| integer(c_int), pointer, save | cmtype |
| character(len=12) | namgas |
| double precision, pointer, save | pcigas |
| double precision, dimension(:,:), pointer, save | coefeg |
| double precision, dimension(:,:), pointer, save | compog |
| integer | nmaxf |
| integer | nmaxfm |
| integer | nmaxh |
| integer | nmaxhm |
| double precision, save | hstoea |
| double precision, dimension(nmaxhm), save | hh |
| double precision, dimension(nmaxfm), save | ff |
| double precision, dimension(nmaxfm, nmaxhm), save | tfh |
| real(c_double), pointer, save | tinfue |
| real(c_double), pointer, save | tinoxy |
| real(c_double), pointer, save | hinfue |
| real(c_double), pointer, save | hinoxy |
| integer(c_int), pointer, save | ngazfl |
| integer(c_int), pointer, save | nki |
| integer(c_int), pointer, save | nxr |
| integer(c_int), pointer, save | nzm |
| integer(c_int), pointer, save | nzvar |
| integer(c_int), pointer, save | nlibvar |
| integer(c_int), pointer, save | ikimid |
| integer(c_int), pointer, save | mode_fp2m |
| double precision, save | coef_k = 7.d-2 |
| integer, save | flamelet_zm |
| integer, save | flamelet_zvar |
| integer, save | flamelet_ki |
| integer, save | flamelet_xr |
| integer, save | flamelet_temp |
| integer, save | flamelet_rho |
| integer, save | flamelet_vis |
| integer, save | flamelet_dt |
| integer, save | flamelet_temp2 |
| integer, save | flamelet_hrr |
| integer, dimension(ngazgm), save | flamelet_species |
| integer, save | flamelet_c |
| integer, save | flamelet_omg_c |
| real(c_double), dimension(:,:,:,:,:), pointer, save | flamelet_library => null() |
| | Library for thermochemical properties in SLFM.
| double precision, dimension(:,:,:,:,:,:), allocatable | radiation_library |
| | Library for radiative properties in SLFM.
| real(c_double), pointer, save | frmel |
| real(c_double), pointer, save | tgf |
| real(c_double), pointer, save | cebu |
| integer | ndracm |
| integer(c_int), pointer, save | ndirac |
| integer, dimension(ndracm), save | irhol |
| integer, dimension(ndracm), save | iteml |
| integer, dimension(ndracm), save | ifmel |
| integer, dimension(ndracm), save | ifmal |
| integer, dimension(ndracm), save | iampl |
| integer, dimension(ndracm), save | itscl |
| integer, dimension(ndracm), save | imaml |
| integer, save | imam |
| real(c_double), pointer, save | vref |
| real(c_double), pointer, save | lref |
| real(c_double), pointer, save | ta |
| real(c_double), pointer, save | tstar |
| real(c_double), pointer, save | fmin |
| real(c_double), pointer, save | fmax |
| real(c_double), pointer, save | hmin |
| real(c_double), pointer, save | hmax |
| real(c_double), pointer, save | coeff1 |
| real(c_double), pointer, save | coeff2 |
| real(c_double), pointer, save | coeff3 |
| integer(c_int), pointer, save | isoot |
| real(c_double), pointer, save | xsoot |
| real(c_double), pointer, save | rosoot |
| real(c_double), pointer, save | lsp_fuel |
| logical(c_bool), pointer, save | use_janaf |
| | use JANAF or not
| integer, save | ifm = -1 |
| | id of mixing rate field
| integer, save | ifp2m = -1 |
| | id of mixing rate variance field
| integer, save | ifsqm = -1 |
| | id of field specifying the second moment of the mixing rate:
| integer, save | ipvm = -1 |
| | id of transported progress variable field (for ippmod(islfm) >= 2)
| integer, save | iygfm = -1 |
| | id of fresh gas mass fraction field
| integer, save | iyfm = -1 |
| | id of mass fraction field
| integer, save | iyfp2m = -1 |
| | id of mass fraction variance field
| integer, save | icoyfp = -1 |
| | id of mass fraction covariance field
| integer, dimension(ngazgm), save | iym |
| | mass fractions :
| integer, dimension(ngazgm), save | ibym |
| integer, save | itemp = -1 |
| | state variable (temperature)
| integer, save | ifmin |
| | state variable
| integer, save | ifmax |
| | state variable
| integer, save | irecvr = -1 |
| | state variable: Pointer to the reconstructed variance in case of mode_fp2m = 1
| integer, save | itotki = -1 |
| | state variable: Pointer to the total scalar dissipation rate
| integer, save | ihrr = -1 |
| | state variable: Pointer to volumetric heat release rate
| integer, save | ixr = -1 |
| | state variable: Pointer to defect enthalpy
| integer, save | iomgc = -1 |
| | state variable: Pointer to Omega C
| integer, save | ickabs = -1 |
| | state variable: absorption coefficient, when the radiation modelling is activated
| integer, save | it2m = -1 |
| | state variable: term
| integer, save | it3m = -1 |
| | state variable: term, when the radiation modelling is activated
| integer, save | it4m = -1 |
| integer, save | itsc = -1 |
| integer, save | inpm = -1 |
| | pointer for soot precursor number in isca (isoot = 1)
| integer, save | ifsm = -1 |
| | pointer for soot mass fraction in isca (isoot = 1)
| integer, parameter | n_z = 80 |
| | Burke Schumann combustion model constants.
| integer, parameter | n_xr = 5 |
| integer, parameter | n_zvar = 10 |
| integer, parameter | n_var_bsh = 7 |
| integer, parameter | nvar_turb = 10 |
Module for gas combustion.
