Data Types | |
| interface | boundary_conditions_mapped_set |
| Set mapped boundary conditions for a given field and mapping locator. More... | |
| interface | cs_boundary_conditions_legacy_turbulence |
| Define automatic turbulence values for specific physical modules. More... | |
| interface | cs_f_field_get_key_struct_var_cal_opt |
| interface | cs_f_field_set_key_struct_var_cal_opt |
| interface | cs_f_scalar_clipping |
| interface | cs_gas_combustion_h_to_t |
| Convert enthalpy to temperature for gas combustion. More... | |
| interface | cs_gas_combustion_t_to_h |
| Convert temperature to enthalpy for gas combustion. More... | |
| interface | cs_intprf |
| interface | cs_intprz |
| interface | cs_log_default_activate |
| interface | cs_log_default_is_active |
| interface | cs_set_type_order_turbulence_model |
| interface | cs_time_moment_is_active |
| Return if moment is active (1) or not (0). More... | |
| interface | cs_time_moment_n_moments |
| Return the number of temporal moments. More... | |
| interface | cs_turb_model_init |
| interface | csexit |
| interface | equation_param_from_vcopt |
| interface | les_filter |
| Compute filters for dynamic models. More... | |
| interface | time_moment_field_id |
| Get field id associated with a given moment. More... | |
| interface | timer_stats_set_plot |
| Enable or disable plotting for a timer statistic. More... | |
| interface | timer_stats_start |
| Start a timer for a given statistic. More... | |
| interface | timer_stats_switch |
| Start a timer for a given statistic, stopping previous timers of the same type which are not a parent, and starting inactive parent timers if necessary. More... | |
| interface | turbulence_bc_ke_turb_intensity |
| Calculation of | |
| interface | turbulence_bc_rij_transform |
| Compute matrix | |
| type | var_cal_opt |
| interface | yg2xye |
| Compute molar and mass fractions of elementary species Ye, Xe (fuel, O2, CO2, H2O, N2) from global species Yg (fuel, oxidant, products) More... | |
Functions/Subroutines | |
| subroutine | balance_by_zone (sel_crit, name) |
| Compute balance on a given zone for a given scalar. More... | |
| subroutine | intprf (nprofz, nproft, profz, proft, profv, xz, temps, var) |
| Temporal and z-axis interpolation for meteorological profiles. More... | |
| subroutine | intprz (nprofz, profz, profv, xz, iz1, iz2, var) |
| z-axis interpolation for meteorological profiles More... | |
| subroutine | pressure_drop_by_zone (sel_crit) |
| Compute pressure drop for a given zone. More... | |
| subroutine | surface_balance (sel_crit, name, normal) |
| Compute surface scalar balance for a given surface area. More... | |
| subroutine | boundary_conditions_error (bc_type) |
| Handle boundary condition definition errors and associated output. More... | |
| type(c_ptr) function | boundary_conditions_map (location_type, n_location_elts, n_faces, location_elts, faces, coord_shift, coord_stride, tolerance) |
| Locate shifted boundary face coordinates on possibly filtered cells or boundary faces for later interpolation. More... | |
| subroutine | field_set_key_struct_var_cal_opt (f_id, k_value) |
| Assign a var_cal_opt for a cs_var_cal_opt_t key to a field. More... | |
| subroutine | field_get_key_struct_var_cal_opt (f_id, k_value) |
| Return a pointer to the var_cal_opt structure for cs_var_cal_opt key associated with a field. More... | |
| subroutine | gradient_hn_s (f_id, imrgra, inc, nswrgp, imligp, iwarnp, epsrgp, climgp, pvar, grad) |
| Compute cell gradient for scalar with homegeneous gradient. More... | |
| subroutine | user_f_boundary_conditions (itypfb, izfppp, dt) |
| Wrapper to Fortran user boundary condition definitions. More... | |
| subroutine | user_f_initialization (dt) |
