Coupled three meshes
stage75
Post by stage75 »
I get tocouple two areas of meshes using the USSATC like:
SRC.1 :
numsat = -1
namsat = ' '
iwarns = 1
nbcsat = 1
do ii = 1, nbcsat
  if (ii .eq. 1) then
    call defsat(numsat, namsat, 'all[]', ' ', ' ', 'coupled1', iwarns)
  endif
enddo
SRC.2:
numsat = -1
namsat = ' '
iwarns = 1
nbcsat = 1
do ii = 1, nbcsat
call defsat(numsat, namsat, 'all[]', ' ', ' ', 'coupled2', iwarns)
  endif
enddo
But I can't couple three areas SRC.1, SRC.2 and SRC.3, I modefied USSATC like this but its not work :
SRC.1
numsat = -1
iwarns = 1
nbcsat = 3
do ii = 1, nbcsat
 numsat = 1
  endif
enddo
SRC.2
numsat = -1
iwarns = 1
nbcsat = 3
do ii = 1, nbcsat
 numsat = 1
    call defsat(numsat, namsat, 'all[]', ' ', ' ', 'couple0', iwarns)
else if (ii .eq. 2) then
numsat = 3
call defsat(numsat, namsat, 'all[]', ' ', ' ', 'couple1', iwarns)
  endif
enddo
and SRC.3
numsat = -1
iwarns = 1
nbcsat = 3
do ii = 1, nbcsat
 if (ii .eq. 2) then
    numsat = 3
    call defsat(numsat, namsat, 'all[]', ' ', ' ', 'couple2', iwarns)
  endif
enddo
Thanks for help
stage75
Re: Coupled three meshes
Post by stage75 »
...please there is someone who can correct me the ; numsat, namsat, iwarns and nbcsat For this coupling three meshes operates correctly
Do you get interlock or a crash ? If you get a crash, you should know what to post by now...
If you get an interlock (i.e. code does not crash but hangs), you may at least get tracebacks when killing the job (using CTRL-C or kill -15, not kill -9), which could help.
stage75
Post by stage75 »
I get this message :
/home/itouche/Téléchargements/tmp/installer/ncs-2.0.4/src/base/cs_sat_coupling.c:2076: Erreur fatale.
Au moins 1 couplage Code_Saturne a été défini pour lequel
aucune communication avec une instance de Code_Saturne n'est possible.
I think I can not couple correctly three meshes!
If you have read http://code-saturne.org/forum/viewtopic.php?f=2&t=7, you should have provided your "listing" file. Otherwise, please read it.
In your sources, I believe I have found a typo, but the "coupling" part of the "listing" would confirm this, so I'll leave the rest of the exercise to you.
stage75
Post by stage75 »
Thank's Yvan ,
I'll check when the mistake in the coupling and I come back here :) :)
stage75
Post by stage75 »
...Frankly I tried the coupling between the three areas but don't work!
coupled1: the common surface between area 1 and area 2
couple0 : the common surface between area 2 and area 1
couple1: is the common surface between area 2 and area 3
couple2: is the common surface between area 3 and area 2
Do you have an idea please ! :roll:
You still did not read my post or follow the Forum recommendations. If you do not provide enough debugging information, nobody can help you.
stage75
Post by stage75 »
Yes Yvan I read your post and the link . Despite the link I have trouble achieving this coupling of three areas!
attached the listing files
listing.3.txt
(23.17 KiB) Downloaded 219 times
listing.2.txt
(22.7 KiB) Downloaded 234 times
listing.1.txt
(23.49 KiB) Downloaded 227 times
When you get things like this (from second listing, but others are similar) :
Applications accessibles grâce à MPI :
0; type : "Code_Saturne 2.0.4"
nom de cas : ""
rang racine : 0 ; nb_rangs : 1
1; type : "Code_Saturne 2.0.4" (this instance)
nom de cas : ""
rang racine : 1 ; nb_rangs : 1
2; type : "Code_Saturne 2.0.4"
nom de cas : ""
rang racine : 2 ; nb_rangs : 1
Couplage Code_Saturne :
id de couplage : 0
nom local : "�.���"
nom d'application distante : ""
numéro local : 1
numéro d'application MPI : 1
rang racine MPI : 1
nombre de rangs MPI : 1
Couplage Code_Saturne 0 : initialisation de la communication MPI ...
You can see that the problem is related to coupling names not being defined (with 2 couplings only, the names are not used, as there can be only one match, so this explains why things worked with 2 couplings).
Now things are easy: for each coupling, you need to define numsat, to be consistent with the name of the case (set namsat = " "), as I am not sure assigning a name is possible with version 2.0 (it is used in 2.x, x >0, and 3.0).
Also,
