Fail to compile the thermal source term subroutine
Jundi He
Post by Jundi He »
Hi Code Saturne develop team:
I am using a subroutine to impose the thermal source term for each cell in a channel flow. In the subroutine, I need to use the cell density and velocity (z direction component) to calculate the heat source term. When I try to compile the subroutine, there is an error comes from the cs_field API, the screen shot of the error is shown, and my heat source term subroutine is attached. Did anyone know what the problem is, thanks!
Regards!
Jundi
cs_heat_source_terms.f90
(3.38 KiB) Downloaded 269 times
Re: Fail to compile the thermal source term subroutine
Yes, cvar_vel is a 2-dimensional array (dim*cells), so you shoumd not declare it with the other scalar arrays on line 49, but as:
[double precision, dimension(:,:), pointer :: cvar_vel
on a nearby line (note the double instead of single colons).
Jundi He
Post by Jundi He »
Yvan:
OK, thanks! I have another question, if I need to access to the z direction velocity, should I use this:
call field_get_val_v(ivarfl(iw), cvar_vel)
zvelocity=cvar_vel(1,iel)
Regards!
Jundi
No, that is the x direction; for the z direction, use:
zvelocity=cvar_vel(3,iel)
Jundi He
Post by Jundi He »
OK, thanks a lot!
