#include "base/cs_defs.h"#include "cdo/cs_cdo_blas.h"#include "cdo/cs_cdo_system.h"#include "cdo/cs_iter_algo.h"#include "cdo/cs_property.h"#include "alge/cs_param_saddle.h"#include "alge/cs_sles.h"Go to the source code of this file.
| struct | cs_saddle_solver_t |
| struct | cs_saddle_solver_context_alu_t |
| struct | cs_saddle_solver_context_block_pcd_t |
| struct | cs_saddle_solver_context_gkb_t |
| struct | cs_saddle_solver_context_notay_t |
| struct | cs_saddle_solver_context_uzawa_cg_t |
| struct | cs_saddle_solver_context_simple_t |
| typedef void | cs_saddle_solver_matvec_t(cs_lnum_t n2_dofs, const cs_real_t *vec, const cs_adjacency_t *mat_adj, const cs_real_t *mat_op, cs_real_t *matvec) |
| Generic function prototype to perform a matrix vector operation This operation takes place between an unassembled matrix and a vector. | |
| int | cs_saddle_solver_get_n_systems (void) |
| Retrieve the number of saddle-point systems which have been added. | |
| cs_saddle_solver_t * | cs_saddle_solver_by_id (int id) |
| Get a pointer to saddle-point solver from its id. | |
| cs_saddle_solver_t * | cs_saddle_solver_add (cs_lnum_t n1_elts, int n1_dofs_by_elt, cs_lnum_t n2_elts, int n2_dofs_by_elt, const cs_param_saddle_t *saddlep, cs_cdo_system_helper_t *sh, cs_sles_t *main_sles) |
| Add a new solver for solving a saddle-point problem. | |
| void | cs_saddle_solver_finalize (void) |
| Free all remaining structures related to saddle-point solvers. | |
| void | cs_saddle_solver_free (cs_saddle_solver_t **p_solver) |
| Free a cs_saddle_solver_t structure. | |
| void | cs_saddle_solver_clean (cs_saddle_solver_t *solver) |
| Free/reset only a part of a cs_saddle_solver_t structure. | |
| void | cs_saddle_solver_update_monitoring (cs_saddle_solver_t *solver, unsigned n_iter) |
| Update the current monitoring state with n_iter. | |
| void | cs_saddle_solver_log_monitoring (void) |
| Log the monitoring performance of all saddle-point systems. | |
| cs_real_t * | cs_saddle_solver_m11_inv_lumped (cs_saddle_solver_t *solver, const cs_matrix_t *m11, const cs_range_set_t *b11_rset, cs_sles_t *xtra_sles, int *n_iter) |
| Retrieve the lumped matrix the inverse of the diagonal of the (1,1)-block matrix. The storage of a matrix is in a gather view and the resulting array is in scatter view. | |
| void | cs_saddle_solver_m12_multiply_vector (cs_lnum_t n2_dofs, const cs_real_t *x2, const cs_adjacency_t *m21_adj, const cs_real_t *m21_val, cs_real_t *m12x2) |
| Compute the resulting vector of the operation m12*x2 The stride is equal to 3 for the operator m21 (unassembled) x2 corresponds to a "scatter" view. | |
| void | cs_saddle_solver_m12_multiply_scalar (cs_lnum_t n2_elts, const cs_real_t *x2, const cs_adjacency_t *m21_adj, const cs_real_t *m21_val, cs_real_t *m12x2) |
| Compute the resulting vector of the operation m12*x2 The stride is equal to 1 for the operator m21 (unassembled) x2 corresponds to a "scatter" view. | |
| void | cs_saddle_solver_m21_multiply_vector (cs_lnum_t n2_dofs, const cs_real_t *x1, const cs_adjacency_t *m21_adj, const cs_real_t *m21_val, cs_real_t *m21x1) |
| Compute the resulting vector of the operation m21*x1 The stride is equal to 3 for the operator m21 operator x1 corresponds to a "scatter" view. | |
| void | cs_saddle_solver_m21_multiply_scalar (cs_lnum_t n2_dofs, const cs_real_t *x1, const cs_adjacency_t *m21_adj, const cs_real_t *m21_val, cs_real_t *m21x1) |
| Compute the resulting vector of the operation m21*x1 The stride is equal to 1 for the operator m21 operator x1 corresponds to a "scatter" view. | |
| void | cs_saddle_solver_context_alu_create (cs_saddle_solver_t *solver) |
| Create and initialize the context structure for an algorithm related to the ALU algorithm. | |
