| cs_join_t * | cs_join_create (int join_number, const char *sel_criteria, float fraction, float plane, fvm_periodicity_type_t perio_type, double perio_matrix[3][4], int verbosity, int visualization, bool preprocessing) |
| void | cs_join_destroy (cs_join_t **join) |
| cs_join_select_t * | cs_join_select_create (const char *selection_criteria, fvm_periodicity_type_t perio_type, int verbosity) |
| void | cs_join_select_destroy (cs_join_param_t param, cs_join_select_t **join_select) |
| void | cs_join_extract_vertices (cs_lnum_t n_select_faces, const cs_lnum_t *select_faces, const cs_lnum_t *f2v_idx, const cs_lnum_t *f2v_lst, cs_lnum_t n_vertices, cs_lnum_t *n_select_vertices, cs_lnum_t *select_vertices[]) |
| void | cs_join_clean_selection (cs_lnum_t *n_elts, cs_lnum_t *elts[], cs_lnum_t n_ref_elts, cs_lnum_t ref_elts[]) |
| void | cs_join_build_edges_idx (cs_lnum_t n_faces, const cs_lnum_t faces[], const cs_lnum_t f2v_idx[], const cs_lnum_t f2v_lst[], cs_lnum_t v2v_idx[]) |
| void | cs_join_build_edges_lst (cs_lnum_t n_faces, const cs_lnum_t faces[], const cs_lnum_t f2v_idx[], const cs_lnum_t f2v_lst[], cs_lnum_t count[], const cs_lnum_t v2v_idx[], cs_lnum_t v2v_lst[]) |
◆ cs_join_state_t
| Enumerator |
| CS_JOIN_STATE_UNDEF | |
| CS_JOIN_STATE_NEW | |
| CS_JOIN_STATE_ORIGIN | |
| CS_JOIN_STATE_PERIO | |
| CS_JOIN_STATE_MERGE | |
| CS_JOIN_STATE_PERIO_MERGE | |
| CS_JOIN_STATE_SPLIT | |
◆ cs_join_type_t
| Enumerator |
| CS_JOIN_TYPE_NULL | |
| CS_JOIN_TYPE_CONFORMING | |
| CS_JOIN_TYPE_NON_CONFORMING | |
◆ cs_join_build_edges_idx()
◆ cs_join_build_edges_lst()
◆ cs_join_clean_selection()
◆ cs_join_create()
| cs_join_t * cs_join_create |
int | join_number, |
const char * | sel_criteria, |
float | fraction, |
float | plane, |
fvm_periodicity_type_t | perio_type, |
double | perio_matrix[3][4], |
int | verbosity, |
int | visualization, |
bool | preprocessing ) |
◆ cs_join_destroy()
| void cs_join_destroy |
cs_join_t ** | join | ) |
◆ cs_join_extract_vertices()
◆ cs_join_select_create()
| cs_join_select_t * cs_join_select_create |
const char * | selection_criteria, |
int | verbosity ) |
◆ cs_join_select_destroy()
| void cs_join_select_destroy |
cs_join_param_t | param, |
cs_join_select_t ** | join_select ) |
