#include "base/cs_defs.h"#include <assert.h>#include <stdlib.h>#include <string.h>#include "bft/bft_mem.h"#include "bft/bft_printf.h"#include "base/cs_array.h"#include "base/cs_field_default.h"#include "pprt/cs_physical_model.h"#include "cdo/cs_reco.h"#include "base/cs_syr_coupling.h"#include "cdo/cs_thermal_system.h"Macros | |
| #define | CS_THERMAL_SYSTEM_DBG 0 |
| cs_real_t | cs_thermal_system_get_reference_temperature (void) |
| Retrieve the value of the reference temperature associated to a thermal system. | |
| void | cs_thermal_system_set_reference_temperature (cs_real_t ref) |
| Set the value of the reference temperature associated to the thermal system. | |
| cs_flag_t | cs_thermal_system_get_model (void) |
| Retrieve the model flag related to a thermal system. | |
| bool | cs_thermal_system_needs_navsto (void) |
| Does the thermal system rely on the advection field associated to the Navier-Stokes equations ? | |
| bool | cs_thermal_system_is_activated (void) |
| Check if the resolution of the thermal system has been activated. | |
| cs_thermal_system_t * | cs_thermal_system_activate (cs_thermal_model_type_t model, cs_flag_t numeric, cs_flag_t post) |
| Allocate and initialize the thermal system. | |
| void | cs_thermal_system_destroy (void) |
| Free the main structure related to the thermal system. | |
| cs_equation_t * | cs_thermal_system_get_equation (void) |
| Retrieve the main equation related to the thermal system. | |
| cs_real_t * | cs_thermal_system_get_face_temperature (void) |
| Retrieve the current temperature at face values. | |
| void | cs_thermal_system_init_setup (void) |
| Start setting-up the thermal system At this stage, numerical settings should be completely determined but connectivity and geometrical information is not yet available. | |
| void | cs_thermal_system_finalize_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step) |
| Last step of the setup of the thermal system. | |
| void | cs_thermal_system_compute_steady_state (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step) |
| Build and solve a steady-state thermal system. | |
| void | cs_thermal_system_compute (bool cur2prev, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step) |
| Build and solve the thermal system. | |
| void | cs_thermal_system_init_values (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts) |
| Set an initial values for all quantities related to this module This is done after the setup step. | |
| void | cs_thermal_system_update (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts, bool cur2prev) |
| Update the quantities related to the thermal module. | |
| void | cs_thermal_system_extra_op (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq) |
| Predefined extra-operations for the Navier-Stokes system. | |
| void | cs_thermal_system_extra_post (void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *time_step) |
| Predefined post-processing output for the thermal system. The prototype of this function is fixed since it is a function pointer defined in cs_post.h (cs_post_time_mesh_dep_output_t) | |
| void | cs_thermal_system_log_setup (void) |
| Summary of the main options related to cs_thermal_system_t structure. | |
| void | cs_thermal_system_cht_boundary_conditions_setup (void) |
| Initialize structures and/or boundary conditions used for CHT coupling. | |
| #define CS_THERMAL_SYSTEM_DBG 0 |
| cs_thermal_system_t * cs_thermal_system_activate | ( | cs_thermal_model_type_t | model, |
| cs_flag_t | numeric, | ||
| cs_flag_t | post ) |
| [in] | model | model flag related to the thermal system |
| [in] | numeric | (optional) numerical flag settings |
| [in] | post | (optional) post-processing flag settings |
| void cs_thermal_system_cht_boundary_conditions_setup | ( | void | ) |
| void cs_thermal_system_compute | ( | bool | cur2prev, |
| void cs_thermal_system_compute_steady_state | ( | const cs_mesh_t * | mesh, |
| void cs_thermal_system_destroy | ( | void | ) |
| void cs_thermal_system_extra_op | ( | const cs_cdo_connect_t * | connect, |
| const cs_cdo_quantities_t * | cdoq ) |
Predefined extra-operations for the thermal system.
| void cs_thermal_system_extra_post | ( | void * | input, |
| int | mesh_id, | ||
| int | cat_id, | ||
| int | ent_flag[5], | ||
| cs_lnum_t | n_cells, | ||
| cs_lnum_t | n_i_faces, | ||
| cs_lnum_t | n_b_faces, | ||
| [in,out] | input | pointer to a optional structure (here a cs_thermal_system_t structure) |
| void cs_thermal_system_finalize_setup | ( | const cs_cdo_connect_t * | connect, |
| cs_equation_t * cs_thermal_system_get_equation | ( | void | ) |
| cs_real_t * cs_thermal_system_get_face_temperature | ( | void | ) |
| cs_flag_t cs_thermal_system_get_model | ( | void | ) |
| cs_real_t cs_thermal_system_get_reference_temperature | ( | void | ) |
| void cs_thermal_system_init_setup | ( | void | ) |
| void cs_thermal_system_init_values | ( | const cs_mesh_t * | mesh, |
| const cs_time_step_t * | ts ) |
| bool cs_thermal_system_is_activated | ( | void | ) |
| void cs_thermal_system_log_setup | ( | void | ) |
| bool cs_thermal_system_needs_navsto | ( | void | ) |
| void cs_thermal_system_set_reference_temperature | ( | cs_real_t | ref | ) |
| [in] | ref | value of the reference temperature |
| void cs_thermal_system_update | ( | const cs_mesh_t * | mesh, |
| bool | cur2prev ) |
