Basic example
Local variables to be added
Initialization
One can get any field using cs_field_by_name function (use cs_field_by_name_try if one is not sure the field exists). "scalar1" is the name related to the first user-defined scalar variable. f->val[cell_id] is the value of this variable in cell number cell_id.
ONLY done if there is no restart computation.
if (domain->time_step->nt_prev > 0)
return;
if (fld != nullptr) {
for (
cs_lnum_t cell_id = 0; cell_id < n_cells; cell_id++)
for (
cs_lnum_t c_id = 0; c_id < n_cells; c_id++) {
cvar_fm[c_id] = 25;
cvar_ygfm[c_id] = 25;
cvar_scalt[c_id] = 25;
Definition: cs_defs.h:342
Definition: cs_defs.h:335
Return a pointer to a field based on its name if present.
Definition: cs_field.cpp:2515
@ ygfm
Definition: cs_field_pointer.h:134
@ fm
Definition: cs_field_pointer.h:129
#define CS_F_(e)
cs_field_t * cs_thermal_model_field(void)
Definition: cs_thermal_model.cpp:216
Definition: cs_field.h:131
cs_real_t * val
Definition: cs_field.h:152
