cs_join_intersect.h
1#ifndef __CS_JOIN_INTERSECT_H__
2#define __CS_JOIN_INTERSECT_H__
5 * Set of subroutines for finding intersections between bounding boxes
6 * - on faces
7 * - on edges
8 *===========================================================================*/
9
10/*
11 This file is part of code_saturne, a general-purpose CFD tool.
13 Copyright (C) 1998-2025 EDF S.A.
14
15 This program is free software; you can redistribute it and/or modify it under
16 the terms of the GNU General Public License as published by the Free Software
17 Foundation; either version 2 of the License, or (at your option) any later
18 version.
19
20 This program is distributed in the hope that it will be useful, but WITHOUT
21 ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
22 FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
23 details.
24
25 You should have received a copy of the GNU General Public License along with
26 this program; if not, write to the Free Software Foundation, Inc., 51 Franklin
27 Street, Fifth Floor, Boston, MA 02110-1301, USA.
28*/
30/*----------------------------------------------------------------------------*/
33 * Standard C library headers
34 *---------------------------------------------------------------------------*/
37 * Local library headers
38 *---------------------------------------------------------------------------*/
40#include "base/cs_base.h"
41#include "mesh/cs_join_mesh.h"
42#include "mesh/cs_join_set.h"
43#include "mesh/cs_join_util.h"
45/*---------------------------------------------------------------------------*/
46
48
50 * Macro and type definitions
51 *===========================================================================*/
52
54
55/* Definition of a structure defining an intersection */
56/* -------------------------------------------------- */
57
58typedef struct {
59
60 cs_lnum_t edge_id; /* id of the edge implied in this intersection */
61 cs_lnum_t vtx_id; /* id of the vertex resulting of the intersection */
62 cs_coord_t curv_abs; /* curvilinear abscissa of the intersection */
63
64} cs_join_inter_t;
65
66/* Definition of a structure defining a set of intersections */
67/* --------------------------------------------------------- */
68
69typedef struct {
70
71 cs_lnum_t n_max_inter; /* max. number of intersections allocated */
72 cs_lnum_t n_inter; /* number of intersections */
73
74 cs_join_inter_t *inter_lst; /* size = 2 * n_intersections
75 one inter_t structure for each edge
76 implied in an intersection */
77
78} cs_join_inter_set_t;
79
80/* Definition of a structure defining a set of intersections on edges */
81/* ------------------------------------------------------------------ */
82
83typedef struct {
84
85 cs_lnum_t n_edges; /* Number of edges implied in an intersection */
86
87 cs_gnum_t *edge_gnum; /* Global number of the related edges */
88 cs_lnum_t *index; /* Indexed list of vertex num describing
89 intersections on a given edge without
90 vertices at the extremity and ordered
91 by curvilinear abscissa */
92
93 cs_lnum_t *vtx_lst; /* List of new vertex num */
94 cs_gnum_t *vtx_glst; /* List of new vertex global num */
95 cs_coord_t *abs_lst; /* List of curvilinear abscissa */
96
97 cs_lnum_t max_sub_size;
98
99} cs_join_inter_edges_t;
100
102
103/*============================================================================
104 * Public function prototypes
105 *===========================================================================*/
106
107/*----------------------------------------------------------------------------
108 * Create a new cs_join_inter_set_t structure.
109 *
110 * parameters:
111 * init_size <-- number of init. cs_join_inter_t structure to allocate
112 *
113 * returns:
114 * a pointer to a new inter_set_t structure.
115 *---------------------------------------------------------------------------*/
116
117cs_join_inter_set_t *
119
120/*----------------------------------------------------------------------------
121 * Destroy a cs_join_inter_set_t structure.
122 *
123 * parameters:
124 * inter_set <-> a pointer to the inter_set_t structure to destroy
125 *---------------------------------------------------------------------------*/
126
127void
128cs_join_inter_set_destroy(cs_join_inter_set_t **inter_set);
129
130/*----------------------------------------------------------------------------
131 * Dump a cs_join_inter_set_t structure.
132 *
133 * parameters:
134 * f <-- handle to output file
135 * i_set <-- cs_join_inter_set_t structure to dump
136 * edges <-- associated cs_join_edge_t structure
137 * mesh <-- associated cs_join_mesh_t structure
138 *---------------------------------------------------------------------------*/
139
140void
142 const cs_join_inter_set_t *i_set,
143 const cs_join_edges_t *edges,
144 const cs_join_mesh_t *mesh);
145
146/*----------------------------------------------------------------------------
147 * Allocate and initialize a new cs_join_inter_edges_t structure.
148 *
149 * parameters:
150 * n_edges <-- number of edges
151 *
152 * returns:
153 * a pointer to the created cs_join_inter_edges_t structure.
154 *---------------------------------------------------------------------------*/
155
156cs_join_inter_edges_t *
158
159/*----------------------------------------------------------------------------
160 * Build a cs_join_inter_edges_t structure (useful to find equivalence on
161 * edges and to apply vertex merge to a cs_join_mesh_t structure).
