#include "base/cs_defs.h"#include "base/cs_block_dist.h"#include "base/cs_part_to_block.h"#include "fvm/fvm_defs.h"#include "fvm/fvm_nodal.h"#include "fvm/fvm_writer.h"Go to the source code of this file.
| struct | fvm_writer_section_t |
| typedef struct _fvm_writer_field_helper_t | fvm_writer_field_helper_t |
| typedef void | fvm_writer_field_output_t(void *context, cs_datatype_t datatype, int dimension, int component_id, cs_gnum_t block_start, cs_gnum_t block_end, void *buffer) |
| fvm_writer_section_t * | fvm_writer_export_list (const fvm_nodal_t *mesh, int min_export_dim, int max_export_dim, int boundary_flag, bool group_by_type, bool group_all, bool discard_polygons, bool discard_polyhedra, bool divide_polygons, bool divide_polyhedra) |
| void | fvm_writer_count_extra_vertices (const fvm_nodal_t *mesh, bool divide_polyhedra, cs_gnum_t *n_extra_vertices_g, cs_lnum_t *n_extra_vertices) |
| cs_coord_t * | fvm_writer_extra_vertex_coords (const fvm_nodal_t *mesh, cs_lnum_t n_extra_vertices) |
| fvm_writer_field_helper_t * | fvm_writer_field_helper_create (const fvm_nodal_t *mesh, const fvm_writer_section_t *section_list, int field_dim, cs_interlace_t interlace, cs_datatype_t datatype, fvm_writer_var_loc_t location) |
| void | fvm_writer_field_helper_destroy (fvm_writer_field_helper_t **helper) |
| void | fvm_writer_field_helper_get_size (const fvm_writer_field_helper_t *helper, size_t *input_size, size_t *output_size, size_t *min_output_buffer_size) |
| int | fvm_writer_field_helper_field_dim (const fvm_writer_field_helper_t *helper) |
| cs_datatype_t | fvm_writer_field_helper_datatype (const fvm_writer_field_helper_t *helper) |
| int | fvm_writer_field_helper_step_el (fvm_writer_field_helper_t *helper, const fvm_writer_section_t *export_section, int src_dim, int src_dim_shift, cs_interlace_t src_interlace, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, const void *const field_values[], void *output_buffer, size_t output_buffer_size, size_t *output_size) |
| int | fvm_writer_field_helper_step_nl (fvm_writer_field_helper_t *helper, const fvm_nodal_t *mesh, int src_dim, int src_dim_shift, cs_interlace_t src_interlace, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, const void *const field_values[], void *output_buffer, size_t output_buffer_size, size_t *output_size) |
| const fvm_writer_section_t * | fvm_writer_field_helper_output_e (fvm_writer_field_helper_t *helper, void *context, const fvm_writer_section_t *export_section, int src_dim, cs_interlace_t src_interlace, const int *comp_order, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, const void *const field_values[], fvm_writer_field_output_t *output_func) |
| void | fvm_writer_field_helper_output_n (fvm_writer_field_helper_t *helper, void *context, const fvm_nodal_t *mesh, int src_dim, cs_interlace_t src_interlace, const int *comp_order, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, const void *const field_values[], fvm_writer_field_output_t *output_func) |
| void | fvm_writer_field_component_name (char *s, size_t s_size, bool lowercase, int dimension, int component_id) |
| typedef struct _fvm_writer_field_helper_t fvm_writer_field_helper_t |
| typedef void fvm_writer_field_output_t(void *context, cs_datatype_t datatype, int dimension, int component_id, cs_gnum_t block_start, cs_gnum_t block_end, void *buffer) |
| void fvm_writer_count_extra_vertices | ( | const fvm_nodal_t * | mesh, |
| bool | divide_polyhedra, | ||
| cs_gnum_t * | n_extra_vertices_g, | ||
| cs_lnum_t * | n_extra_vertices ) |
| fvm_writer_section_t * fvm_writer_export_list | ( | const fvm_nodal_t * | mesh, |
| int | min_export_dim, | ||
| int | max_export_dim, | ||
| int | boundary_flag, | ||
| bool | group_by_type, | ||
| bool | group_all, | ||
| bool | discard_polygons, | ||
| bool | discard_polyhedra, | ||
| bool | divide_polygons, | ||
| bool | divide_polyhedra ) |
| cs_coord_t * fvm_writer_extra_vertex_coords | ( | const fvm_nodal_t * | mesh, |
| cs_lnum_t | n_extra_vertices ) |
| void fvm_writer_field_component_name | ( | char * | s, |
| size_t | s_size, | ||
| bool | lowercase, | ||
| int | dimension, | ||
| int | component_id ) |
| fvm_writer_field_helper_t * fvm_writer_field_helper_create | ( | const fvm_nodal_t * | mesh, |
| const fvm_writer_section_t * | section_list, | ||
| int | field_dim, | ||
| cs_interlace_t | interlace, | ||
| fvm_writer_var_loc_t | location ) |
| cs_datatype_t fvm_writer_field_helper_datatype | ( | const fvm_writer_field_helper_t * | helper | ) |
| void fvm_writer_field_helper_destroy | ( | fvm_writer_field_helper_t ** | helper | ) |
| int fvm_writer_field_helper_field_dim | ( | const fvm_writer_field_helper_t * | helper | ) |
| void fvm_writer_field_helper_get_size | ( | const fvm_writer_field_helper_t * | helper, |
| size_t * | input_size, | ||
| size_t * | output_size, | ||
| size_t * | min_output_buffer_size ) |
| const fvm_writer_section_t * fvm_writer_field_helper_output_e | ( | fvm_writer_field_helper_t * | helper, |
| void * | context, | ||
| const fvm_writer_section_t * | export_section, | ||
| int | src_dim, | ||
| cs_interlace_t | src_interlace, | ||
| const int * | comp_order, | ||
| int | n_parent_lists, | ||
| const cs_lnum_t | parent_num_shift[], | ||
| const void *const | field_values[], | ||
| fvm_writer_field_output_t * | output_func ) |
| void fvm_writer_field_helper_output_n | ( | fvm_writer_field_helper_t * | helper, |
| const fvm_nodal_t * | mesh, | ||
| int | src_dim, | ||
| int fvm_writer_field_helper_step_el | ( | fvm_writer_field_helper_t * | helper, |
| int | src_dim, | ||
| int | src_dim_shift, | ||
| void * | output_buffer, | ||
| size_t | output_buffer_size, | ||
| size_t * | output_size ) |
| int fvm_writer_field_helper_step_nl | ( | fvm_writer_field_helper_t * | helper, |
| int | src_dim, | ||
