Internal wall not detected in code saturne 4.2
sagarcfd
Post by sagarcfd »
I am trying to model internal wall as baffle using Code Saturne 4.2. During mesh creation I have created an internal face with name baffle. Also I have used subroutine cs_user_mesh.c as attached below. But baffle is not being detected in preprocessor listing so I am unable to provide wall boundary condition to baffle. Code saturne compiles user subroutine without error and run goes well but it do not take internal wall into account. Since flow is not affected by baffle streamlines are straight as shown below.
Instead I am expecting flow to go like shown in picture below after detecting baffle
User subroutine is as below:
 * Insert thin wall into a mesh.
cs_user_mesh_thinwall(cs_mesh_t  *mesh)
  /* Example: thin wall along a plane */
  if (true) {
    cs_lnum_t   n_selected_faces = 1;
    cs_lnum_t  *selected_faces = 1;
    cs_real_t  *i_face_cog = 1, *i_face_normal = 1;
    /* example of multi-line character string */
    const char criteria[] = "baffle";
    cs_mesh_init_group_classes(mesh);
    cs_mesh_quantities_i_faces(mesh, &i_face_cog, &i_face_normal);
    cs_glob_mesh->select_i_faces = fvm_selector_create(mesh->dim,
                                                       mesh->n_i_faces,
                                                       mesh->class_defs,
                                                       mesh->i_face_family,
                                                       1,
                                                       i_face_cog,
                                                       i_face_normal);
    BFT_MALLOC(selected_faces, mesh->n_i_faces, cs_lnum_t);
    cs_selector_get_i_face_list(criteria,
                                &n_selected_faces,
                                selected_faces);
    BFT_FREE(i_face_cog);
    BFT_FREE(i_face_normal);
    mesh->class_defs = fvm_group_class_set_destroy(mesh->class_defs);
    mesh->select_i_faces = fvm_selector_destroy(mesh->select_i_faces);
    cs_create_thinwall(mesh,
                       selected_faces,
                       n_selected_faces);
    BFT_FREE(selected_faces);
Please tell me what I am doing wrong.
Thanks and Regards,
Sagar
Thinh_wall2.xml
.xml file
(6.15 KiB) Downloaded 330 times
cs_user_mesh.c
cs_user_mesh.c
(23.5 KiB) Downloaded 357 times
Mesh-4_new.zip
Mesh file in .msh format
(361.49 KiB) Downloaded 388 times
sagarcfd
Re: Internal wall not detected in code saturne 4.2
Post by sagarcfd »
I am attaching images once again below. I am expecting flow to turn around baffle as shown in expected result.
Thanks and Regards,
Sagar
Expected result
Expected result
Actual Result
Actual Result
did you count the number of boundary faces (in the listing file) or visualize the mesh boundary (not volume) to make sure your faces were selected correctly ?
sagarcfd
Post by sagarcfd »
I have checked physical groups in gmesh and boundaries given in code saturne and they do match. I have attached snapshots for reference.
Thanks and Regards,
Sagar
Boundary condition in code saturne
Physical groups
Physical groups
Did you check the file I mentioned in my previous post ?
sagarcfd
Post by sagarcfd »
Yes I did checked. It shows as,
Groups:
"3"
cells: 20000
"5"
boundary faces: 8000
"6"
boundary faces: 100
"7"
boundary faces: 100
"8"
interior faces: 50
So it shows baffle as internal faces. Why it is so inspite of using subroutine and successfully compiling it?
Thanks and Regards,
Sagar
Your selection criteria in the user subroutine is wrong, as Code_Saturne does not currently handle GMSH physical group names, but simply numbers.
sagarcfd
Post by sagarcfd »
Thanks for reply. I will use group number "8" of baffle in user subroutine instead of group name baffle and let you know about result.
Sagar
sagarcfd
Post by sagarcfd »
Inspite of using group number "8" instead of its name result do not change. snapshot of straight streamlines is attached below.
Thanks and regards,
Sagar
Streamline
Streamline
Luciano Garelli
Post by Luciano Garelli »
Hello Sagar,
I uploaded an user function and a case file where your problem it is working (I attach a figure).
I used the default values in the user fuction like in the /REFERENCE/cs_user_mesh.c using as selection criteria "8" and the same selection criteria in the GUI to impose the wall BC.
Please, check if it is works for you.
Baffle.tar.gz
(7.15 KiB) Downloaded 419 times
