| integer, save | ifm = -1 |
| | id of mixing rate field
| integer, save | ifp2m = -1 |
| | id of mixing rate variance field
| integer, save | ifsqm = -1 |
| | id of field specifying the second moment of the mixing rate:
| integer, save | ipvm = -1 |
| | id of transported progress variable field (for ippmod(islfm) >= 2)
| integer, save | iygfm = -1 |
| | id of fresh gas mass fraction field
| integer, save | iyfm = -1 |
| | id of mass fraction field
| integer, save | iyfp2m = -1 |
| | id of mass fraction variance field
| integer, save | icoyfp = -1 |
| | id of mass fraction covariance field
| integer, dimension(ngazgm), save | iym |
| | mass fractions :
| integer, dimension(ngazgm), save | ibym |
| integer, save | itemp = -1 |
| | state variable (temperature)
| integer, save | ifmin |
| | state variable
| integer, save | ifmax |
| | state variable
| integer, save | irecvr = -1 |
| | state variable: Pointer to the reconstructed variance in case of mode_fp2m = 1
| integer, save | itotki = -1 |
| | state variable: Pointer to the total scalar dissipation rate
| integer, save | ihrr = -1 |
| | state variable: Pointer to volumetric heat release rate
| integer, save | ixr = -1 |
| | state variable: Pointer to defect enthalpy
| integer, save | iomgc = -1 |
| | state variable: Pointer to Omega C
| integer, save | ickabs = -1 |
| | state variable: absorption coefficient, when the radiation modelling is activated
| integer, save | it2m = -1 |
| | state variable: term
| integer, save | it3m = -1 |
| | state variable: term, when the radiation modelling is activated
| integer, save | it4m = -1 |
| integer, save | itsc = -1 |
| integer, save | inpm = -1 |
| | pointer for soot precursor number in isca (isoot = 1)
| integer, save | ifsm = -1 |
| | pointer for soot mass fraction in isca (isoot = 1)
| integer, parameter | n_z = 80 |
| | Burke Schumann combustion model constants.
| integer, parameter | n_xr = 5 |
| integer, parameter | n_zvar = 10 |
| integer, parameter | n_var_bsh = 7 |
| integer, parameter | nvar_turb = 10 |
