2D turbulent channel flow: pb with TKE results
gina
Post by gina »
I simulate 2D turbulent channel flow with dimensions (x*y*z) = (100*1*1)m for the helf of my geometry (y is the height, and z is the third dimension). I take, ρ = 1 kg/m3, ν = 0.001695 kg/ms an u=18.4539 m/s to obtain Re_tau=590 and to compared my result to DNS data of Moser et al[1].
I use a periodic Bondary condition.
I can turn on my simulation with saturne and I have got a result BUT, the values of TKE is vey small (the order of 10 **- 2)compared to DNS and Fluent results!!!
I think that I have introduice correctly my data !
I do not know where is the problem ?
Could somebody please have a look at the xml file and let me know where I am making mistake. I just want to plot the turbulent knimatic profil
Thanks and Best Regards,
[1]Moser R.D., Kim J., Mansour N.N.
(1999) “Direct numerical simulation of turbulent channel flow up to Reτ = 590”, Phys. Fluids, Vol. 11, N° 4, 943-500.
saturne_result-tar.gz
(1020.33 KiB) Downloaded 729 times
Mickael Hassanaly
Re: 2D turbulent channel flow: pb with TKE results
Post by Mickael Hassanaly »
Dear Gina,
could you send me the paper you are referencing to?
Mickaël
gina
Post by gina »
thank you Mickaël for your answer.
I review my results .. finally in saturn GUI profile , I made a small mistake , I took turbulent viscosity instead of turbulent energy ... but despite that , the value of TKE wich I get is small compared to the DNS ! Can you please check it I thank you very much
MKM99.pdf
(99.59 KiB) Downloaded 703 times
Debashis Basu
Post by Debashis Basu »
Could you please tell me how you are calculating the TKE ? Is it based on the fluctuating u', v' and w' ?
I can then try to answer your question.
Debashis
Debashis Basu
Are you using Saturne version 2 or Saturne version 1.3.3
Debashis
gina
Post by gina »
thanks,
I use saturne version 2.0.0-rc2
i compared to k+=f(y+)
i calculate k+ for dns like this: k+=1/2*(u'*u'+v'*v'+w'*w')
and from saturne i have the data of k =f(y), then i convert my k to k+ (k+=k/friction velocity**2) and my y to y+ (y+=y*friction velocity/viscosity)
gina
Post by gina »
Dear all,
Could somebody orient me! Perhaps I do a mistake that I cant see well...
you can found as attached my saturn result compared with DNS
Please i need your help
(6.38 KiB) Not downloaded yet
Mickael Hassanaly
Gina,
I'm taking a look to your case. Don't worry ;-)
Mickaël
gina
Post by gina »
thank you dear Mickaël,
Mickael Hassanaly
Gina,
i think you attempt to reach a turbulent Reynolds of 590, is that correct? With you set up , this is not the case. More over you don't use the correct values for fluid properties (specially viscosity). I follow the papers you send me and i have same order of value on the turbulent energy (i didn't change the viscosity here). I send you my xml file in attachment.
Mickaël
helf_channel.xml
(7.15 KiB) Downloaded 753 times
