fvm_writer_helper.h
1#ifndef __FVM_WRITER_HELPER_H__
2#define __FVM_WRITER_HELPER_H__
5 * Helper types and functions for mesh and field writers
30#include "base/cs_defs.h"
33 * Local headers
36#include "base/cs_block_dist.h"
38#include "fvm/fvm_defs.h"
39#include "fvm/fvm_nodal.h"
40#include "fvm/fvm_writer.h"
42/*----------------------------------------------------------------------------*/
45
46/*=============================================================================
47 * Macro definitions
49
51 * Type definitions
53
54/*----------------------------------------------------------------------------
55 * FVM nodal to writer section translation list
56 *----------------------------------------------------------------------------*/
57
58typedef struct _fvm_writer_section_t {
59
60 struct _fvm_writer_section_t *next; /* Pointer to next element
61 in list (NULL at end) */
62
63 const fvm_nodal_section_t *section; /* Corresponding section in mesh */
64
65 cs_gnum_t extra_vertex_base; /* Start global number of added
66 vertices (for tesselation) */
67
68 cs_lnum_t num_shift; /* Element number shift when no
69 parent lists are used */
70 fvm_element_t type; /* Corresponding element type (may
71 differ from section->type when
72 using tesselations) */
73
74 bool continues_previous; /* Indicates if the corresponding FVM
75 nodal section should be appended
76 to the previous one on output */
77
79
80/*----------------------------------------------------------------------------
81 * FVM nodal to writer field output helper
82 *----------------------------------------------------------------------------*/
83
84/*
85 Pointer to structure keeping track of the status of a writer's field
86 output state. The structure itself is private, and is defined in fvm_writer.c
87*/
88
89typedef struct _fvm_writer_field_helper_t fvm_writer_field_helper_t;
90
91/*----------------------------------------------------------------------------
92 * Function pointer for output of field values by a writer helper
93 *
94 * parameters:
95 * context <-> pointer to writer and field context
96 * datatype <-- output datatype
97 * dimension <-- output field dimension
98 * component_id <-- output component id (if non-interleaved)
99 * block_start <-- start global number of element for current block
100 * block_end <-- past-the-end global number of element for current block
101 * buffer <-> associated output buffer
102 *----------------------------------------------------------------------------*/
103
104typedef void
105(fvm_writer_field_output_t) (void *context,
106 cs_datatype_t datatype,
107 int dimension,
108 int component_id,
109 cs_gnum_t block_start,
110 cs_gnum_t block_end,
111 void *buffer);
112
113/*=============================================================================
114 * Semi-private function prototypes
115 *============================================================================*/
116
117/*----------------------------------------------------------------------------
118 * Build list of sections to output
119 *
120 * Depending on whether multiple sections of a given element type
121 * are allowed or not, sections may be ordered in different ways.
122 * Discarded element types are not added to the list.
123 *
124 * parameters:
125 * mesh <-- pointer to nodal mesh structure
126 * min_export_dim <-- minimum dimension of sections to export
127 * max_export_dim <-- maximum dimension of sections to export
128 * boundary_flag <-- -1 if ignored, otherwise only sections
129 * with -1 or matching boundary flag
130 * group_by_type <-- if true, group sections of same type
131 * group_all <-- if true, all sections continue previous ones
132 * discard_polygons <-- ignore polygonal sections
133 * discard_polyhedra <-- ignore polyhedral sections
134 * divide_polygons <-- tesselate polygonal sections
135 * divide_polyhedra <-- tesselate polyhedral sections
136 *
137 * returns:
138 * array of section translations (must be freed by caller),
139 * or NULL if section list is completely empty
140 *----------------------------------------------------------------------------*/
141
143fvm_writer_export_list(const fvm_nodal_t *mesh,
144 int min_export_dim,
145 int max_export_dim,
146 int boundary_flag,
147 bool group_by_type,
148 bool group_all,
149 bool discard_polygons,
150 bool discard_polyhedra,
151 bool divide_polygons,
152 bool divide_polyhedra);
153
154/*----------------------------------------------------------------------------
155 * Count number of extra vertices when tesselations are present
156 *
157 * parameters:
158 * mesh <-- pointer to nodal mesh structure
159 * divide_polyhedra <-- true if polyhedra are tesselated
160 * n_extra_vertices_g --> global number of extra vertices (optional)
161 * n_extra_vertices --> local number of extra vertices (optional)
162 *----------------------------------------------------------------------------*/
163
164void
166 bool divide_polyhedra,
167 cs_gnum_t *n_extra_vertices_g,
168 cs_lnum_t *n_extra_vertices);
169
170#if defined(HAVE_MPI)
171
172/*----------------------------------------------------------------------------
173 * Build block info and part to block distribution helper for vertices.
