use numsat, not namsat.
The example will be fixed in the next bug fix release, 2.0.7, but the number of arguments for defcpl will not change (even if namsat is not used), for compatibility with existing data setups.
stage75
Post by stage75 »
Thanks for your help !
