◆ cs_gui_boundary_add_meg_context()
Add new MEG-based cs_dof_func_t context info.
- Parameters
| [in] | zone | pointer to associated zone |
| [in] | name | name of associated field or array |
| [in] | condition | associated condition type |
| [in] | dim | associated dimension |
- Returns
- : pointer to cs_dof_func_t context info
◆ cs_gui_boundary_conditions_define()
Define boundary conditions based on setup file.
- Parameters
| [in,out] | bdy | boundaries structure to update (if NULL, default to cs_glob_domain->boundaries) |
◆ cs_gui_boundary_conditions_dof_func_meg()
cs_dof_func_t function to compute a boundary profiles using a MEG generated function.
For the calling function, elt_ids is optional. If non-null, array(s) should be accessed with an indirection. The same indirection can be applied to fill retval if dense_output is set to false. In the current case, retval is allocated to mesh->n_b_faces
- Parameters
| [in,out] | retval | resulting value(s). Must be allocated. |
- Parameters
◆ cs_gui_boundary_conditions_free_memory()
| void cs_gui_boundary_conditions_free_memory |
void | | ) |
Free GUI boundary condition structures.
◆ cs_gui_boundary_conditions_processing()
| void cs_gui_boundary_conditions_processing |
int * | itypfb | ) |
◆ cs_gui_boundary_conditions_verify()
| void cs_gui_boundary_conditions_verify |
void | | ) |
