Include dependency graph for cs_lagr_event.h:Go to the source code of this file.
| struct | cs_lagr_event_attribute_map_t |
| struct | cs_lagr_event_set_t |
Macros | |
| #define | CS_EVENT_INFLOW (1 << 0) |
| #define | CS_EVENT_OUTFLOW (1 << 1) |
| #define | CS_EVENT_REBOUND (1 << 2) |
| #define | CS_EVENT_DEPOSITION (1 << 3) |
| #define | CS_EVENT_RESUSPENSION (1 << 4) |
| #define | CS_EVENT_ROLL_OFF (1 << 5) |
| #define | CS_EVENT_ROLL_ON (1 << 6) |
| #define | CS_EVENT_FOULING (1 << 7) |
Enumerations | |
| enum | cs_lagr_event_attribute_t { CS_LAGR_E_FLAG = CS_LAGR_N_ATTRIBUTES , CS_LAGR_E_CELL_ID , CS_LAGR_E_FACE_ID , CS_LAGR_E_VELOCITY , CS_LAGR_N_E_ATTRIBUTES } |
| void | cs_lagr_event_initialize (void) |
| Define event map based on defined options. More... | |
| void | cs_lagr_event_finalize (void) |
| Destroy event set map if it exists. More... | |
| const cs_lagr_event_attribute_map_t * | cs_lagr_event_get_attr_map (void) |
| Return const pointer to the main event attribute map structure. More... | |
| const char * | cs_lagr_event_get_attr_name (cs_lagr_event_attribute_t attr) |
| Return name associated with a given attribute. More... | |
| cs_lagr_event_set_t * | cs_lagr_event_set_create (void) |
| void | cs_lagr_event_set_destroy (cs_lagr_event_set_t **events) |
| void | cs_lagr_event_get_attr_info (const cs_lagr_event_set_t *events, cs_lagr_event_attribute_t attr, size_t *extents, size_t *size, ptrdiff_t *displ, cs_datatype_t *datatype, int *count) |
| Get data extents for a given event attribute. More... | |
| void | cs_lagr_event_attr_in_range (int attr) |
| Check if an event attribute is in a valid range. More... | |
| static void * | cs_lagr_events_attr (cs_lagr_event_set_t *event_set, cs_lnum_t event_id, int attr) |
| Get pointer to a current attribute of a given event in a set. More... | |
| static const void * | cs_lagr_events_attr_const (const cs_lagr_event_set_t *event_set, cs_lnum_t event_id, int attr) |
| Get const pointer to current attribute data of a given event in a set. More... | |
| static cs_lnum_t | cs_lagr_events_get_lnum (const cs_lagr_event_set_t *event_set, cs_lnum_t event_id, int attr) |
| Get attribute value of type cs_lnum_t of a given event in a set. More... | |
| static void | cs_lagr_events_set_lnum (cs_lagr_event_set_t *event_set, cs_lnum_t event_id, int attr, cs_lnum_t value) |
| Set attribute value of type cs_lnum_t of a given event in a set. More... | |
| static cs_real_t | cs_lagr_events_get_real (const cs_lagr_event_set_t *event_set, cs_lnum_t event_id, int attr) |
| Get attribute value of type cs_real_t of a given event in a set. More... | |
| static void | cs_lagr_events_set_real (cs_lagr_event_set_t *event_set, cs_lnum_t event_id, int attr, cs_real_t value) |
| Set attribute value of type cs_real_t of a given event in a set. More... | |
| void | cs_lagr_event_set_resize (cs_lagr_event_set_t *event_set, cs_lnum_t min_size) |
| void | cs_lagr_event_set_dump (const cs_lagr_event_set_t *events) |
| Dump a cs_lagr_event_set_t structure. More... | |
| void | cs_lagr_event_init_from_particle (cs_lagr_event_set_t *events, cs_lagr_particle_set_t *particles, cs_lnum_t event_id, cs_lnum_t particle_id) |
| cs_lagr_event_set_t * | cs_lagr_event_set_boundary_interaction (void) |
| #define CS_EVENT_DEPOSITION (1 << 3) |
deposistion event
| #define CS_EVENT_FOULING (1 << 7) |
fouling
| #define CS_EVENT_INFLOW (1 << 0) |
Flags specifying general event attributes
inflow event
| #define CS_EVENT_OUTFLOW (1 << 1) |
outflow event
| #define CS_EVENT_REBOUND (1 << 2) |
rebound on wall
| #define CS_EVENT_RESUSPENSION (1 << 4) |
resuspension event
| #define CS_EVENT_ROLL_OFF (1 << 5) |
roll off
| #define CS_EVENT_ROLL_ON (1 << 6) |
roll on
| void cs_lagr_event_attr_in_range | ( | int | attr | ) |
If this is not the case, a fatal error is provoked.
