| integer | nmodmx |
| | number of specific physics More...
| integer(c_int), dimension(:), pointer, save | ippmod |
| | global indicator for speciphic physics By default, all the indicators ippmod(i.....) are initialized to -1, which means that no specific physics is activated. More...
| integer | iphpar |
| | ippmod(iphpar) is a global indicator for the specific physics: More...
| integer | icod3p |
| | pointer for specific physics More...
| integer | islfm |
| | pointer to specify steady laminar flamelet approach More...
| integer | icoebu |
| | pointer to specify Eddy Break Up pre-mixed flame with indicator ippmod(icoebu) More...
| integer | icolwc |
| | pointer to specify Libby-Williams pre-mixed flame withy indicator ippmod(icolwc) More...
| integer | ieljou |
| | pointer to specify Joule effect module (Laplace forces not taken into account) with indicator ippmod(ieljou): More...
| integer | ielarc |
| | pointer to specify Electric arcs module (Joule effect and Laplace forces) with indicator ippmod(ielarc): More...
| integer | iccoal |
| | pointer to specify multi-coals and multi-classes pulverised coal combustion with indicator ippmod(iccoal). The number of different coals must be inferior or equal to ncharm = 3. The number of particle size classes nclpch(icha) for the coal icha, must be inferior or equal to ncpcmx = 10. More...
| integer | icompf |
| | pointer to specify compressible module with indicator ippmod(icompf) More...
| integer | iatmos |
| | pointer to specify atmospheric flow module with indicator ippmod(iatmos) More...
| integer | iaeros |
| | pointer to specify cooling towers module with indicator ippmod(iaeros) More...
| integer | igmix |
| | pointer to specify gas mixture module with indicator ippmod(igmix) More...
| integer(c_int), pointer, save | icondb |
| | Specific condensation modelling if = -1 module not activated if = 0 condensation source terms activated. More...
| integer(c_int), pointer, save | icondv |
| | Specific condensation modelling if = -1 module not activated if = 0 condensation source terms with metal structures activate. More...
| integer, save | ienerg |
| | specific total energy for compressible algorithm More...
| integer, save | itempk |
| | temperature deduced from the specific total energy More...
| real(c_double), pointer, save | viscv0 |
| | reference volume viscosity More...
| integer, save | ihm |
| | enthalpy, if transported or if deduced More...
| real(c_double), pointer, save | srrom |
| | sub-relaxation coefficient for the density More...
| integer(c_int), dimension(:), pointer, save | iqimp |
| | imposed flow zone indicator in a way which is similar to the process described in the framework of the EBU module, the user chooses for every inlet face to impose the mass flow or not (iqimp(izone)=1 or 0). If the mass flow is imposed, the user must set the air mass flow value qimp(izone) ant its direction in rcodcl(ifac,iu), rcodcl(ifac,iv) and rcodcl(ifac,iw). If the velocity is imposed, he has to set rcodcl(ifac,iu), rcodcl(ifac,iv), and rcodcl(ifac,iw). More...
| integer(c_int), dimension(:), pointer, save | icalke |
| | condition type turbulence indicator More...
| real(c_double), dimension(:), pointer, save | xintur |
| | turbulent intensity (k=1.5(uref*xintur)**2) More...
| real(c_double), dimension(:), pointer, save | dh |
| | hydraulic diameter More...
| integer, save | nozapm |
| | index of maximum reached boundary zone More...
| integer, save | nzfppp |
| | number of boundary zones on current process More...
| integer, dimension(nozppm), save | ilzppp |
| | list of boundary zones index More...
General module for specific physics.