174 *
175 * parameters:
176 * min_rank_step <-- minimum step between output ranks
177 * min_block_size <-- minimum block buffer size
178 * n_g_add_vertices <-- global number of vertices due to tesselated polyhedra
179 * n_add_vertices <-- local number of vertices due to tesselated polyhedra
180 * mesh <-- pointer to nodal mesh structure
181 * bi --> block information structure
182 * d --> part to block distributor
183 * comm <-- associated communicator
184 *----------------------------------------------------------------------------*/
185
186void
187fvm_writer_vertex_part_to_block_create(int min_rank_step,
188 cs_lnum_t min_block_size,
189 cs_gnum_t n_g_add_vertices,
190 cs_lnum_t n_add_vertices,
191 const fvm_nodal_t *mesh,
193 cs_part_to_block_t **d,
194 MPI_Comm comm);
195
196#endif /* defined(HAVE_MPI) */
197
198/*----------------------------------------------------------------------------
199 * Return extra vertex coordinates when tesselations are present
200 *
201 * parameters:
202 * mesh <-- pointer to nodal mesh structure
203 * n_extra_vertices <-- number of extra vertices
204 *
205 * returns:
206 * array containing all extra vertex coordinates
207 *----------------------------------------------------------------------------*/
208
211 cs_lnum_t n_extra_vertices);
212
213/*----------------------------------------------------------------------------
214 * Create field writer helper structure.
215 *
216 * Local values are initialized, ang lobal values are set to zero
217 * (they may be initialized by calling fvm_writer_field_helper_init_g()).
218 *
219 * parameters:
220 * mesh <-- pointer to nodal mesh structure
221 * section_list <-- point to export section list helper structure
222 * field_dim <-- indicates output field dimension
223 * interlace <-- indicates if output is interlaced
224 * location <-- indicates if field is cell or node based
225 * datatype <-- datatype of destination buffers
226 *
227 * returns:
228 * pointer to allocated and initialized field writer helper
229 *----------------------------------------------------------------------------*/
230
233 const fvm_writer_section_t *section_list,
234 int field_dim,
235 cs_interlace_t interlace,
236 cs_datatype_t datatype,
237 fvm_writer_var_loc_t location);
238
239/*----------------------------------------------------------------------------
240 * Destroy FVM field writer helper.
241 *
242 * parameters: * helper <-> pointer to pointer to structure that should be destroyed
243 *----------------------------------------------------------------------------*/
244
245void
247
248#if defined(HAVE_MPI)
249
250/*----------------------------------------------------------------------------
251 * Set MPI info for an fvm_writer_field_helper structure.
252 *
253 * parameters:
254 * helper <-> pointer to structure that should be initialized
255 * min_rank_step <-- minimum step between output ranks
256 * min_block_size <-- minimum block buffer size
257 * comm <-- associated MPI communicator
258 *
259 * returns:
260 * pointer to allocated and initialized field writer helper
261 *----------------------------------------------------------------------------*/
262
263void
264fvm_writer_field_helper_init_g(fvm_writer_field_helper_t *helper,
265 int min_rank_step,
266 int min_block_size,
267 MPI_Comm comm);
268
269#endif /* defined(HAVE_MPI) */
270
271/*----------------------------------------------------------------------------
272 * Return sizes associated with a writer field helper.
