Syrthes CFD installation
Re: Syrthes CFD installation
According to the last log, there is an error building some Syrthes tools (which are independent of code_saturne), but there is not much detail.
This is surprising, as the firs function which fails (Syrthes/EnSight conversion) should have minimal external library dependencies. Do you have any additional error essages in the terminal from which you ran the Syrthes install ?
Vincent_DORE
Indeed, there are some errors (I logged terminal errors in the syrthes_install.log file).
Vincent
Vincent
- ERREUR.log
- (2.05 KiB) Downloaded 5382 times
- syrthes_install.log
- (84.16 KiB) Downloaded 5319 times
- setup.ini
- (4.42 KiB) Downloaded 5287 times
Vincent Doré
It seems mpicc is not found, so you may have a configuration error (in incorrect mpicc path in setup.ini), or are missing an MPI installation.
Vincent_DORE
Sorry Yvan, I made a change and forgot to redefine path to mpicc after.
Here is the error with the mpicc path filled.
Vincent
Vincent
- ERREUR.log
- (788 Bytes) Downloaded 5275 times
- (146.13 KiB) Downloaded 5266 times
- setup.ini
- (4.49 KiB) Downloaded 5269 times
Vincent Doré
Is the installation more complete now ?
Vincent_DORE
The installation is more complete.
Code Saturne works alone.
Syrthes works alone.
When my user tried to make a coupled simulation, the directory creation works, GUI interface also but we have an error when we launch runcase (see picture attached).
Vincent
Vincent
Vincent Doré
Was code_saturne and PLE installed with MPI support ? This is necessary for the Syrthes coupling.
Vincent_DORE
Indeed, there were a bad path in one of the config file.
Now the previous problem is solved.
Syrthes simulations work for mono or multi procs.
Saturne simulations work for mono or multi procs.
But coupled simulation doesn't work.
Any idea why we face this cs_syr_coupling.c:898: Erreur fatale ?
Vincent
Vincent
- run_solver.log
- (10.09 KiB) Downloaded 5336 times
- error.txt
- (584 Bytes) Downloaded 5230 times
- coupling_parameters.py
- (257 Bytes) Downloaded 5228 times
Vincent Doré
Could you post the top-level "run_solver" generated in RESU_COUPLING/run_id ?
Does the libsyrthes_cfd.a library exist in the Syrthes installation "lib" directory (next to libsyrthes_seq.a and libsyrthes_mpi.a) ?
Vincent_DORE
Here are info requested.
Thanks again.
Vincent
Thanks again.
Vincent
- syrthes-lib-dir-content.txt
- (336 Bytes) Downloaded 5264 times
- run_solver.txt
- (456 Bytes) Downloaded 5307 times
Vincent Doré
