cs_join_split.h
1#ifndef __CS_JOIN_SPLIT_H__
2#define __CS_JOIN_SPLIT_H__
5 * Set of subroutines for cutting faces during face joining.
6 *===========================================================================*/
31 * Local headers
32 *---------------------------------------------------------------------------*/
34#include "base/cs_base.h"
35#include "mesh/cs_join_mesh.h"
36#include "mesh/cs_join_set.h"
37#include "mesh/cs_join_util.h"
38
39/*---------------------------------------------------------------------------*/
43/*============================================================================
44 * Macro and type definitions
45 *===========================================================================*/
46
48 * Public function prototypes
49 *===========================================================================*/
50
51/*----------------------------------------------------------------------------
52 * Build new faces after the vertex fusion operation. Split initial faces into
53 * subfaces and keep the historic between initial/final faces.
54 *
55 * parameters:
56 * param <-- set of user-defined parameters
57 * face_normal <-- array of normal vector on each face
58 * edges <-- list of edges
59 * work <-> pointer to a cs_join_mesh_t structure
60 * old2new_history <-> relation between new faces and old one:
61 * old global face -> new local face
62 *---------------------------------------------------------------------------*/
63
64void
66 const cs_real_t face_normal[],
67 const cs_join_edges_t *edges,
68 cs_join_mesh_t **work,
69 cs_join_gset_t **old2new_history);
70
71/*----------------------------------------------------------------------------
72 * Update after face splitting of the local join mesh structure.
73 * Send back to the original rank the new face description.
74 *
75 * parameters:
76 * param <-- set of user-defined parameters
77 * work_mesh <-- distributed mesh on faces to join
78 * gnum_rank_index <-- index on ranks for the old global face numbering
79 * o2n_hist <-> old global face -> new local face numbering
80 * local_mesh <-> mesh on local selected faces to be joined
81 *---------------------------------------------------------------------------*/
82
83void
85 const cs_join_mesh_t *work_mesh,
86 const cs_gnum_t gnum_rank_index[],
87 cs_join_gset_t **o2n_hist,
88 cs_join_mesh_t **local_mesh);
89
90/*---------------------------------------------------------------------------*/
91
93
94#endif /* __CS_JOIN_SPLIT_H__ */
Definition cs_defs.h:542
Definition cs_defs.h:342
unsigned cs_gnum_t
global mesh entity number
Definition cs_defs.h:327
Definition cs_defs.h:543
void cs_join_split_faces(cs_join_param_t param, const cs_real_t face_normal[], const cs_join_edges_t *edges, cs_join_mesh_t **work, cs_join_gset_t **old2new_history)
Definition cs_join_split.cpp:1842
void cs_join_split_update_struct(const cs_join_param_t param, const cs_join_mesh_t *work_mesh, const cs_gnum_t gnum_rank_index[], cs_join_gset_t **o2n_hist, cs_join_mesh_t **local_mesh)
Definition cs_join_split.cpp:2257
Definition cs_join_util.h:115