273 *
274 * parameters:
275 * helper <-- pointer to helper structure
276 * input_size --> Total field locations in input (or NULL)
277 * output_size --> Total field locations in output (or NULL)
278 * min_output_buffer_size --> Minimum required buffer size (or NULL)
279 *----------------------------------------------------------------------------*/
280
281void
283 size_t *input_size,
284 size_t *output_size,
285 size_t *min_output_buffer_size);
286
287/*----------------------------------------------------------------------------
288 * Return the output dimension associated with a writer field helper.
289 *
290 * parameters:
291 * helper <-- pointer to helper structure
292 *
293 * returns:
294 * field dimension associated with helper
295 *----------------------------------------------------------------------------*/
296
297int
299
300/*----------------------------------------------------------------------------
301 * Return the output datatype associated with a writer field helper.
302 *
303 * parameters:
304 * helper <-- pointer to helper structure
305 *
306 * returns:
307 * output datatype associated with helper
308 *----------------------------------------------------------------------------*/
309
312
313/*----------------------------------------------------------------------------
314 * Partially distribute field values to a local output buffer.
315 *
316 * parameters:
317 * helper <-> pointer to helper structure
318 * export_section <-- pointer to section helper structure
319 * src_dim <-- dimension of source data
320 * src_dim_shift <-- source data dimension shift (start index)
321 * src_interlace <-- indicates if field in memory is interlaced
322 * n_parent_lists <-- indicates if field values are to be obtained
323 * directly through the local entity index (when 0) or
324 * through the parent entity numbers (when 1 or more)
325 * parent_num_shift <-- parent list to common number index shifts;
326 * size: n_parent_lists
327 * datatype <-- indicates the data type of (source) field values
328 * field_values <-- array of associated field value arrays
329 * datatype <-- input data type
330 * field_values <-- pointer to input array
331 * output_buffer <-- pointer to output buffer
332 * (working array only for ranks > 0)
333 * output_buffer_size <-- size of output buffer (in datatype units)
334 * output_size --> size of output upon return (in datatype units)
335 *
336 * returns:
337 * 0 if values were distributed to the output buffer, 1 if the end of the
338 * section has already been reached and no values were left to distribute.
339 *----------------------------------------------------------------------------*/
340
341int
343 const fvm_writer_section_t *export_section,
344 int src_dim,
345 int src_dim_shift,
346 cs_interlace_t src_interlace,
347 int n_parent_lists,
348 const cs_lnum_t parent_num_shift[],
349 cs_datatype_t datatype,
350 const void *const field_values[],
351 void *output_buffer,
352 size_t output_buffer_size,
353 size_t *output_size);
354
355/*----------------------------------------------------------------------------
356 * Partially distribute per node field values to a local output buffer.
357 *
358 * parameters:
359 * helper <-> pointer to helper structure
360 * mesh <-- pointer to associated mesh
361 * src_dim <-- dimension of source data
362 * src_dim_shift <-- source data dimension shift (start index)
363 * src_interlace <-- indicates if field in memory is interlaced
364 * n_parent_lists <-- indicates if field values are to be obtained
365 * directly through the local entity index (when 0) or
366 * through the parent entity numbers (when 1 or more)
367 * parent_num_shift <-- parent list to common number index shifts;
368 * size: n_parent_lists
369 * datatype <-- indicates the data type of (source) field values
370 * field_values <-- array of associated field value arrays
371 * datatype <-- input data type
372 * field_values <-- pointer to input array
373 * output_buffer <-- pointer to output buffer
374 * (working array only for ranks > 0)
375 * output_buffer_size <-- size of output buffer (in datatype units)
376 * output_size --> size of output upon return (in datatype units)
377 *
378 * returns:
379 * 0 if values were distributed to the output buffer, 1 if the end of the
380 * section has already been reached and no values were left to distribute.