| void | cs_saddle_solver_context_alu_clean (cs_saddle_solver_context_alu_t *ctx) |
| Free main memory consuming part of the context structure associated to an ALU algorithm. | |
| void | cs_saddle_solver_context_alu_free (cs_saddle_solver_context_alu_t **p_ctx) |
| Free the context structure associated to an ALU algorithm. | |
| void | cs_saddle_solver_context_block_pcd_create (cs_lnum_t b22_max_size, cs_saddle_solver_t *solver) |
| Create and initialize the context structure for a block preconditioner used in combination with a Krylov solver such as MINRES or GCR. | |
| void | cs_saddle_solver_context_block_pcd_clean (cs_saddle_solver_context_block_pcd_t *ctx) |
| Free the context structure for a block preconditioner used in combination with a Krylov solver such as MINRES or GCR. | |
| void | cs_saddle_solver_context_block_pcd_free (cs_saddle_solver_context_block_pcd_t **p_ctx) |
| void | cs_saddle_solver_context_gkb_create (cs_saddle_solver_t *solver) |
| Create and initialize the context structure for the GKB algorithm. | |
| void | cs_saddle_solver_context_gkb_clean (cs_saddle_solver_context_gkb_t *ctx) |
| Free the main memory consuming part of the context structure associated to the GKB algorithm. | |
| void | cs_saddle_solver_context_gkb_free (cs_saddle_solver_context_gkb_t **p_ctx) |
| Free the context structure associated to the GKB algorithm. | |
| void | cs_saddle_solver_context_notay_create (cs_saddle_solver_t *solver) |
| Create and initialize the context structure for the algorithm relying on the Notay's algebraic transformation. | |
| void | cs_saddle_solver_context_uzawa_cg_create (cs_lnum_t b22_max_size, cs_saddle_solver_t *solver) |
| Create and initialize the context structure for an algorithm related to the Uzawa-CG algorithm. | |
| void | cs_saddle_solver_context_uzawa_cg_clean (cs_saddle_solver_context_uzawa_cg_t *ctx) |
| Free main memory consuming part of the context structure associated to a Uzawa-CG algorithm. | |
| void | cs_saddle_solver_context_uzawa_cg_free (cs_saddle_solver_context_uzawa_cg_t **p_ctx) |
| Free the context structure associated to a Uzawa-CG algorithm. | |
| void | cs_saddle_solver_context_simple_create (cs_lnum_t b22_max_size, cs_saddle_solver_t *solver) |
| Create and initialize the context structure for an algorithm related to the SIMPLE algorithm. | |
| void | cs_saddle_solver_context_simple_clean (cs_saddle_solver_context_simple_t *ctx) |
| Free main memory consuming part of the context structure associated to a SIMPLE algorithm. | |
| void | cs_saddle_solver_context_simple_free (cs_saddle_solver_context_simple_t **p_ctx) |
| void | cs_saddle_solver_alu_incr (cs_saddle_solver_t *solver, cs_real_t *x1, cs_real_t *x2) |
| Apply the Augmented Lagrangian-Uzawa algorithm to a saddle point problem (the system is stored in a hybrid way). The stride is equal to 1 for the matrix (db_size[3] = 1) and the vector. | |
| void | cs_saddle_solver_gcr (cs_saddle_solver_t *solver, cs_real_t *x1, cs_real_t *x2) |
| Apply the GCR algorithm to a saddle point problem (the system is stored in a hybrid way). The stride is equal to 1 for the matrix in the (1,1) block (db_size[3] = 1). | |
| void | cs_saddle_solver_gkb_inhouse (cs_saddle_solver_t *solver, cs_real_t *x1, cs_real_t *x2) |
| Apply the GKB algorithm to a saddle point problem (the system is stored in a hybrid way). The stride is equal to 1 for the matrix in the (1,1) block (db_size[3] = 1). | |
| void | cs_saddle_solver_sles_full_system (cs_saddle_solver_t *solver, cs_real_t *x1, cs_real_t *x2) |
| Apply an (external) solver to solve a saddle point problem (the system is stored in a monolithic way). | |
| void | cs_saddle_solver_minres (cs_saddle_solver_t *solver, cs_real_t *x1, cs_real_t *x2) |
