As usual, one can access any field using the field_get_val_s_by_name function. cvar_*(iel) is the value of this variable in cell number iel. ONLY done if there is no restart computation
The following local variables need to be defined for the examples in this section:
cs_coal_model_t * cs_glob_coal_model
Definition: cs_coal.cpp:96
#define CS_COMBUSTION_GAS_MAX_ELEMENTARY_COMPONENTS
Definition: cs_combustion_gas.h:59
Definition: cs_defs.h:342
Definition: cs_defs.h:335
Definition: cs_physical_constants.cpp:465
Fluid properties descriptor.
The following initialization block allows setting some variable values (variables not set here keep their GUI-defined or default values):
if (domain->time_step->nt_prev > 0)
return;
bft_printf(
"%s: settings for pulverized coal\n", __func__);
coefe[ige] = 0.;
const int ioxy = 0;
for (
cs_lnum_t cell_id = 0; cell_id < n_cells; cell_id++)
cvar_h[cell_id] = h1init;
for (
cvar_yco2[cell_id] =
xco2;
for (
cvar_nox[cell_id] = h1init;
Definition: bft_printf.cpp:140
cs_real_t cs_coal_ht_convert_h_to_t_gas_by_yi(cs_real_t eh, const cs_real_t xesp[])
Calculation of the gas temperature from gas enthalpy and given mass fractions for coal combustion.
Definition: cs_coal_ht_convert.cpp:524
Definition: cs_field.cpp:2489
@ h
Definition: cs_field_pointer.h:93
#define CS_F_(e)
real(c_double), pointer, save xco2
Molar coefficient of CO2.
Definition: ppthch.f90:149
integer(c_int), pointer, save ico2
Definition: cpincl.f90:105
integer(c_int), pointer, save in2
integer(c_int), pointer, save ih2o
integer(c_int), pointer, save io2
int ico2
Definition: cs_coal.h:385
int in2
Definition: cs_coal.h:384
int ih2o
Definition: cs_coal.h:383
double oxyo2[CS_COMBUSTION_COAL_MAX_OXYDANTS]
Definition: cs_coal.h:124
double oxyn2[CS_COMBUSTION_COAL_MAX_OXYDANTS]
Definition: cs_coal.h:127
double wmole[CS_COMBUSTION_COAL_MAX_ELEMENTARY_COMPONENTS]
Definition: cs_coal.h:118
int ieqco2
Definition: cs_coal.h:158
double oxyco2[CS_COMBUSTION_COAL_MAX_OXYDANTS]
Definition: cs_coal.h:133
int ieqnox
Definition: cs_coal.h:166
int io2
Definition: cs_coal.h:382
double oxyh2o[CS_COMBUSTION_COAL_MAX_OXYDANTS]
Definition: cs_coal.h:130
cs_real_t * val
Definition: cs_field.h:152
double t0
Definition: cs_physical_constants.h:82