| Wrapper to Fortran user initialization definitions. More... | |
| subroutine | cs_f_usppmo () |
| Wrapper to Fortran user parameters, model choice. More... | |
| subroutine | cs_f_usipsu (nmodpp) |
| Wrapper to Fortran user parameters. More... | |
| subroutine | cs_f_usipes (nmodpp) |
| Wrapper to Fortran user parameters, additional parameters. More... | |
| subroutine | variable_field_create (name, label, location_id, dim, id) |
| Add field defining a general solved variable, with default options. More... | |
| double precision function | notebook_parameter_value_by_name (name) |
| Return notebook parameter value. More... | |
| subroutine | clpsca (iscal) |
| brief Clipping scalar field. More... | |
| integer | mesh_location_none |
| integer | mesh_location_cells |
| integer | mesh_location_interior_faces |
| integer | mesh_location_boundary_faces |
| integer | mesh_location_vertices |
| integer | mesh_location_particles |
| integer | mesh_location_other |
| integer | post_on_location |
| integer | post_boundary_nr |
| integer | post_monitor |
| integer | restart_val_type_int_t |
| integer | restart_val_type_real_t |
| integer | restart_disabled |
| integer | restart_main |
| integer | restart_auxiliary |
| integer | restart_rad_transfer |
| integer | restart_lagr |
| integer | restart_lagr_stat |
| integer | restart_1d_wall_thermal |
| integer | restart_les_inflow |
| integer | volume_zone_initialization |
| integer | volume_zone_porosity |
| integer | volume_zone_head_loss |
| integer | volume_zone_source_term |
| integer | volume_zone_mass_source_term |
| subroutine balance_by_zone | ( | character(len=*), intent(in) | sel_crit, |
| character(len=*), intent(in) | name | ||
param[in] sel_crit selection criteria of a volume zone param[in] name scalar name
| subroutine boundary_conditions_error | ( | integer(c_int), dimension(*), intent(in) | bc_type | ) |
For each boundary face, bc_type defines the boundary condition type. As a convention here, zero values correspond to undefined types, positive values to defined types (with no error), and negative values to defined types with inconsistent or incompatible values, the absolute value indicating the original boundary condition type. param[in] bc_type array og BC type ids
| type(c_ptr) function boundary_conditions_map | ( | integer, intent(in) | location_type, |
| integer, intent(in) | n_location_elts, | ||
| integer, intent(in) | n_faces, | ||
| integer, dimension(*), intent(in) | location_elts, | ||
| integer, dimension(*), intent(in) | faces, | ||
| real(kind=c_double), dimension(*) | coord_shift, | ||
| integer, intent(in) | coord_stride, | ||
| double precision, intent(in) | tolerance | ||
param[in] location_type matching values location (CS_MESH_LOCATION_CELLS or CS_MESH_LOCATION_BOUNDARY_FACES) param[in] n_location_elts number of selected location elements param[in] n_faces number of selected boundary faces param[in] location_elts list of selected location elements (1 to n), or NULL if no indirection is needed param[in] faces list of selected boundary faces (1 to n), or NULL if no indirection is needed param[in] coord_shift array of coordinates shift relative to selected boundary faces param[in] coord_stride access stride in coord_shift: 0 for uniform shift, 1 for "per face" shift. param[in] tolerance relative tolerance for point location. return associated locator structure
| subroutine clpsca | ( | integer, intent(in) | iscal | ) |
| subroutine cs_f_usipes | ( | integer(c_int) | nmodpp | ) |
| subroutine cs_f_usipsu | ( | integer(c_int) | nmodpp | ) |
| subroutine cs_f_usppmo |
| subroutine field_get_key_struct_var_cal_opt | ( | integer, intent(in) | f_id, |
| type(var_cal_opt), intent(out), target | k_value | ||
If the field category is not compatible, a fatal error is provoked.
