1#ifndef __CS_HHO_STOKES_H__
2#define __CS_HHO_STOKES_H__
59typedef struct _cs_hho_stokes_t cs_hho_stokes_t;
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
unsigned short int cs_flag_t
Definition cs_defs.h:344
double * cs_hho_stokes_get_face_values(const void *data)
Get the computed values at faces (DoF used in the linear system are located at primal faces)
Definition cs_hho_stokes.cpp:752
void cs_hho_stokes_update_field(const cs_real_t *solu, const cs_real_t *rhs, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_real_t *field_val)
Store solution(s) of the linear system into a field structure Update extra-field values required for ...
Definition cs_hho_stokes.cpp:711
void cs_hho_stokes_initialize_system(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_matrix_t **system_matrix, cs_real_t **system_rhs)
Create the matrix of the current algebraic system. Allocate and initialize the right-hand side associ...
void * cs_hho_stokes_free_context(void *data)
Destroy a cs_hho_stokes_t structure.
Definition cs_hho_stokes.cpp:585
void cs_hho_stokes_compute_source(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data)
Compute the contributions of source terms (store inside builder)
Definition cs_hho_stokes.cpp:618
void cs_hho_stokes_build_system(const cs_mesh_t *mesh, const cs_real_t *field_val, double dt_cur, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data)
Build the linear system arising from a scalar convection/diffusion equation with a HHO scheme....
Definition cs_hho_stokes.cpp:656
void cs_hho_stokes_get(cs_cell_sys_t **csys, cs_cell_builder_t **cb, cs_hho_builder_t **hhob)
Definition cs_hho_stokes.cpp:406
void cs_hho_stokes_finalize(void)
Free buffers and generic structures related to HHO schemes.
Definition cs_hho_stokes.cpp:424
double * cs_hho_stokes_get_cell_values(const void *data)
Get the computed values at cells (DoF used in the linear system are located at primal faces)
Definition cs_hho_stokes.cpp:774
void cs_hho_stokes_initialize(cs_flag_t scheme_flag, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step, const cs_matrix_assembler_t *ma0, const cs_matrix_assembler_t *ma1, const cs_matrix_assembler_t *ma2, const cs_matrix_structure_t *ms0, const cs_matrix_structure_t *ms1, const cs_matrix_structure_t *ms2)
Allocate work buffer and general structures related to HHO schemes Set shared pointers.
Definition cs_hho_stokes.cpp:292
void * cs_hho_stokes_init_context(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb)
Initialize a cs_hho_stokes_t structure storing data useful for managing such a scheme.
Definition cs_hho_stokes.cpp:461
void cs_hho_stokes_extra_op(const char *eqname, const cs_field_t *field, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data)
Definition cs_hho_stokes.cpp:797
struct _cs_matrix_structure_t cs_matrix_structure_t
Definition cs_matrix.h:106
Definition cs_matrix.h:110
Definition cs_matrix_assembler.h:61
Definition cs_cdo_connect.h:61
Definition cs_cdo_quantities.h:145
Definition cs_cdo_local.h:60
Definition cs_cdo_local.h:146
Definition cs_equation_param.h:193
Definition cs_field.h:158
Definition cs_hho_builder.h:54
time step descriptor
Definition cs_time_step.h:64
