8.3
Scalar balance on full domain
This is an example of cs_user_extra_operations which performs a scalar balance on the full computational domain. It is possible to customize the output to extract the contribution of some boundary zones of interest.
Define local variables
cs_lnum_t n_faces;
cs_lnum_t *face_list;
cs_lnum_t cell_id, cell_id1, cell_id2, face_id;
int nt_cur = domain->time_step->nt_cur;
const cs_mesh_t *m = domain->mesh;
const cs_mesh_quantities_t *mq = domain->mesh_quantities;
const cs_lnum_t n_cells = m->n_cells;
const cs_lnum_t n_cells_ext = m->n_cells_with_ghosts;
const cs_lnum_t n_i_faces = m->n_i_faces;
const cs_lnum_t n_b_faces = m->n_b_faces;
const cs_lnum_2_t *i_face_cells = m->i_face_cells;
const cs_lnum_t *b_face_cells = m->b_face_cells;
const cs_real_t *cell_vol = mq->cell_vol;
const cs_rreal_3_t *diipb = mq->diipb;
const cs_real_t *b_face_surf = mq->b_face_surf;
Definition: cs_defs.h:342
cs_rreal_t cs_rreal_3_t[3]
Definition: cs_defs.h:388
cs_lnum_t cs_lnum_2_t[2]
Definition: cs_defs.h:352
Definition: cs_defs.h:335
double precision, dimension(:,:), pointer diipb
vector II' for interior faces for every boundary face, the three components of the vector ....
Definition: mesh.f90:160
cs_rreal_3_t * diipb
Definition: cs_mesh_quantities.h:132
cs_real_t * b_face_surf
Definition: cs_mesh_quantities.h:119
cs_real_t * cell_vol
Definition: cs_mesh_quantities.h:97
Definition: cs_mesh.h:85
cs_lnum_t * b_face_cells
Definition: cs_mesh.h:112
cs_lnum_t n_i_faces
Definition: cs_mesh.h:98
cs_lnum_t n_b_faces
Definition: cs_mesh.h:99
cs_lnum_t n_cells_with_ghosts
Definition: cs_mesh.h:151
cs_lnum_t n_cells
Definition: cs_mesh.h:97
cs_lnum_2_t * i_face_cells
Definition: cs_mesh.h:111
Get the physical fields
cs_lnum_t n_faces;
Initialization step
double vol_balance = 0.;
double div_balance = 0.;
double a_wall_balance = 0.;
double h_wall_balance = 0.;
double sym_balance = 0.;
double in_balance = 0.;
double out_balance = 0.;
double mass_i_balance = 0.;
double mass_o_balance = 0.;
double tot_balance = 0.;
/* If the scalar enthalpy is not computed, return */
if (h == nullptr)
return;
/* Boundary condition coefficient for h */
const cs_real_t *a_H = h->bc_coeffs->a;
const cs_real_t *b_H = h->bc_coeffs->b;
const cs_real_t *af_H = h->bc_coeffs->af;
const cs_real_t *bf_H = h->bc_coeffs->bf;
/* Convective mass fluxes for inner and boundary faces */
int iflmas = cs_field_get_key_int(h, cs_field_key_id("inner_mass_flux_id"));
const cs_real_t *i_mass_flux = cs_field_by_id(iflmas)->val;
int iflmab = cs_field_get_key_int(h, cs_field_key_id("boundary_mass_flux_id"));
const cs_real_t *b_mass_flux = cs_field_by_id(iflmab)->val;
/* Allocate temporary array */
cs_real_t *h_reconstructed;
BFT_MALLOC(h_reconstructed, n_b_faces, cs_real_t);
/* Reconstructed value */
if (false) {
cs_real_3_t *grad;
BFT_MALLOC(grad, n_cells_ext, cs_real_3_t);
true, /* use_previous_t */
1, /* inc */
grad);
for (face_id = 0; face_id < n_b_faces; face_id++) {
cell_id = b_face_cells[face_id]; // associated boundary cell
h_reconstructed[face_id] = h->val[cell_id]
+ grad[cell_id][0]*diipb[face_id][0]
+ grad[cell_id][1]*diipb[face_id][1]
+ grad[cell_id][2]*diipb[face_id][2];
BFT_FREE(grad);
/* Non-reconstructed value */
} else {
h_reconstructed[face_id] = h->val[cell_id];
#define BFT_FREE(_ptr)
Definition: bft_mem.h:90
Definition: bft_mem.h:58
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:359
Definition: cs_field.cpp:3275
Definition: cs_field.cpp:2465
Definition: cs_field.cpp:2781
void cs_field_gradient_scalar(const cs_field_t *f, bool use_previous_t, int inc, cs_real_3_t *restrict grad)
Compute cell gradient of scalar field or component of vector or tensor field.