| [in] | attr | event attribute |
| void cs_lagr_event_finalize | ( | void | ) |
| void cs_lagr_event_get_attr_info | ( | const cs_lagr_event_set_t * | events, |
| cs_lagr_event_attribute_t | attr, | ||
| size_t * | extents, | ||
| size_t * | size, | ||
| ptrdiff_t * | displ, | ||
| cs_datatype_t * | datatype, | ||
| int * | count | ||
For attributes not currently present, the displacement and data size should be -1 and 0 respectively.
| [in] | events | associated event set |
| [out] | extents | size (in bytes) of event structure, or NULL |
| [out] | size | size (in bytes) of attribute in event structure, or NULL |
| [out] | displ | displacement (in bytes) in event structure, or NULL |
| [out] | datatype | datatype of associated attribute, or NULL |
| [out] | count | number of type values associated with attribute, or NULL |
| [out] | extents | size (in bytes) of event structure, or nullptr |
| [out] | size | size (in bytes) of attribute in event structure, or nullptr |
| [out] | displ | displacement (in bytes) in event structure, or nullptr |
| [out] | datatype | datatype of associated attribute, or nullptr |
| [out] | count | number of type values associated with attribute, or nullptr |
| const cs_lagr_event_attribute_map_t * cs_lagr_event_get_attr_map | ( | void | ) |
| const char * cs_lagr_event_get_attr_name | ( | cs_lagr_event_attribute_t | attr | ) |
| void cs_lagr_event_init_from_particle | ( | cs_lagr_event_set_t * | events, |
| cs_lagr_particle_set_t * | particles, | ||
| cs_lnum_t | event_id, | ||
| cs_lnum_t | particle_id | ||
| void cs_lagr_event_initialize | ( | void | ) |
This function should only be called after cs_lagr_particle_attr_initialize, as it may use elements from the main particle attributes map.
| cs_lagr_event_set_t * cs_lagr_event_set_boundary_interaction | ( | void | ) |
Return a cs_lagr_event_set_t structure for particle/boundary interactions.
The event set is created if not present yet.
This event set is automatically freed and destroyed at the end of the computation.
| cs_lagr_event_set_t * cs_lagr_event_set_create | ( | void | ) |
Create a cs_lagr_event_set_t structure.
| void cs_lagr_event_set_destroy | ( | cs_lagr_event_set_t ** | events | ) |
Destroy a cs_lagr_event_set_t structure.
| [in,out] | events | pointer to pointer to event set to destroy |
| void cs_lagr_event_set_dump | ( | const cs_lagr_event_set_t * | events | ) |
| [in] | events | cs_lagr_event_t structure to dump |
| [in] | events | cs_lagr_event_set_t structure to dump |
| void cs_lagr_event_set_resize | ( | cs_lagr_event_set_t * | event_set, |
| cs_lnum_t | min_size | ||
inlinestatic |
| [in] | event_set | pointer to event set |
| [in] | event_id | event id |
| [in] | attr | requested attribute id |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
| [in,out] | event_set | pointer to event set |
| [in] | value | value to assign |
inlinestatic |
