#include "cs_defs.h"#include <assert.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <limits.h>#include <math.h>#include "bft_error.h"#include "bft_mem.h"#include "bft_printf.h"#include "fvm_io_num.h"#include "cs_mesh_builder.h"#include "cs_mesh_connect.h"#include "cs_mesh_group.h"#include "cs_parall.h"#include "cs_sort.h"#include "cs_mesh_boundary.h"
Include dependency graph for cs_mesh_boundary.cpp:Functions | |
| void | cs_mesh_boundary_insert (cs_mesh_t *mesh, cs_lnum_t n_faces, cs_lnum_t face_id[]) |
| Insert boundary into the mesh. More... | |
| void | cs_mesh_boundary_insert_with_shared_vertices (cs_mesh_t *mesh, cs_lnum_t n_faces, cs_lnum_t face_id[]) |
| Insert boundary into the mesh, sharing vertices on both sides. More... | |
| void | cs_mesh_boundary_insert_separating_cells (cs_mesh_t *mesh, const char *group_name, cs_lnum_t n_cells, const cs_lnum_t cell_id[]) |
| Insert a boundary into the mesh between a given set of cells and the the others. More... | |
| void | cs_mesh_boundary_remove_periodicity (cs_mesh_t *mesh) |
| Remove periodicity information from a mesh. More... | |
This is done by transforming interior faces into boundary faces.
Note that the ids of selected faces are sorted by this function.
| [in,out] | mesh | pointer to mesh structure to modify |
| [in] | n_faces | number of selected (interior) faces |
| [in,out] | face_id | list of selected (interior) faces (0 to n-1) |
| void cs_mesh_boundary_insert_separating_cells | ( | cs_mesh_t * | mesh, |
| const char * | group_name, | ||
| cs_lnum_t | n_cells, | ||
| const cs_lnum_t | cell_id[] | ||
An optional group name may be assigned to newly created boundary faces.
Note that the list of selected faces is sorted by this function.
| [in] | group_name | group name to assign to newly created boundary faces, or nullptr |
| [in] | n_cells | number of separated cells |
| [in] | cell_id | separated cell ids |
| void cs_mesh_boundary_insert_with_shared_vertices | ( | cs_mesh_t * | mesh, |
| cs_lnum_t | n_faces, | ||
| cs_lnum_t | face_id[] | ||
This function should be used with caution, as sharing vertices may cause issues with vertex-based values, gradient extended neighborhoods, and some visualization operations.
| void cs_mesh_boundary_remove_periodicity | ( | cs_mesh_t * | mesh | ) |
Periodic interior faces are transformed into boundary faces.
