Coupling Code_Saturne/Syrthes: SIGTERM signal (termination) received
Hello
I am trying to do a coupling between code_sturne and syrthes. Burt when running, I have the following error message at the Starting calculation:
with errorcode 1.
[hotcell:124583] 1 more process has sent help message help-mpi-api.txt / mpi-abort
[hotcell:124583] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
Either code_saturne or SYRTHES may have failed.
Check code_saturne log (listing) and SYRTHES log (syrthes.log)
Post-calculation operations
Error in calculation stage.
In the fluid error file, I have this message:
1: 0x7f2fbe956027 <epoll_wait+0x57> (libc.so.6)
2: 0x7f2fa917ea29 <ucs_event_set_wait+0x99> (libucs.so.0)
3: 0x7f2fa95e23eb <uct_tcp_iface_progress+0x7b> (libuct.so.0)
4: 0x7f2fa983cada <ucp_worker_progress+0x2a> (libucp.so.0)
5: 0x7f2fbdb3bf94 <opal_progress+0x34> (libopen-pal.so.40)
6: 0x7f2fbdb429d5 <ompi_sync_wait_mt+0xb5> (libopen-pal.so.40)
7: 0x7f2fbf095659 <ompi_request_default_wait+0x1e9> (libmpi.so.40)
8: 0x7f2fbf0c6a58 <PMPI_Intercomm_create+0x3a8> (libmpi.so.40)
9: 0x7f2fc126cf0a <ple_coupling_mpi_intracomm_create+0xda> (libple.so.2)
10: 0x7f2fc16266b1 <cs_syr4_coupling_init_comm+0x141> (libsaturne-7.0.so)
11: 0x7f2fc1628d49 <cs_syr_coupling_all_init+0x739> (libsaturne-7.0.so)
12: 0x7f2fc25e853c <main+0x27c> (libcs_solver-7.0.so)
13: 0x7f2fbe860d85 <__libc_start_main+0xe5> (libc.so.6)
14: 0x40094e <_start+0x2e> (cs_solver)
Attached are the listing files (for fluid and solid).
Does anyone have an idea how to get through this? Any help would be greatly appreciated.
with errorcode 1.
- solid_listing.txt
- (3.11 KiB) Downloaded 6023 times
- fluid_listing.txt
- (10.23 KiB) Downloaded 6010 times
Re: Coupling Code_Saturne/Syrthes: SIGTERM signal (termination) received
I have seen a similar issue several time in the past, though I have not used Syrthes recently. If Syrthes fails, logs can be limited... Do you have any other error message in the log ? Could you run the "run_solver" script in /data/test_CS/RESU_COUPLING/20221103-1522 to see if you get another error log. In some cases, the syrthes data file can contain a hidden command that gets in the way (set by the Syrthes GUI when checking the mesh or something of the sort).
Also make sure you ask for multiple iterations on the Syrthes side.
Hello Yvan!
Thank you for your quick reply!
I have no other error messages in the logs.
Running "run_solver" script in /data/test_CS/RESU_COUPLING/20221103-1522, it look that "module" is not recognized:
./run_solver: ligne 8: module : commande introuvable
with errorcode 1.
[hotcell:135298] 1 more process has sent help message help-mpi-api.txt / mpi-abort
[hotcell:135298] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
A suggestion?
Thanks!
Kanssoune
with errorcode 1.
A suggestion?
Thanks!
Kanssoune
Can you post your "run_solver" script ?
Sorry, I was sick and today I read your message.
The script is attached.
Kanssoune
Kanssoune
- run_solver.txt
- (1001 Bytes) Downloaded 5806 times
Checking how the "run_solver" script is generated, and looking at your script, I do not believe the warning message "module not found" can be ignored.
So I still have the impression the solid domain is causing the issue. Could you post the solid setup, except for the large files (mesh, ...) ?
Thank for your reply.
Attached some files. If I need to post a specific file in addition, do not hesitate.
Kanssoune
Kanssoune
- mesh_solide.syr_desc.txt
- (77 Bytes) Downloaded 5807 times
- mesh_solide.syr.txt
- (3.1 MiB) Downloaded 6121 times
- solid.syd.txt
- (3.13 KiB) Downloaded 5813 times
Yould you also post your Syrthes installation setup file (setup.ini) and the syrthes.profile (in the "bin" directory of the Syrthes install), as well as the "config.log" file from the code_saturne installation ?
Seeing how early the issue happpens, I wonder if you do not have an MPI library mismatch, and those will help me check.
The requested files are attached.
Thanks for your help.
Kanssoune
Kanssoune
- syrthes.profile.txt
- (3.2 KiB) Downloaded 5883 times
- setup.ini
- (4.31 KiB) Downloaded 5929 times
- config.log
- (199.52 KiB) Downloaded 5924 times
The MPI version seems fine, so I do not see any version mismatch which could explain the issues here.
So back to the beginning....
If your test case is not too large, you can post it or send it to me so that I can see if I reproduce the issue.
