The test case is attached.
Kanssoune
Coupling Code_Saturne/Syrthes: SIGTERM signal (termination) received
Re: Coupling Code_Saturne/Syrthes: SIGTERM signal (termination) received
- Cas_test.7z
- (1.06 MiB) Downloaded 7380 times
Running under a debugger, I see that the crash is in Syrthes, with the following backtrace (using the version of Syrthes 4 provided on the code-saturne.org website) :
(gdb) bt
#0 0x00007ffff7d502f0 in PMPI_Abort () from /lib/x86_64-linux-gnu/libmpi.so.40
#1 0x0000555555563d52 in syrthes_exit (status=1) at syrthes.c:1243
#2 0x00005555555a27f3 in decode_prophy ()
#3 0x000055555559d46c in lire_donnees ()
#4 0x000055555555e490 in syrthes (rang_deb=0, nbproc_ray=-1) at syrthes.c:284
#5 0x000055555555dcc5 in main (argc=9, argv=0x7fffffffc3c8) at mainsyrthes.c:247
I do not have the debug info because the Syrthes makefiles would need additional patching to pass the required parameters it seems. So I do not know if this is a Syrthes 4/5 incompatibility (I did not check with Syrthes 5, as its installation procedure is a pain), a bug in Syrthes, or an error in your data.
I will help users with the code_saturne internal coupling, but I'll let debugging issues with Syrthes to the Syrthes team or to other volunteers...
(gdb) bt
Thank you for your time and the testing.
I'm out of ideas and I need everyone's goodwill to be able to move forward.
Kanssoune
Kanssoune
Finaly it was an error in our data.
Thanks for your help.
Kanssoune
Kanssoune
