Hello every body,
I work to measure Y+ on all cells of a profile, like a cylinder, in Code Saturne 1.3.3.
I have wrote the subroutine usproj which I join but i have the error message :
usproj.F gfortran -D_CS_HAVE_XML -D_CS_LANG_FR -I. -O1 -c usproj.F
In file usproj.F:558
YPLUS(IEL) = RA(IYPPAR+IEL-1) 1
Error: Unexpected STATEMENT FUNCTION statement at (1)
In file usproj.F:586
& CDGFBO(3, IFAC), YPLUS(IEL)
1
Error: Function 'yplus' at (1) has no IMPLICIT type
Can you help me please? In fact, I have different tests with Code Saturne and verify the function with the users' guide but I have'nt the solution.
Thanks you everybody
Sebastien
Y+ problem in Code Saturne 1.3.3
Sébastien Thomas
- usproj_CP_CF_Y.F
- (31.5 KiB) Downloaded 301 times
James McNaughton
Re: Y+ problem in Code Saturne 1.3.3
You can have a maximum of 72 characters per line in FORTRAN77 so the YPLUS(NFABOR) variable is not recognised. Put it on a new line such as:
If you use something like vi to view the file it will highlight when you go over the max number of characters on a line.
Also you define YPLUS to be the size of NFABOR (number boundary faces) but later refer to it with IEL (cell-id), it's quite probable this will lead to errors. I think you should refer to it as YPLUS(IFAC).
Hope that helps,
James
DOUBLE PRECISION YPLUS(NFABOR)Also you define YPLUS to be the size of NFABOR (number boundary faces) but later refer to it with IEL (cell-id), it's quite probable this will lead to errors. I think you should refer to it as YPLUS(IFAC).
Hope that helps,
James
Sébastien Thomas
Thank you for your answer.
I resolved the problem of implicit and function. But I have a new problem. When I exxecute my case on Code Saturne on 1 proc on my desktop computer, i have a message : ERREUR WHILE RUNNING THE KERNEL (SOLVER). I join my subroutine and the error file and the listing file.
Sebastien
Sebastien
- usproj.F
- (31.57 KiB) Downloaded 322 times
- listing-07270959.txt
- (28.01 KiB) Downloaded 357 times
- erreur-07270959.txt
- (474 Bytes) Downloaded 312 times
Mickael Hassanaly
Hello Sebastien,
FINDPT function isn't properly filled line 565 in your usproj.f90.
Mickaël Hassanaly
Mickaël Hassanaly
Sébastien Thomas
Thank you very much
Sebastien Thomas
Sebastien Thomas
Sébastien Thomas
ello every body,
I work to measure Y+ on all cells of a profile NACA and on a cylinder, in Code Saturne 1.3.3.
I wrote the subroutine USPROJ.F which is joined.
This subroutine run but, I have problem when I interpret my results because I notice the value zero for some points but in paraview they have not this value.
Can you help me please? I attach my subroutine usprof and an exemple of results file, Y+
- YPLUS.hst.dat
- (43.92 KiB) Downloaded 283 times
- usproj.F
- (25.34 KiB) Downloaded 325 times
Mickael Hassanaly
Do you run your case on multiple processors?
Mickaël
Mickaël
