1#ifndef __CS_CDO_SCHEME_GEOMETRY_H__
2#define __CS_CDO_SCHEME_GEOMETRY_H__
99 grd_c[0] = ohf *
fm->face.unitv[0];
100 grd_c[1] = ohf *
fm->face.unitv[1];
101 grd_c[2] = ohf *
fm->face.unitv[2];
121 const short int *f2e_idx = cm->
f2e_idx + f;
122 const double *tef_vals = cm->
tef + f2e_idx[0];
123 const double inv_f = 1./cm->
face[f].
meas;
127 for (
short int e = 0; e < f2e_idx[1] - f2e_idx[0]; e++)
128 wef[e] = tef_vals[e] * inv_f;
150 const short int *f2e_idx = cm->
f2e_idx + f;
151 const double *tef_vals = cm->
tef + f2e_idx[0];
156 for (
157 pefc[e] = tef_vals[e] * f_coef;
185 const short int *f2e_idx = cm->
f2e_idx + f;
186 const short int *f2e_ids = cm->
f2e_ids + f2e_idx[0];
187 const double *tef_vals = cm->
tef + f2e_idx[0];
188 const double inv_f = 1./cm->
face[f].
meas;
192 for (
short int e = 0; e < f2e_idx[1] - f2e_idx[0]; e++) {
194 const short int *
v = cm->
e2v_ids + 2*f2e_ids[e];
195 const double w = 0.5*tef_vals[e] * inv_f;
Definition: cs_defs.h:542
Definition: cs_defs.h:342
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:359
Definition: cs_defs.h:543
@ fm
Definition: cs_field_pointer.h:129
static bool cs_eflag_test(cs_eflag_t flag_to_check, cs_eflag_t reference)
Check if a two compute flag share the same pattern Return true if the computed flag to check has at l...
Definition: cs_flag.h:383
@ CS_FLAG_COMP_FEQ
Definition: cs_flag.h:251
@ CS_FLAG_COMP_HFQ
Definition: cs_flag.h:269
@ CS_FLAG_COMP_PFQ
Definition: cs_flag.h:235
@ CS_FLAG_COMP_EV
Definition: cs_flag.h:243
@ CS_FLAG_COMP_PFC
Definition: cs_flag.h:278
void cs_compute_inertia_tensor(const cs_cell_mesh_t *cm, const cs_real_t center[3], cs_real_t inertia[3][3])
Compute the inertial matrix of a cell with respect to the point called "center". This computation is ...
Definition: cs_scheme_geometry.cpp:307
void cs_compute_grd_ve(const short int v1, const short int v2, const cs_nvec3_t deq, const cs_real_3_t uvc[], const cs_real_t lvc[], cs_real_t *grd_v1, cs_real_t *grd_v2)
Compute the gradient of a Lagrange function related to primal vertices in a p_{ef,...
Definition: cs_scheme_geometry.cpp:413
static void cs_compute_pefc(short int f, const cs_cell_mesh_t *cm, cs_real_t *pefc)
Compute the volume related to each tetrahedron of base tef and apex x_c (there are as many tetrahedra...
Definition: cs_scheme_geometry.h:143
static void cs_compute_wvf(short int f, const cs_cell_mesh_t *cm, cs_real_t *wvf)
Compute for a face the weight related to each vertex w_{v,f} This weight is equal to |dc(v) cap f|/|f...
Definition: cs_scheme_geometry.h:174
void cs_compute_wef_wvf(short int f, const cs_cell_mesh_t *cm, cs_real_t *wvf, cs_real_t *wef)
Compute for a face the weight related to each vertex w_{v,f} and the weight related to each edge w_{v...
Definition: cs_scheme_geometry.cpp:461
static void cs_compute_grdfc_cw(short int f, const cs_cell_mesh_t *cm, cs_real_t *grd_c)
Compute the value of the constant gradient of the Lagrange function attached to xc in p_{f,...
Definition: cs_scheme_geometry.h:69
void cs_compute_face_covariance_tensor(const cs_cell_mesh_t *cm, short int f, const cs_nvec3_t ax, const cs_nvec3_t ay, const cs_real_t center[3], cs_real_t cov[3])
Definition: cs_scheme_geometry.cpp:235
static void cs_compute_wef(short int f, const cs_cell_mesh_t *cm, cs_real_t *wef)
Compute the weight wef = |tef|/|f|.
Definition: cs_scheme_geometry.h:115
static void cs_compute_grdfc_fw(const cs_face_mesh_t *fm, cs_real_t *grd_c)
Definition: cs_scheme_geometry.h:94
double precision, dimension(:,:,:), allocatable v
Definition: atimbr.f90:113
short int * e2v_ids
Definition: cs_cdo_local.h:251
cs_real_t * pvol_f
Definition: cs_cdo_local.h:247
short int n_vc
Definition: cs_cdo_local.h:223
double * hfc
Definition: cs_cdo_local.h:244
short int * f2e_idx
Definition: cs_cdo_local.h:260
cs_eflag_t flag
Definition: cs_cdo_local.h:205
short int * f2e_ids
Definition: cs_cdo_local.h:261
double * tef
Definition: cs_cdo_local.h:263
short int * f_sgn
Definition: cs_cdo_local.h:241
cs_quant_t * face
Definition: cs_cdo_local.h:245
Set of local quantities and connectivities related to a mesh face Structure used to get a better memo...
Definition: cs_cdo_local.h:280
Definition: cs_defs.h:400
double meas
Definition: cs_cdo_quantities.h:133
double unitv[3]
Definition: cs_cdo_quantities.h:134