381 *----------------------------------------------------------------------------*/
382
383int
385 const fvm_nodal_t *mesh,
386 int src_dim,
387 int src_dim_shift,
388 cs_interlace_t src_interlace,
389 int n_parent_lists,
390 const cs_lnum_t parent_num_shift[],
391 cs_datatype_t datatype,
392 const void *const field_values[],
393 void *output_buffer,
394 size_t output_buffer_size,
395 size_t *output_size);
396
397/*----------------------------------------------------------------------------
398 * Output per element field values, using writer-specific function
399 * and context structure pointers.
400 *
401 * Note that if the output data is not interleaved, for multidimensional data,
402 * the output function is called once per component, using the same buffer.
403 * This is a good fit for most options, but if a format requires writing
404 * additional buffering may be required in the context.
405 *
406 * parameters:
407 * helper <-> pointer to helper structure
408 * context <-> pointer to writer context
409 * export_section <-- pointer to section helper structure
410 * src_dim <-- dimension of source data
411 * src_interlace <-- indicates if field in memory is interlaced
412 * comp_order <-- field component reordering array, or NULL
413 * n_parent_lists <-- indicates if field values are to be obtained
414 * directly through the local entity index (when 0) or
415 * through the parent entity numbers (when 1 or more)
416 * parent_num_shift <-- parent list to common number index shifts;
417 * size: n_parent_lists
418 * datatype <-- indicates the data type of (source) field values
419 * field_values <-- array of associated field value arrays
420 * output_func <-- pointer to output function
421 *
422 * returns:
423 * pointer to next section helper structure in list
424 *----------------------------------------------------------------------------*/
425
428 void *context,
429 const fvm_writer_section_t *export_section,
430 int src_dim,
431 cs_interlace_t src_interlace,
432 const int *comp_order,
433 int n_parent_lists,
434 const cs_lnum_t parent_num_shift[],
435 cs_datatype_t datatype,
436 const void *const field_values[],
437 fvm_writer_field_output_t *output_func);
438
439/*----------------------------------------------------------------------------
440 * Output per node field values, using writer-specific function
441 * and context structure pointers.
442 *
443 * Note that if the output data is not interleaved, for multidimensional data,
444 * the output function is called once per component, using the same buffer.
445 * This is a good fit for most options, but if a format requires writing
446 * additional buffering may be required in the context.
447 *
448 * parameters:
449 * helper <-> pointer to helper structure
450 * context <-> pointer to writer context
451 * mesh <-- pointer to nodal mesh
452 * divide_polyhedra <-- tesselate polyhedral sections
453 * src_dim <-- dimension of source data
454 * src_dim_shift <-- source data dimension shift (start index)
455 * src_interlace <-- indicates if field in memory is interlaced
456 * n_parent_lists <-- indicates if field values are to be obtained
457 * directly through the local entity index (when 0) or
458 * through the parent entity numbers (when 1 or more)
459 * parent_num_shift <-- parent list to common number index shifts;
460 * size: n_parent_lists
461 * datatype <-- indicates the data type of (source) field values
462 * field_values <-- array of associated field value arrays
463 * datatype <-- input data type
464 * field_values <-- pointer to input array
465 * output_func <-- pointer to output function
466 *----------------------------------------------------------------------------*/
467
468void
470 void *context,
471 const fvm_nodal_t *mesh,
472 int src_dim,
473 cs_interlace_t src_interlace,
474 const int *comp_order,
475 int n_parent_lists,
476 const cs_lnum_t parent_num_shift[],
477 cs_datatype_t datatype,
478 const void *const field_values[],
479 fvm_writer_field_output_t *output_func);
480
481/*----------------------------------------------------------------------------
482 * Set string representing a field component's name based on its id.
