User function. Define immersed boundaries in time and space. More...
| void | cs_user_ibm_define_objects (void) |
| User function in which the user defines the objects to model. | |
| void | cs_user_ibm_parameters (void) |
| User function to set global parameters for the immersed boundaries module. | |
| void | cs_user_ibm_object_transformations (const cs_real_t time) |
| User function where to apply predefined transformations to med/stl based objects. | |
| void | cs_user_ibm_solid_por (const cs_lnum_t c_id, const cs_real_3_t xyz, const cs_real_t t, const int num_object) |
| User function which allows the definition of a 'porous' object. | |
| void cs_user_ibm_define_objects | ( | void | ) |
| void cs_user_ibm_object_transformations | ( | const cs_real_t | time | ) |
| [in] | t | time value for the current time step |
| void cs_user_ibm_parameters | ( | void | ) |
| void cs_user_ibm_solid_por | ( | const cs_lnum_t | c_id, |
| const cs_real_3_t | xyz, | ||
| const cs_real_t | t, | ||
| const int | num_object ) |
| [in] | c_id | local cell number |
| [in] | xyz | x, y, z coordinates of the current position |
| [in] | num_object | num of fsi object (if fsi activated) |