162 *
163 * parameters:
164 * edges <-- cs_join_edges_t structure
165 * inter_set <-- structure storing data on edge intersections
166 *
167 * returns:
168 * a pointer to the created cs_join_inter_edges_t structure
169 *---------------------------------------------------------------------------*/
170
171cs_join_inter_edges_t *
172cs_join_inter_edges_define(const cs_join_edges_t *edges,
173 const cs_join_inter_set_t *inter_set);
174
175/*----------------------------------------------------------------------------
176 * Destroy an cs_join_inter_edges_t structure.
177 *
178 * parameters:
179 * inter_edges <-> pointer to cs_join_inter_edges_t structure to destroy
180 *---------------------------------------------------------------------------*/
181
182void
183cs_join_inter_edges_destroy(cs_join_inter_edges_t **inter_edges);
184
185/*----------------------------------------------------------------------------
186 * Find non-trivial equivalences between vertices sharing the same edges.
187 *
188 * For instance an equivalence between a vertex from the extremity of an edge
189 * and a vertex created by an edge-edge intersection.
190 *
191 * parameters:
192 * param <-- set of user-defined parameter
193 * mesh <-- pointer to the local cs_join_mesh_t structure
194 * which has initial vertex data
195 * edges <-- list of edges
196 * inter_edges <-- structure including data on edge intersections
197 * vtx_equiv <-> structure dealing with vertex equivalences
198 *---------------------------------------------------------------------------*/
199
200void
202 cs_join_mesh_t *mesh,
203 const cs_join_edges_t *edges,
204 const cs_join_inter_edges_t *inter_edges,
205 cs_join_eset_t *vtx_equiv);
206
207#if defined(HAVE_MPI)
208
209/*----------------------------------------------------------------------------
210 * Synchronize the definition of intersections on each edge by block.
211 *
212 * parameters:
213 * edges <-- cs_join_edges_t structure
214 * mesh <-- cs_join_mesh_t structure
215 * part <-- structure storing data on edge intersections by partition
216 *
217 * returns:
218 * newly allocated cs_join_inter_edges_t, synchronized and defined on
219 * a block
220 *---------------------------------------------------------------------------*/
221
222cs_join_inter_edges_t *
223cs_join_inter_edges_part_to_block(const cs_join_mesh_t *mesh,
224 const cs_join_edges_t *edges,
225 const cs_join_inter_edges_t *part);
226
227/*----------------------------------------------------------------------------
228 * Synchronize the definition of intersections on each edge from a
229 * cs_join_inter_edges_t structure defined on a block.
230 *
231 * parameters:
232 * n_g_egdes <-- global number of edges
233 * block <-- synchronized cs_join_inter_edges_t struct. by block
234 * part <-> cs_join_inter_edges_t to synchronized on partition
235 *---------------------------------------------------------------------------*/
236
237void
238cs_join_inter_edges_block_to_part(cs_gnum_t n_g_edges,
239 const cs_join_inter_edges_t *block,
240 cs_join_inter_edges_t *part);
241
242#endif /* HAVE_MPI */
243
244/*----------------------------------------------------------------------------
245 * Redefine a cs_join_inter_edges_t structure to be consistent with the local
246 * numbering of a given couple of cs_join_mesh_t structure and
247 * cs_join_edges_t structure.
248 * Add future new vertices for the face definition in cs_join_mesh_t
249 *
250 * parameters:
251 * verbosity <-- verbosity level
252 * edges <-- cs_join_edges_t structure
253 * mesh <-> cs_join_mesh_t structure
254 * inter_edges <-> current cs_join_inter_edges_t struct. to work with
255 *---------------------------------------------------------------------------*/
256
257void
259 const cs_join_edges_t *edges,
260 cs_join_mesh_t *mesh,
261 cs_join_inter_edges_t **inter_edges);
262
263/*----------------------------------------------------------------------------
264 * Get all real edges intersections among possible edges intersections.
265 *
266 * parameters:
267 * param <-- set of user-defined parameters for the joining
268 * edge_edge_vis <-- a pointer to a cs_join_gset_t structure
269 * edges <-- pointer to a structure defining edges
270 * mesh <-- pointer to the cs_join_mesh_t structure
271 * which has the face connectivity
272 * inter_set <-> pointer to a structure including data on edge
273 * intersections
274 * vtx_eset <-> pointer to a structure dealing with vertex
275 * equivalences
276 *
277 * returns:
278 * the type of joining encountered (conforming or not)
279 *---------------------------------------------------------------------------*/
280
283 const cs_join_gset_t *edge_edge_vis,
284 const cs_join_edges_t *edges,
285 const cs_join_mesh_t *mesh,
286 cs_join_eset_t **vtx_eset,
287 cs_join_inter_set_t **inter_set);
288
289/*----------------------------------------------------------------------------
290 * Build a tree structure on which we associate leaves and face bounding boxes.
