CS without graphic display
gbenefice
Post by gbenefice »
I would like to use CS without graphic display to perform a parametric optimization with windows 7 64bits.
I try with the windows command prompt:
“code_saturne.exe run –param text.xml”
But there is an execution error
Guillaume
(35.6 KiB) Not downloaded yet
Re: CS without graphic display
Do you start the execution from inside a case directory ?
The "code_saturne run" command assumes you are in a case directory (otherwise, you need to pass it the additional --case parameter).
gbenefice
Post by gbenefice »
Hello
Sorry my late answer ! I have worked on Ubuntu in recent months.
I launch the code_saturne command in the case directory (See as an attachement).
Guillaume
I would need to check the exact line matching the error message you have, but I won't be able to do it before next week.
Maybe someone else can look at this, or it will need to wait until next week.
Luciano Garelli
Post by Luciano Garelli »
Could you post the case and mesh files in order to check It?