Definition: cs_field_operator.cpp:470
@ h
Definition: cs_field_pointer.h:93
cs_real_t * val
Definition: cs_field.h:152
Computation step
--> Balance on interior volumes
for (cell_id = 0; cell_id < n_cells; cell_id++) {
vol_balance += cell_vol[cell_id] * rho[cell_id]
* (h->val_pre[cell_id] - h->val[cell_id]);
--> Balance on all faces (interior and boundary), for div(rho u)
for (face_id = 0; face_id < n_i_faces; face_id++) {
cell_id1 = i_face_cells[face_id][0]; // associated boundary cell
cell_id2 = i_face_cells[face_id][1]; // associated boundary cell
/* Contribution to flux from the two cells of the current face
(The cell is count only once in parallel by checking that
the cell_id is not in the halo) */
if (cell_id1 < n_cells)
div_balance += i_mass_flux[face_id] * dt[cell_id1] * h->val[cell_id1];
if (cell_id2 < n_cells)
div_balance -= i_mass_flux[face_id] * dt[cell_id2] * h->val[cell_id2];
/* Contribution to flux from the current face */
div_balance += b_mass_flux[face_id] * dt[cell_id] * h->val[cell_id];
// TODO mass source terms and mass accumulation term
// In case of a mass source term, add contribution from Gamma*Tn+1
--> Balance on boundary faces
We handle different types of boundary faces separately to better
analyze the information, but this is not mandatory. */
Compute the contribution from walls with colors 2, 3, 4 and 7
(adiabatic here, so flux should be 0)
BFT_MALLOC(face_list, n_b_faces, cs_lnum_t);
cs_selector_get_b_face_list("2 or 3 or 4 or 7", &n_faces, face_list);
for (cs_lnum_t i = 0; i < n_faces; i++) {
face_id = face_list[i];
(diffusion and convection flux, negative if incoming) */
a_wall_balance += - b_face_surf[face_id] * dt[cell_id]
* (af_H[face_id] + bf_H[face_id] * h_reconstructed[face_id])
- b_mass_flux[face_id] * dt[cell_id]
* (a_H[face_id] + b_H[face_id] * h_reconstructed[face_id]);
Contribution from walls with color 6
(here at fixed enthalpy; the convective flux should be 0)
cs_selector_get_b_face_list("6", &n_faces, face_list);
h_wall_balance += - b_face_surf[face_id] * dt[cell_id]
Contribution from symmetries (should be 0).
cs_selector_get_b_face_list("8 or 9", &n_faces, face_list);
sym_balance += - b_face_surf[face_id] * dt[cell_id]
Contribution from inlet (color 1, diffusion and convection flux)
cs_selector_get_b_face_list("1", &n_faces, face_list);
in_balance += - b_face_surf[face_id] * dt[cell_id]
Contribution from outlet (color 5, diffusion and convection flux)
cs_selector_get_b_face_list("5", &n_faces, face_list);
out_balance += - b_face_surf[face_id] * dt[cell_id]
/* Free memory */
BFT_FREE(face_list);
BFT_FREE(h_reconstructed);
/* Sum of values on all ranks (parallel calculations) */
double b_tot[9] = {
vol_balance, div_balance, a_wall_balance, h_wall_balance,
sym_balance, in_balance, out_balance, mass_i_balance, mass_o_balance
vol_balance = b_tot[0], div_balance = b_tot[1];
a_wall_balance = b_tot[2], h_wall_balance = b_tot[3];
sym_balance = b_tot[4], in_balance = b_tot[5], out_balance = b_tot[6];
mass_i_balance = b_tot[7], mass_o_balance = b_tot[8];
/* Total balance
/* We add the different contributions calculated above */
tot_balance = vol_balance + div_balance + a_wall_balance + h_wall_balance
+ sym_balance + in_balance + out_balance + mass_i_balance
+ mass_o_balance;
@ CS_DOUBLE
Definition: cs_defs.h:305
@ rho
Definition: cs_field_pointer.h:99
@ dt
static void cs_parall_sum(int n, cs_datatype_t datatype, void *val)
Sum values of a given datatype on all default communicator processes.
Definition: cs_parall.h:147
void cs_selector_get_b_face_list(const char *criteria, cs_lnum_t *n_b_faces, cs_lnum_t b_face_list[])
Fill a list of boundary faces verifying a given selection criteria.
Definition: cs_selector.cpp:213
Write the balance at time step n
/* Free memory */
double b_tot[9] = {
/* Total balance
+ mass_o_balance;