291 * Create a cs_join_gset_t structure (indexed list on global numbering)
292 * storing potential intersections between face bounding boxes.
293 *
294 * parameters:
295 * param <-- set of user-defined parameters
296 * join_mesh <-- cs_join_mesh_t structure where faces are defined
297 * stats <-> joining statistics
298 *
299 * returns:
300 * a new allocated pointer to a cs_join_gset_t structure storing the
301 * face - face visibility.
302 *---------------------------------------------------------------------------*/
303
304cs_join_gset_t *
306 const cs_join_mesh_t *join_mesh,
307 cs_join_stats_t *stats);
308
309/*----------------------------------------------------------------------------
310 * Transform face visibility into edge visibility.
311 *
312 * parameters:
313 * mesh <-- pointer to a cs_join_mesh_t structure
314 * edges <-- pointer to a cs_join_edges_t structure
315 * face_visib <-- pointer to a cs_join_gset_t structure
316 *
317 * returns:
318 * a new allocated cs_join_gset_t structure holding edge visibility
319 *---------------------------------------------------------------------------*/
320
321cs_join_gset_t *
322cs_join_intersect_face_to_edge(const cs_join_mesh_t *mesh,
323 const cs_join_edges_t *edges,
324 const cs_join_gset_t *face_visib);
325
326/*----------------------------------------------------------------------------
327 * Dump a cs_join_inter_edges_t structure.
328 *
329 * parameters:
330 * f <-- handle to output file
331 * inter_edges <-- cs_join_inter_edges_t structure to dump
332 * edges <-- list of edges
333 * mesh <-- associated cs_join_mesh_t structure
334 *---------------------------------------------------------------------------*/
335
336void
338 const cs_join_inter_edges_t *inter_edges,
339 const cs_join_edges_t *edges,
340 const cs_join_mesh_t *mesh);
341
342/*---------------------------------------------------------------------------*/
343
345
346#endif /* __CS_JOIN_INTERSECT_H__ */
Definition cs_defs.h:542
double cs_coord_t
Definition cs_defs.h:340
unsigned cs_gnum_t
global mesh entity number
Definition cs_defs.h:327
Definition cs_defs.h:543
Definition cs_defs.h:335
void cs_join_intersect_update_struct(int verbosity, const cs_join_edges_t *edges, cs_join_mesh_t *mesh, cs_join_inter_edges_t **inter_edges)
Definition cs_join_intersect.cpp:3235
cs_join_inter_edges_t * cs_join_inter_edges_create(cs_lnum_t n_edges)
Definition cs_join_intersect.cpp:2374
void cs_join_add_equiv_from_edges(cs_join_param_t param, cs_join_mesh_t *mesh, const cs_join_edges_t *edges, const cs_join_inter_edges_t *inter_edges, cs_join_eset_t *vtx_equiv)
Definition cs_join_intersect.cpp:2604
void cs_join_inter_edges_dump(FILE *f, const cs_join_inter_edges_t *inter_edges, const cs_join_edges_t *edges, const cs_join_mesh_t *mesh)
Definition cs_join_intersect.cpp:3997
cs_join_inter_set_t * cs_join_inter_set_create(cs_lnum_t init_size)
Definition cs_join_intersect.cpp:2280
void cs_join_inter_edges_destroy(cs_join_inter_edges_t **inter_edges)
Definition cs_join_intersect.cpp:2573
cs_join_gset_t * cs_join_intersect_faces(const cs_join_param_t param, const cs_join_mesh_t *join_mesh, cs_join_stats_t *stats)
Definition cs_join_intersect.cpp:3674
cs_join_gset_t * cs_join_intersect_face_to_edge(const cs_join_mesh_t *mesh, const cs_join_edges_t *edges, const cs_join_gset_t *face_visib)
Definition cs_join_intersect.cpp:3787
void cs_join_inter_set_destroy(cs_join_inter_set_t **inter_set)
Definition cs_join_intersect.cpp:2302
cs_join_type_t cs_join_intersect_edges(cs_join_param_t param, const cs_join_gset_t *edge_edge_vis, const cs_join_edges_t *edges, const cs_join_mesh_t *mesh, cs_join_eset_t **vtx_eset, cs_join_inter_set_t **inter_set)
Definition cs_join_intersect.cpp:3445
cs_join_inter_edges_t * cs_join_inter_edges_define(const cs_join_edges_t *edges, const cs_join_inter_set_t *inter_set)
Definition cs_join_intersect.cpp:2418
void cs_join_inter_set_dump(FILE *f, const cs_join_inter_set_t *i_set, const cs_join_edges_t *edges, const cs_join_mesh_t *mesh)
Definition cs_join_intersect.cpp:2323
cs_join_type_t
Definition cs_join_util.h:55
Definition mesh.f90:26
Definition cs_join_util.h:115
Definition cs_join_util.h:79
