Y+ problem in Code Saturne 1.3.3
Sébastien Thomas
Post by Sébastien Thomas »
Hello every body,
I work to measure Y+ on all cells of a profile, like a cylinder, in Code Saturne 1.3.3.
I have wrote the subroutine usproj which I join but i have the error message :
usproj.F gfortran  -D_CS_HAVE_XML  -D_CS_LANG_FR                   -I. -O1 -c usproj.F
In file usproj.F:558
        YPLUS(IEL) = RA(IYPPAR+IEL-1)        1
Error: Unexpected STATEMENT FUNCTION statement at (1)
 In file usproj.F:586
     &              CDGFBO(3, IFAC), YPLUS(IEL)
                                                            1
Error: Function 'yplus' at (1) has no IMPLICIT type
Can you help me please? In fact, I have different tests with Code Saturne and verify the function with the users' guide but I have'nt the solution.
Thanks you everybody
Sebastien
usproj_CP_CF_Y.F
(31.5 KiB) Downloaded 291 times
James McNaughton
Re: Y+ problem in Code Saturne 1.3.3
Post by James McNaughton »
You can have a maximum of 72 characters per line in FORTRAN77 so the YPLUS(NFABOR) variable is not recognised. Put it on a new line such as:
DOUBLE PRECISION YPLUS(NFABOR)
If you use something like vi to view the file it will highlight when you go over the max number of characters on a line.
Also you define YPLUS to be the size of NFABOR (number boundary faces) but later refer to it with IEL (cell-id), it's quite probable this will lead to errors. I think you should refer to it as YPLUS(IFAC).
Hope that helps,
James
Sébastien Thomas
Thank you for your answer.
I resolved the problem of implicit and function. But I have a new problem. When I exxecute my case on Code Saturne on 1 proc on my desktop computer, i have a message : ERREUR WHILE RUNNING THE KERNEL (SOLVER). I join my subroutine and the error file and the listing file.
Sebastien
usproj.F
(31.57 KiB) Downloaded 309 times
listing-07270959.txt
(28.01 KiB) Downloaded 340 times
erreur-07270959.txt
(474 Bytes) Downloaded 297 times
Mickael Hassanaly
Post by Mickael Hassanaly »
Hello Sebastien,
FINDPT function isn't properly filled line 565 in your usproj.f90.
Mickaël Hassanaly
Sébastien Thomas
Thank you very much
Sebastien Thomas
Sébastien Thomas
ello every body,
I work to measure Y+ on all cells of a profile NACA and on a cylinder, in Code Saturne 1.3.3.
I wrote the subroutine USPROJ.F which is joined.
This subroutine run but, I have problem when I interpret my results because I notice the value zero for some points but in paraview they have not this value.
Can you help me please? I attach my subroutine usprof and an exemple of results file, Y+
YPLUS.hst.dat
(43.92 KiB) Downloaded 275 times
usproj.F
(25.34 KiB) Downloaded 312 times
Mickael Hassanaly
Do you run your case on multiple processors?
Mickaël
