Syrthes CFD installation
misomg
Post by misomg »
I tried to couple Code Satrune and Syrthes, turorial case 3disks2d. Each standalone calculation runs fine, but after coupling I get error:
Coupling execution between:
   o Code_Saturne [1 domain(s)];
   o SYRTHES      [1 domain(s)];
                      Code_Saturne
 Version:   6.0
 Path:      /home/misomg/Code_Saturne/6.0.2/code_saturne-6.0.2/arch/Linux_x86_64
 Result directory:
   /home/misomg/CFD/3disks2D/RESU_COUPLING/20200607-1340
  Preparing calculation data
 SYRTHES4 home directory: /home/misomg/syrthes4.3.5/arch/Linux_x86_64
 MPI home directory: /usr/bin
 Building the executable file syrthes..
ar: /home/misomg/syrthes4.3.5/arch/Linux_x86_64/lib/libsyrthes_cfd.a: No such file or directory
make: *** [Makefile:15: exe] Error 9
as I understand, I forget to install syrthescfd, but during installation I get error. I think PLE is installed correctly
in Code Saturne directory, so I cant find where problem is?
cfd_couplage.c:53:10: fatal error: ple_coupling.h: No such file or directory
make[1]: *** [Makefile:24: /home/misomg/syrthes4.3.5/build//cfd_couplage.o] Error 1
make: *** [Makefile:36: syrthescfd] Error 2
../syrthescfd.log:cfd_couplage.c:53:10: fatal error: ple_coupling.h: No such file or directory
../syrthescfd.log:make[1]: *** [Makefile:24: /home/misomg/syrthes4.3.5/build//cfd_couplage.o] Error 1
../syrthescfd.log:make: *** [Makefile:36: syrthescfd] Error 2
Attached are setup file and error log
Regards Michal
setup.ini
(4.15 KiB) Downloaded 6385 times
saturne-syrthes-coupling-error-.txt
(3.49 KiB) Downloaded 6395 times
ERREUR.log
(1.84 KiB) Downloaded 6241 times
Re: Syrthes CFD installation
In "setup.ini", for the PLE path, you simply need to remove the trailing "/lib".
misomg
Post by misomg »
thank you, that was a problem.
Michal
Vincent_DORE
Post by Vincent_DORE »
Hi all,
I try to couple Code Saturne 6.0.5 and Syrthes 4.3.5.
I succeeded to compile CS but I have an error when I try to compile Syrthes linked with CS.
I have ple error and I'm not able to obtain syrthescfd binary.
I join config and setup files.
Have you ever faced these errors ?
Thanks a lot for your help.
Vincent
setup.ini
(4.38 KiB) Downloaded 6211 times
ERREUR.log
(6.36 KiB) Downloaded 6139 times
config.log
(208.5 KiB) Downloaded 6396 times
Vincent Doré
You could obtain this sort of error if the PLE from code_saturne was built without MPI support, which does not seem to be the case since MPI was detected correctly by code_saturne.
What files are present you have in /opt/code_saturne-6.0.5/lib and /opt/code_saturne-6.0.5/include ?
Vincent_DORE
I do not have a lib directory or an include directory, but I have libple directory.
Here are attached ls command result files.
Hope this help.
Vincent
ls_code_saturne_root_directory.txt
(2.18 KiB) Downloaded 6273 times
ls_code_saturne_libple.txt
(1.71 KiB) Downloaded 6418 times
Vincent Doré
The code_saturne and libple directories you use should be the installation directory, not the source or build directory.
And it seems you have built code_saturne in the source directory, while using a separate directory is recommended (https://github.com/code-saturne/code_sa ... irectories).
Vincent_DORE
Hello and thanks for the github link.
I updated my installation and now I have separate directories but the problem continues.
Here are include and lib directories content.
Vincent
ls_code_saturne_include.txt
(395 Bytes) Downloaded 6196 times
ls_code_saturne_lib.txt
(879 Bytes) Downloaded 6233 times
Vincent Doré
OK, this stage seems OK (at least at first sight).
Is the problem on the Syrthes side still exactly the same ? Could you post the updated code_saturne config.log, syrthes.ini, and compilation error log in case there is a slight difference ?
Vincent_DORE
Hello Yvan, happy new year 2021 !
Sorry, due to COVID, it was difficult to have access to the server...
Here are files requested.
My user informed me that Code Saturne is Ok now.
But we still have problem with syrthes :
- convert2syrthes4 seems missing,
- libsyrthes_seq.a is missing
- syrthes-pp too
Any idea ?
Thanks a lot for your help !
Vincent
config.log
(196.37 KiB) Downloaded 6236 times
setup.ini
(4.42 KiB) Downloaded 6249 times
ERREUR.log
(2.05 KiB) Downloaded 6189 times
Vincent Doré