483 *
484 * parameters:
485 * s --> destination string
486 * s_size <-- maximum string size
487 * lowercase <-- true if lowercase is required
488 * dimension <-- field dimension
489 * component_id <-- field component id
490 *----------------------------------------------------------------------------*/
491
492void
494 size_t s_size,
495 bool lowercase,
496 int dimension,
497 int component_id);
498
499/*----------------------------------------------------------------------------*/
500
502
503#endif /* __FVM_WRITER_HELPER_H__ */
cs_datatype_t
Definition cs_defs.h:300
Definition cs_defs.h:542
double cs_coord_t
Definition cs_defs.h:340
cs_interlace_t
Definition cs_defs.h:514
unsigned cs_gnum_t
global mesh entity number
Definition cs_defs.h:327
Definition cs_defs.h:543
Definition cs_defs.h:335
fvm_element_t
Definition fvm_defs.h:48
Definition fvm_writer.h:69
int fvm_writer_field_helper_field_dim(const fvm_writer_field_helper_t *helper)
cs_coord_t * fvm_writer_extra_vertex_coords(const fvm_nodal_t *mesh, cs_lnum_t n_extra_vertices)
const fvm_writer_section_t * fvm_writer_field_helper_output_e(fvm_writer_field_helper_t *helper, void *context, const fvm_writer_section_t *export_section, int src_dim, cs_interlace_t src_interlace, const int *comp_order, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, const void *const field_values[], fvm_writer_field_output_t *output_func)
void fvm_writer_field_helper_get_size(const fvm_writer_field_helper_t *helper, size_t *input_size, size_t *output_size, size_t *min_output_buffer_size)
Definition fvm_writer_helper.h:89
void fvm_writer_field_output_t(void *context, cs_datatype_t datatype, int dimension, int component_id, cs_gnum_t block_start, cs_gnum_t block_end, void *buffer)
Definition fvm_writer_helper.h:105
fvm_writer_section_t * fvm_writer_export_list(const fvm_nodal_t *mesh, int min_export_dim, int max_export_dim, int boundary_flag, bool group_by_type, bool group_all, bool discard_polygons, bool discard_polyhedra, bool divide_polygons, bool divide_polyhedra)
fvm_writer_field_helper_t * fvm_writer_field_helper_create(const fvm_nodal_t *mesh, const fvm_writer_section_t *section_list, int field_dim, cs_interlace_t interlace, cs_datatype_t datatype, fvm_writer_var_loc_t location)
cs_datatype_t fvm_writer_field_helper_datatype(const fvm_writer_field_helper_t *helper)
void fvm_writer_field_component_name(char *s, size_t s_size, bool lowercase, int dimension, int component_id)
void fvm_writer_count_extra_vertices(const fvm_nodal_t *mesh, bool divide_polyhedra, cs_gnum_t *n_extra_vertices_g, cs_lnum_t *n_extra_vertices)
void fvm_writer_field_helper_output_n(fvm_writer_field_helper_t *helper, void *context, const fvm_nodal_t *mesh, int src_dim, cs_interlace_t src_interlace, const int *comp_order, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, const void *const field_values[], fvm_writer_field_output_t *output_func)
int fvm_writer_field_helper_step_el(fvm_writer_field_helper_t *helper, const fvm_writer_section_t *export_section, int src_dim, int src_dim_shift, cs_interlace_t src_interlace, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, const void *const field_values[], void *output_buffer, size_t output_buffer_size, size_t *output_size)
int fvm_writer_field_helper_step_nl(fvm_writer_field_helper_t *helper, const fvm_nodal_t *mesh, int src_dim, int src_dim_shift, cs_interlace_t src_interlace, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, const void *const field_values[], void *output_buffer, size_t output_buffer_size, size_t *output_size)
void fvm_writer_field_helper_destroy(fvm_writer_field_helper_t **helper)
Definition mesh.f90:26
Definition cs_block_dist.h:50
Definition fvm_nodal_priv.h:58
Definition fvm_writer_helper.h:58
Definition fvm_writer_helper.h:65
Definition fvm_writer_helper.h:74
fvm_element_t type
Definition fvm_writer_helper.h:70
const fvm_nodal_section_t * section
Definition fvm_writer_helper.h:63
cs_lnum_t num_shift
Definition fvm_writer_helper.h:68
struct _fvm_writer_section_t * next
Definition fvm_writer_helper.h:60