| Apply the MINRES algorithm to a saddle point problem (the system is stored in a hybrid way). The stride is equal to 1 for the matrix (db_size[3] = 1) and the vector. | |
| void | cs_saddle_solver_notay (cs_saddle_solver_t *solver, cs_real_t *x1, cs_real_t *x2) |
| Apply the Notay's transformation algorithm to solve a saddle point problem (the system is stored in a monolithic way). | |
| void | cs_saddle_solver_uzawa_cg (cs_saddle_solver_t *solver, cs_real_t *x1, cs_real_t *x2) |
| Apply the Uzawa-CG algorithm to solve a saddle point problem (the system is stored in a hybrid way). This algorithm is based on Koko's paper "Uzawa conjugate gradient method for the Stokes problem: Matlab
implementation with P1-iso-P2/ P1 finite element". | |
| void | cs_saddle_solver_simple (cs_saddle_solver_t *solver, cs_real_t *x1, cs_real_t *x2) |
| Apply the SIMPLE-like algorithm to solve a saddle point problem. | |
| typedef void cs_saddle_solver_matvec_t(cs_lnum_t n2_dofs, const cs_real_t *vec, const cs_adjacency_t *mat_adj, const cs_real_t *mat_op, cs_real_t *matvec) |
| [in] | n2_dofs | number of (scatter) DoFs for the (2,2)-block |
| [in] | vec | array of values |
| [in] | mat_adj | adjacency related to the matrix operator |
| [in] | mat_val | values associated to the matrix operator |
| [in,out] | matvec | resulting vector (have to be allocated) |
| cs_saddle_solver_t * cs_saddle_solver_add | ( | cs_lnum_t | n1_elts, |
| int | n1_dofs_by_elt, | ||
| cs_lnum_t | n2_elts, | ||
| int | n2_dofs_by_elt, | ||
| const cs_param_saddle_t * | saddlep, | ||
| cs_cdo_system_helper_t * | sh, | ||
| cs_sles_t * | main_sles ) |
| [in] | n1_elts | number of elements associated to the (1,1)-block |
| [in] | n1_dofs_by_elt | number of DoFs by elements in the (1,1)-block |
| [in] | n2_elts | number of elements associated to the (2,2)-block |
| [in] | n2_dofs_by_elt | number of DoFs by elements in the (2,2)-block |
| [in] | saddlep | set of parameters for the saddle-point solver |
| [in] | sh | pointer to a system helper structure |
| [in] | main_sles | pointer to the main SLES structure related to this saddle-point problem |
| void cs_saddle_solver_alu_incr | ( | cs_saddle_solver_t * | solver, |
| cs_real_t * | x1, | ||
| cs_real_t * | x2 ) |
| [in,out] | solver | pointer to a saddle_point solver structure |
| [in,out] | x1 | array for the first part |
| [in,out] | x2 | array for the second part |
| cs_saddle_solver_t * cs_saddle_solver_by_id | ( | int | id | ) |
| [in] | id | id of the saddle-point system |
| void cs_saddle_solver_clean | ( | cs_saddle_solver_t * | solver | ) |
| [in,out] | solver | double pointer to the structure to free |
| void cs_saddle_solver_context_alu_clean | ( | cs_saddle_solver_context_alu_t * | ctx | ) |
| [in,out] | ctx | pointer to the context structure to clean |
| void cs_saddle_solver_context_alu_create | ( | cs_saddle_solver_t * | solver | ) |
| [in,out] | solver | pointer to a saddle-point solver structure |
| void cs_saddle_solver_context_alu_free | ( | cs_saddle_solver_context_alu_t ** | p_ctx | ) |
| [in,out] | p_ctx | double pointer to the context structure to free |
| void cs_saddle_solver_context_block_pcd_clean | ( | cs_saddle_solver_context_block_pcd_t * | ctx | ) |
| [in,out] | ctx | pointer to the context structure to free |
| void cs_saddle_solver_context_block_pcd_create | ( | cs_lnum_t | b22_max_size, |
| cs_saddle_solver_t * | solver ) |
| [in] | b22_max_size | max. size for the second part of unknows |
| void cs_saddle_solver_context_block_pcd_free | ( | cs_saddle_solver_context_block_pcd_t ** | p_ctx | ) |
| void cs_saddle_solver_context_gkb_clean | ( | cs_saddle_solver_context_gkb_t * | ctx | ) |
| void cs_saddle_solver_context_gkb_create | ( | cs_saddle_solver_t * | solver | ) |
| void cs_saddle_solver_context_gkb_free | ( | cs_saddle_solver_context_gkb_t ** | p_ctx | ) |
