hello,
Since I installed the new version of code_saturne(C_S-5.0). I can not verify my mesh in the GUI.
"Please i need help"
Sante Junior.
Problem of verifying the quality of the mesh in CS 5.0
Luciano Garelli
Re: Problem of verifying the quality of the mesh in CS 5.0
In CS 5 you have to switch to the "prepocessing mode" (in the fig that you post you are in the "calculation mode") and then select "mesh quality criteria" in the preprocessing type.
Hello Luciano;
Thank you for your reply. Now I face another problem; When I want to load the boundary conditions I am asked for the file "check_mesh.log" which is absent. I do not know how to solve this new problem. Especially that I want to run a tutorial on burning pulverized coal with a Lagrangian approach.
Please, I still need your help
Sante Junior.
Sante Junior.
Here is the mesh file of the tutriel in question.
Regards.
Sante Junior
Regards.
Sante Junior
- Tutorial3D.cgns.tar.gz
- (454.22 KiB) Downloaded 909 times
Luciano Garelli
The file that you have to read in order to load the BC's is the preprocessor.log as the pop-up notifications says.
Hello Luciano,
Thanks you!!!!
Best Grgards
Sante Junior
Thanks you!!!!
Best Grgards
Sante Junior
