Additional right-hand side source terms for scalar equations (user scalars and specific physics scalars) with the cs_user_source_terms user-defined function.
Local variables and initialization
Definition: cs_defs.h:342
Definition: cs_defs.h:335
Definition: cs_field.cpp:2465
double precision, dimension(:), pointer cell_f_vol
fluid volume of each cell
Definition: mesh.f90:104
Definition: cs_field.h:131
cs_real_t * cell_vol
Definition: cs_mesh_quantities.h:97
cs_lnum_t n_cells
Definition: cs_mesh.h:97
Only apply to thermal scalar
return;
cs_field_t * cs_thermal_model_field(void)
Definition: cs_thermal_model.cpp:216
Function body
Map required fields
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:359
@ vel
#define CS_F_(e)
Compute bulk mean velocity
#define CS_REAL_TYPE
Definition: cs_defs.h:486
static void cs_parall_sum(int n, cs_datatype_t datatype, void *val)
Sum values of a given datatype on all default communicator processes.
Definition: cs_parall.h:147
cs_real_t tot_vol
Definition: cs_mesh_quantities.h:150
Compute source terms; we want to impose a total flux of 1 Watt.
st_imp[i] = 0.;
st_exp[i] =
cell_f_vol[i] * cvar_vel[i][0] * tot_flux / ubulk;
