Here is a list of all variables with links to the structures/unions they belong to:
- l -
- L : fvm_morton_code_t
- l00 : cs_fluid_properties_t
- l2residual : cs_solving_info_t
- l_col_shift : cs_cdo_assembly_t
- l_darcy : cs_gwf_tpf_t
- l_diffusivity_h : cs_gwf_tpf_t
- l_id : cs_cdo_assembly_row_t
- l_mass_density : cs_gwf_tpf_t
- l_pressure : cs_gwf_tpf_t
- l_range : cs_range_set_t
- l_rho_h : cs_gwf_tpf_t
- l_row_shift : cs_cdo_assembly_t
- l_saturation : cs_gwf_tpf_t
- l_viscosity : cs_gwf_tpf_t
- label : cs_function_t
- lagr_time : cs_lagr_extra_module_t
- lam_viscosity : cs_navsto_param_t
- lambda : cs_thermal_system_t
- lambda0 : cs_fluid_properties_t
- lambda_a : cs_gas_mix_species_prop_t
- lambda_b : cs_gas_mix_species_prop_t
- lambda_h : cs_air_fluid_props_t
- lambda_l : cs_air_fluid_props_t
- lambda_vdw : cs_lagr_clogging_param_t, cs_lagr_dlvo_param_t, cs_lagr_physico_chemical_t, cs_lagr_roughness_param_t
- lamref : cs_gas_mix_species_prop_t
- lamvbr : cs_lagr_brownian_t
- last_inner_iter : cs_iter_algo_aac_t, cs_iter_algo_default_t
- last_nt : cs_time_control_t
- last_t : cs_time_control_t
- latent_heat : cs_solidification_t
- latitude : cs_atmo_option_t
- lb : cs_lagr_attribute_map_t, cs_lagr_event_attribute_map_t
- lcap_pty : cs_gwf_tpf_t
- les_param : cs_turbulence_param_t
- linf : cs_cavitation_parameters_t
- loc : cs_cell_builder_t
- local_models : cs_1d_wall_thermal_t
- location : cs_cdo_balance_t, cs_cdo_system_block_info_t, cs_meg_xdef_input_t
- location_id : cs_boundary_zone_t, cs_field_bc_coeffs_t, cs_field_t, cs_function_t, cs_io_sec_header_t, cs_lagr_injection_set_t, cs_lagr_zone_data_t, cs_volume_zone_t, cs_zone_t
- locator : cs_internal_coupling_t
- log : cs_function_t
- logrp : cs_opts_t
- longitude : cs_atmo_option_t
- lref : cs_libby_williams_params_t
- lsat_pre_array : cs_gwf_tpf_t
- lsat_pty : cs_gwf_tpf_t
- lsp_fuel : cs_combustion_gas_model_t
- ltsdyn : cs_lagr_source_terms_t
- ltsmas : cs_lagr_source_terms_t
- ltsthe : cs_lagr_source_terms_t
- lw : cs_combustion_gas_model_t