| void cs_saddle_solver_context_notay_create | ( | cs_saddle_solver_t * | solver | ) |
| void cs_saddle_solver_context_simple_clean | ( | cs_saddle_solver_context_simple_t * | ctx | ) |
| void cs_saddle_solver_context_simple_create | ( | cs_lnum_t | b22_max_size, |
| void cs_saddle_solver_context_simple_free | ( | cs_saddle_solver_context_simple_t ** | p_ctx | ) |
| void cs_saddle_solver_context_uzawa_cg_clean | ( | cs_saddle_solver_context_uzawa_cg_t * | ctx | ) |
| void cs_saddle_solver_context_uzawa_cg_create | ( | cs_lnum_t | b22_max_size, |
| void cs_saddle_solver_context_uzawa_cg_free | ( | cs_saddle_solver_context_uzawa_cg_t ** | p_ctx | ) |
| void cs_saddle_solver_finalize | ( | void | ) |
| void cs_saddle_solver_free | ( | cs_saddle_solver_t ** | p_solver | ) |
| [in,out] | p_solver | double pointer to the structure to free |
| void cs_saddle_solver_gcr | ( | cs_saddle_solver_t * | solver, |
This algorithm is taken from 2010 Notay's paper: "An aggregation-based algebraic multigrid method" ETNA (vol. 37)
| int cs_saddle_solver_get_n_systems | ( | void | ) |
| void cs_saddle_solver_gkb_inhouse | ( | cs_saddle_solver_t * | solver, |
| void cs_saddle_solver_log_monitoring | ( | void | ) |
| cs_real_t * cs_saddle_solver_m11_inv_lumped | ( | cs_saddle_solver_t * | solver, |
| const cs_matrix_t * | m11, | ||
| const cs_range_set_t * | b11_rset, | ||
| cs_sles_t * | xtra_sles, | ||
| int * | n_iter ) |
| [in] | solver | solver for saddle-point problems |
| [in] | m11 | matrix related to the (1,1) block |
| [in] | b11_rset | range set structure for the (1,1) block |
| [in,out] | xtra_sles | pointer to an extra SLES structure |
| [out] | n_iter | number of iterations for this operation |
| void cs_saddle_solver_m12_multiply_scalar | ( | cs_lnum_t | n2_elts, |
| const cs_real_t * | x2, | ||
| const cs_adjacency_t * | m21_adj, | ||
| const cs_real_t * | m21_val, | ||
| cs_real_t * | m12x2 ) |
This is an update operation. Be careful that the resulting array has to be initialized.
| [in] | n2_elts | number of elements for x2 (not DoFs) |
| [in] | x2 | array for the second set |
| [in] | m21_adj | adjacency related to the M21 operator |
| [in] | m21_val | array associated to the M21 operator (unassembled) |
| [in,out] | m12x2 | resulting array (have to be allocated) |
| void cs_saddle_solver_m12_multiply_vector | ( | cs_lnum_t | n2_dofs, |
| [in] | n2_dofs | number of DoFs for x2 |
| void cs_saddle_solver_m21_multiply_scalar | ( | cs_lnum_t | n2_dofs, |
| const cs_real_t * | x1, | ||
| cs_real_t * | m21x1 ) |
| [in] | n2_dofs | number of (scatter) DoFs for (2,2)-block |
| [in] | x1 | array for the first part |
| [in] | m21_val | values associated to the M21 operator (unassembled) |
| [in,out] | m21x1 | resulting vector (have to be allocated) |
| void cs_saddle_solver_m21_multiply_vector | ( | cs_lnum_t | n2_dofs, |
| void cs_saddle_solver_minres | ( | cs_saddle_solver_t * | solver, |
| void cs_saddle_solver_notay | ( | cs_saddle_solver_t * | solver, |
| [in,out] | solver | pointer to a cs_saddle_solver_t structure |
| void cs_saddle_solver_simple | ( | cs_saddle_solver_t * | solver, |
| void cs_saddle_solver_sles_full_system | ( | cs_saddle_solver_t * | solver, |
| void cs_saddle_solver_update_monitoring | ( | cs_saddle_solver_t * | solver, |
| unsigned | n_iter ) |
| [in,out] | solver | pointer to a saddle solver structure |
| [in] | n_iter | number of iterations needed for a new call |
| void cs_saddle_solver_uzawa_cg | ( | cs_saddle_solver_t * | solver, |
Apply the Uzawa-CG algorithm to solve a saddle point problem (the system is stored in a hybrid way). This algorithm is based on Koko's paper "Uzawa conjugate gradient method for the Stokes problem: Matlab implementation with P1-iso-P2/ P1 finite element".