| [in] | f_id | field id |
| [out] | k_value | integer value associated with key id for this field |
| subroutine field_set_key_struct_var_cal_opt | ( | integer, intent(in) | f_id, |
| type(var_cal_opt), intent(in), target | k_value | ||
| [in] | k_value | structure associated with key |
| subroutine gradient_hn_s | ( | integer, intent(in) | f_id, |
| integer, intent(in) | imrgra, | ||
| integer, intent(in) | inc, | ||
| integer, intent(in) | nswrgp, | ||
| integer, intent(in) | imligp, | ||
| integer, intent(in) | iwarnp, | ||
| double precision, intent(in) | epsrgp, | ||
| double precision, intent(in) | climgp, | ||
| real(kind=c_double), dimension(ncelet), intent(inout) | pvar, | ||
| real(kind=c_double), dimension(3, ncelet), intent(out) | grad | ||
| [in] | f_id | field id, or -1 |
| [in] | imrgra | gradient computation mode |
| [in] | inc | 0: increment; 1: do not increment |
| [in] | nswrgp | number of sweeps for reconstruction |
| [in] | imligp | gradient limitation method: < 0 no limitation = 0 based on neighboring gradients = 1 based on mean gradient |
| [in] | iwarnp | verbosity |
| [in] | epsrgp | relative precision for reconstruction |
| [in] | climgp | limiter coefficient for imligp |
| [in,out] | pvar | cell values whose gradient is computed |
| [out] | grad | resulting gradient |
| subroutine intprf | ( | integer(c_int), intent(in), value | nprofz, |
| integer(c_int), intent(in), value | nproft, | ||
| real(kind=c_double), dimension(nprofz), intent(in) | profz, | ||
| real(kind=c_double), dimension(nproft), intent(in) | proft, | ||
| real(kind=c_double), dimension(nprofz, nproft), intent(in) | profv, | ||
| real(kind=c_double), intent(in), value | xz, | ||
| real(kind=c_double), intent(in), value | temps, | ||
| real(kind=c_double), intent(out) | var | ||
An optimized linear interpolation is used.
| subroutine intprz | ( | integer(c_int), intent(in), value | nprofz, |
| real(kind=c_double), dimension(nprofz), intent(in) | profv, | ||
| integer(c_int), intent(out) | iz1, | ||
| integer(c_int), intent(out) | iz2, | ||
| double precision function notebook_parameter_value_by_name | ( | character(len=*), intent(in) | name | ) |
| [in] | name | name of the notebook parameter |
| subroutine pressure_drop_by_zone | ( | character(len=*), intent(in) | sel_crit | ) |
| subroutine surface_balance | ( | character(len=*), intent(in) | sel_crit, |
| character(len=*), intent(in) | name, | ||
| real(kind=c_double), dimension(3), intent(in) | normal | ||
| subroutine user_f_boundary_conditions | ( | integer(kind=c_int), dimension(*), intent(inout) | itypfb, |
| integer(kind=c_int), dimension(*), intent(inout) | izfppp, | ||
| real(c_double), dimension(*), intent(in) | dt | ||
| [in,out] | bc_type | boundary face types |
| subroutine user_f_initialization | ( | real(c_double), dimension(*), intent(in) | dt | ) |
| subroutine variable_field_create | ( | character(len=*), intent(in) | name, |
| character(len=*), intent(in) | label, | ||
| integer, intent(in) | location_id, | ||
| integer, intent(in) | dim, | ||
| integer, intent(out) | id | ||
| [in] | name | field name |
| [in] | label | field default label, or empty |
| [in] | location_id | field location type: 0: none 1: cells 2: interior faces 3: interior faces 4: vertices |
| [in] | dim | field dimension |
| [out] | id | id of defined field |
| integer mesh_location_boundary_faces |
| integer mesh_location_cells |
| integer mesh_location_interior_faces |
| integer mesh_location_none |
| integer mesh_location_other |
| integer mesh_location_particles |
| integer mesh_location_vertices |
| integer post_boundary_nr |
| integer post_monitor |
| integer post_on_location |
| integer restart_1d_wall_thermal |
| integer restart_auxiliary |
| integer restart_disabled |
| integer restart_lagr |
| integer restart_lagr_stat |
| integer restart_les_inflow |
| integer restart_main |
| integer restart_rad_transfer |
| integer restart_val_type_int_t |
| integer restart_val_type_real_t |
| integer volume_zone_head_loss |
| integer volume_zone_initialization |
| integer volume_zone_mass_source_term |
| integer volume_zone_porosity |
| integer volume_zone_source_term |
