Data setting for the 1D-wall thermal module (cs_user_1d_wall_thermal.cpp)
The cs_user_1d_wall_thermal subroutine is used to set the 1D-wall thermal module parameters.
Local variables declaration
int izone = 0, ifbt1d = 0;
cs_lnum_t nlelt = 0;
cs_lnum_t *lstelt = nullptr;
Allocation
if (iappel > 0)
CS_MALLOC(lstelt, cs_glob_mesh->n_b_faces, cs_lnum_t);
Rereading of the restart file
wall_thermal->use_restart = cs_restart_present() ? true : false;
iappel = 1 or 2
if (iappel == 1 || iappel == 2) {
* Faces determining with the 1-D thermal module:
* nfpt1d : Total number of faces with the 1D thermal module
* ifpt1d[ii]: Number of the [ii]th face with the 1D thermal module
* Remarks:
* During the rereading of the restart file, nfpt1d and ifpt1d are
* compared with the other values from the restart file being the result of
* the start or restarting computation.
* A total similarity is required to continue with the previous computation.
* Regarding the test case on ifpt1d, it is necessary that the array be
* arranged in increasing order (ifpt1[jj] > ifpt1d[ii] if jj > ii).
* If it is impossible, contact the developer team to deactivate this test.
/* Get the list of boundary faces that will be coupled */
cs_selector_get_b_face_num_list("2 or 3 or 5 or 6 or 7 or 8 or 9 or 10",
&nlelt, lstelt);
izone++;
/* Fill the ifpt1d array, and compute nfpt1d */
for (cs_lnum_t ilelt = 0 ; ilelt < nlelt ; ilelt++) {
cs_lnum_t ifac = lstelt[ilelt];
wall_thermal->izft1d[ifac-1] = izone;
if (iappel == 2) wall_thermal->ifpt1d[ifbt1d] = ifac;
ifbt1d++;
if (iappel == 1) {
wall_thermal->nfpt1d = ifbt1d;
iappel = 2
* Parameters padding of the mesh and initialization:
* (Only one pass during the beginning of the computation)
* locals_models[ii].nppt1d: number of discretized points associated
* to the (ii)th face with the 1-D thermal module.
* locals_models[ii].eppt1d: wall thickness associated to the (ii)th face
* with the 1-D thermal module.
* locals_models[ii].rgpt1d: geometric progression ratio of the meshing refinement
* associated to the (ii)th face with the 1-D thermal module.
* (with : rgpt1d > 1 => small meshes on the fluid side)
* locals_models[ii].tppt1d: wall temperature initialization associated to the
* (ii)th face with the 1-D thermal module.
* Remarks:
* During the rereading of the restart file for the 1-D thermal module,
* the tppt1d variable is not used.
* The nfpt1d, eppt1d and rgpt1d variables are compared to the previous
* values being the result of the restart file.
* An exact similarity is necessary to continue with the previous computation.
if (iappel == 2) {
for (cs_lnum_t ii = 0 ; ii < wall_thermal->nfpt1d ; ii++) {
wall_thermal->local_models[ii].nppt1d = 8;
wall_thermal->local_models[ii].eppt1d = 0.01144;
wall_thermal->local_models[ii].rgpt1d = 1.;
wall_thermal->tppt1d[ii] = cs_glob_fluid_properties->t0;
iappel = 3
* Padding of the wall exterior boundary conditions:
* local_models[ii].iclt1d: boundary condition type
* local_models[ii].iclt1d = 1: dirichlet condition,
* with exchange coefficient
* local_models[ii].iclt1d = 3: flux condition
* local_models[ii].tept1d: exterior temperature
* local_models[ii].hept1d: exterior exchange coefficient
* local_models[ii].fept1d: flux applied to the exterior (flux<0 = coming flux)
* local_models[ii].xlmt1d: lambda wall conductivity coefficient (W/m/C)
* local_models[ii].rcpt1d: wall coefficient rho*Cp (J/m3/C)
* local_models[ii].dtpt1d: time step resolution of the thermal equation to the
* (ii)th boundary face with the 1-D thermal module (s)
if (iappel == 3) {
const cs_lnum_t *b_face_cells = cs_glob_mesh->b_face_cells;
= (const cs_real_3_t *)cs_glob_mesh_quantities->b_face_cog;
wall_thermal->local_models[ii].iclt1d = 1;
wall_thermal->local_models[ii].tept1d = cs_glob_fluid_properties->t0;
/* Physical parameters */
cs_lnum_t face_id = wall_thermal->ifpt1d[ii] - 1;
/* Floor: plate */
if (cdgfbo[face_id][2] <= 1.e-3) {
wall_thermal->local_models[ii].xlmbt1 = 0.16;
wall_thermal->local_models[ii].rcpt1d = 790.*900.;
/* Wall and ceiling: marinite */
else {
wall_thermal->local_models[ii].xlmbt1 = 0.11;
wall_thermal->local_models[ii].rcpt1d = 670.*778.;
cs_lnum_t c_id = b_face_cells[face_id];
wall_thermal->local_models[ii].dtpt1d = CS_F_(dt)->val[c_id];
Deallocation
CS_FREE(lstelt);
