cs_turbulence_ke.h File Reference
Include dependency graph for cs_turbulence_ke.h:
void cs_turbulence_ke (int phase_id, cs_real_t *prdv2f)
 Solve the k-epsilon equations.
void cs_turbulence_ke_clip (int phase_id, cs_lnum_t n_cells, int iclip)
 Clipping of the turbulent kinetic energy and turbulent dissipation.
void cs_turbulence_ke_mu_t (int phase_id)
 Calculation of turbulent viscosity for the K-epsilon model.
void cs_turbulence_ke_q_mu_t (int phase_id)
 Calculation of turbulent viscosity for the non-linear quadratic K-epsilon from Baglietto et al. (2005)
void cs_turbulence_ke_q (int phase_id, cs_real_6_t rij[])
 Calculation of non linear terms of the quadratic k-epsilon model (Baglietto et al.)
◆ cs_turbulence_ke()
void cs_turbulence_ke ( int phase_id,
cs_real_t * prdv2f )
Solve the $ k - \varepsilon $ for incompressible flows or slightly compressible flows for one time step.
[in]phase_idturbulent phase id (-1 for single phase flow)
[out]prdv2fv2f production term
◆ cs_turbulence_ke_clip()
void cs_turbulence_ke_clip ( int phase_id,
cs_lnum_t n_cells,
int iclip )
[in]n_cellsnumber of cells
[in]iclipindicator = 0 if viscl0 is used otherwise viscl is used.
◆ cs_turbulence_ke_mu_t()
void cs_turbulence_ke_mu_t ( int phase_id)
◆ cs_turbulence_ke_q()
void cs_turbulence_ke_q ( int phase_id,
cs_real_6_t rij[] )
[out]rijnon linear terms of quadratic Boussinesq approximation
◆ cs_turbulence_ke_q_mu_t()
void cs_turbulence_ke_q_mu_t ( int phase_id)
