8.3
Indicator table for specific physics
+ Collaboration diagram for Indicator table for specific physics:
integer nmodmx
 number of specific physics More...
integer(c_int), dimension(:), pointer, save ippmod
 global indicator for speciphic physics By default, all the indicators ippmod(i.....) are initialized to -1, which means that no specific physics is activated. More...
integer iphpar
 ippmod(iphpar) is a global indicator for the specific physics: More...
integer icod3p
 pointer for specific physics More...
integer islfm
 pointer to specify steady laminar flamelet approach More...
integer icoebu
 pointer to specify Eddy Break Up pre-mixed flame with indicator ippmod(icoebu) More...
integer icolwc
 pointer to specify Libby-Williams pre-mixed flame withy indicator ippmod(icolwc) More...
integer ieljou
 pointer to specify Joule effect module (Laplace forces not taken into account) with indicator ippmod(ieljou): More...
integer ielarc
 pointer to specify Electric arcs module (Joule effect and Laplace forces) with indicator ippmod(ielarc): More...
integer iccoal
 pointer to specify multi-coals and multi-classes pulverised coal combustion with indicator ippmod(iccoal). The number of different coals must be inferior or equal to ncharm = 3. The number of particle size classes nclpch(icha) for the coal icha, must be inferior or equal to ncpcmx = 10. More...
integer icompf
 pointer to specify compressible module with indicator ippmod(icompf) More...
integer iatmos
 pointer to specify atmospheric flow module with indicator ippmod(iatmos) More...
integer iaeros
 pointer to specify cooling towers module with indicator ippmod(iaeros) More...
integer igmix
 pointer to specify gas mixture module with indicator ippmod(igmix) More...
◆ iaeros
integer iaeros
  • ippmod(iaeros) =-1 module not activated
  • ippmod(iaeros) >= 0 activated
◆ iatmos
integer iatmos
  • ippmod(iatmos) =-1 module not activated
  • ippmod(iatmos) = 0 standard modelling
  • ippmod(iatmos) = 1 dry atmosphere
  • ippmod(iatmos) = 2 humid atmosphere
◆ iccoal
integer iccoal
  • ippmod(iccoal) = 0 imbalance between the temperature of the continuous and the solid phases
  • ippmod(iccoal) = 1 otherwise
  • ippmod(iccoal) =-1 module not activated
◆ icod3p
integer icod3p
  • ippmod(icod3p) = 0 adiabatic conditions
  • ippmod(icod3p) = 1 permeatic conditions (enthalpy transport)
  • ippmod(icod3p) =-1 module not activated
◆ icoebu
integer icoebu
  • ippmod(icoebu) = 0 adiabatic conditions at constant richness
  • ippmod(icoebu) = 1 permeatic conditions at constant richness
  • ippmod(icoebu) = 2 adiabatic conditions at variable richness
  • ippmod(icoebu) = 3 permeatic conditions at variable richness
  • ippmod(icoebu) =-1 module not activated
◆ icolwc
integer icolwc
  • ippmod(icolwc)=0 two peak model with adiabiatic conditions.
  • ippmod(icolwc)=1 two peak model with permeatic conditions.
  • ippmod(icolwc)=2 three peak model with adiabiatic conditions.
  • ippmod(icolwc)=3 three peak model with permeatic conditions.
  • ippmod(icolwc)=4 four peak model with adiabiatic conditions.
  • ippmod(icolwc)=5 four peak model with permeatic conditions.
  • ippmod(icolwc)=-1 module not activated.
◆ icompf
integer icompf
  • ippmod(icompf) = 2 module activated: homogeneous two phase model
  • ippmod(icompf) = 1 module activated: single phase model
  • ippmod(icompf) = 0 module activated: single phase barotropic model
  • ippmod(icompf) =-1 module not activated
◆ ielarc
integer ielarc
  • ippmod(ielarc) = 1 determination of the magnetic field by means of the Ampere’ theorem (not available)
  • ippmod(ielarc) = 2 determination of the magnetic field by means of the vector potential
  • ippmod(ielarc) =-1 module not activated
◆ ieljou
integer ieljou
  • ippmod(ieljou) = 1 use of a real potential
  • ippmod(ieljou) = 2 use of a complex potential
  • ippmod(ieljou) = 3 use of real potential and specific boundary conditions for transformers.
  • ippmod(ieljou) = 4 use of complex potential and specific boundary conditions for transformers.
  • ippmod(ieljou) =-1 module not activated
◆ igmix
integer igmix
  • ippmod(igmix) =-1 module not activated
  • ippmod(igmix) = 0 Air/Helium gas mixtures
  • ippmod(igmix) = 1 Air/Hydrogen gas mixtures
  • ippmod(igmix) = 2 Air/Steam gas mixtures
  • ippmod(igmix) = 3 Air/Helium/Steam gas mixtures
  • ippmod(igmix) = 4 Air/Hydrogen/Steam gas mixtures
  • ippmod(igmix) = 5 Air/Helium with O2 from the air deduced
◆ iphpar
integer iphpar
  • 0: no specific physics
  • 1: switch on the specific physics
  • 2: switch on the specific physics plus radiative transfer with a parametric file
◆ ippmod
  • Diffusion flame in the framework of “3 points” rapid complete chemistry: indicator ippmod(icod3p)
  • Diffusion flames in the framework of steady laminar flamelet approach indicator ippmod(islfm)
    • ippmod(islfm) = 0 classic steady laminar flamelet model: adiabatic conditions
    • ippmod(islfm) = 1 classic steady laminar flamelet model: non-adiabatic conditions (enthalpy transport with heat loss)
    • ippmod(islfm) = 2 flamelet/progress variable model: adiabatic conditions
    • ippmod(islfm) = 3 flamelet/progress variable model: non-adiabatic conditions (enthalpy transport with heat loss)
    • ippmod(islfm) =-1 module not activated
Eddy Break Up pre-mixed flame: indicator ippmod(icoebu)
Libby-Williams pre-mixed flame: indicator ippmod(icolwc)
Multi-coals and multi-classes pulverised coal combustion: indicator ippmod(iccoal)
The number of different coals must be inferior or equal to ncharm = 5. The number of particle size classes nclpch(icha) for the coal icha, must be inferior or equal to ncpcmx = 20.
Electric arcs module (Joule effect and Laplace forces): indicator ippmod(ielarc)
Joule effect module (Laplace forces not taken into account): indicator ippmod(ieljou)
compressible flow module: indicator ippmod(icompf)
atmospheric flow module: indicator ippmod(iatmos)
◆ islfm
integer islfm
◆ nmodmx
integer nmodmx
