Combustion combustion model: setup data from input. More...
#include "base/cs_defs.h"#include <assert.h>#include <ctype.h>#include <stdarg.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft/bft_mem.h"#include "bft/bft_printf.h"#include "base/cs_assert.h"#include "base/cs_field.h"#include "base/cs_file.h"#include "base/cs_log.h"#include "base/cs_math.h"#include "base/cs_parall.h"#include "base/cs_physical_constants.h"#include "base/cs_prototypes.h"#include "gui/cs_gui_specific_physics.h"#include "pprt/cs_physical_model.h"#include "pprt/cs_combustion_model.h"#include "cogz/cs_combustion_gas.h"#include "cogz/cs_combustion_bsh.h"#include "cogz/cs_combustion_ht_convert.h"#include "cogz/cs_combustion_read_data.h"Functions | |
| static void | _next_line (const char *name, int &line_num, char *&s, char *last, bool allow_end) |
| Point to next line in text buffer. | |
| static char * | _extract_token (const char *buffer_name, const char *token_name, char *&next, char *last, int line_num, int idx) |
| Extract i-th token from buffer. | |
| static void | _solve_ax_b_gauss (int n, double a[], double *restrict b, double *restrict x) |
| void | cs_combustion_read_data (void) |
| Read gas combustion thermochemistry data. | |
static |
A null-termination character is added to to end of the token unless the end of line has been reached, so the buffer values are modified. The pointer to the next portion of the string is set just after this null character.
| [in] | buffer_name | buffer name (for error logging) |
| [in] | token_name | token type name (for error logging) |
| [in,out] | next | pointer to next part of buffer |
| [in] | last | pointer to last byte of buffer |
| [in] | line_num | line number (for error logging) |
| [in] | idx | token index in line (for error logging) |
static |
| [in] | name | name of associated file (for error logging) |
| [in,out] | line_num | line number counter |
| [in,out] | start | any position in current line before line break in, pointer to start of line out |
| [in] | last | last possible position in buffer |
| [in] | allow_end | if true, return null if last position in buffer is reached; otherwise, this is considered a premature end |
| void cs_combustion_read_data | ( | void | ) |
Number of global reactions: we can only balance one reaction.
