i,
I have two questions.
Ending the calculation
I would like to properly stop a calculation that is currently running. I tried putting a "ficstp" file in the /tmp/.. directory containing:
"blank line"
NTMABS=1200
but it does not work, the calculation keeps running. Any suggestion?
Mass flow direction
My studied domain consists in a parallelepiped, with two inlets (INLET and INFILTRATION) on two opposites faces and one free outlet (on the same face as INLET).
INLET: V=2.77m/s ; Mass flow: A = 4.897E-3
kg/s
INFILTRATION: V=0.446m/s ; Mass flow: B = 3.679E-4 kg/s
Hence, I should get a total incoming mass flow of A + B, and an outgoing mass flow of -(A+B).
Instead, I get (A-B) for incoming mass flow and -(A-B) for outgoing mass flow:
Boundary type Code Nb faces Mass flow
Entree 2 2064 0.452920094E-02
Paroi lisse 5 54798 0.173905083E-20
Paroi rugueuse 6 0 0.000000000E+00
Symetrie 4 0 0.000000000E+00
Sortie libre 3 44 -0.452920104E-02
Indefini 1 0 0.000000000E+00
Should I change the velocity of INFILTRATION from 0.446 to -0.446 m/s?
Any other suggestion?
Axel Cablé
Ending the calculation / Mass flow direction
David Monfort
Re: Ending the calculation / Mass flow direction
Hi Axel,
Concerning your first question about a proper stop of the calculation (or an increase of the number of time-step), you are close to the solution! Here is the right way to this:
<blank line>
1200
As for your second question, could you post either your XML file or your usclim.f90 file so that I can have a look at it ? This is indeed a strange behavior...
David
<blank line>
1200
David
Axel Cablé
Hi David, thanks for your answer the calculation stops properly now.
As for the mass flow, here is the xml file of the case I currently study, where a negative speed is imposed. The characteristics of the geometry are:
INLET: S=0.0015m², U=-2.77 m/s, Flow= A = -0.486E-2 kg/s
INFILTRATION: S=0.0028m², U=0.446 m/s, Flow= B = 0.146E-2 kg/s
(see the attached schema)
I get:
Boundary type Code Nb faces Mass flow --------------------------------------------------------------- Entree 2 1554 -0.636902676E-02 Paroi lisse 5 49769 0.153126584E-21 Paroi rugueuse 6 0 0.000000000E+00 Symetrie 4 0 0.000000000E+00 Sortie libre 3 45 0.636918167E-02 Indefini 1 0 0.000000000E+00 ---------------------------------------------------------------
ie (A-B) for the total incoming mass flow, and (A+B) for the total outgoing mass flow, does it seem ok to you?
Also, I have set a free outlet condition for OUTLET. Hence I'm forced to impose either a zero flux or an imposed value for my scalar: temperature. However, I would like the fluid to "carry" the heat out of the room. Should I use a non standard boundary condition in usclim.F (flux condition)?
Thanks in advance for your answer,
Axel
I get:
Axel
- TESTBOX35.xml
- (7.56 KiB) Downloaded 370 times
- (5.25 KiB) Not downloaded yet
David Monfort
Hello Axel,
The results seem fine to me. Mass fluxes are always taken negative for inlets (u.n < 0 where n is the boundary face normal, always oriented towards the exterior) and positive for outlets (u.n > 0).
Concerning the oulet condition, I would advise you to first test with the standard condition: the velocity will indeed "carry" the heat out of the room except if you have backward flow (the behavior is then a bit more complex... see e.g. the comments at the beginning of the usclim.F subroutine.).
David
David
