1#ifndef __CS_LAGR_PARTICLE_H__
2#define __CS_LAGR_PARTICLE_H__
52#define CS_LAGR_PART_TO_DELETE (1 << 0)
55#define CS_LAGR_PART_FIXED (1 << 1)
58#define CS_LAGR_PART_DEPOSITED (1 << 2)
61#define CS_LAGR_PART_ROLLING (1 << 3)
64#define CS_LAGR_PART_IMPOSED_MOTION (1 << 4)
69#define CS_LAGR_PART_DEPOSITION_FLAGS \
70 ( CS_LAGR_PART_TO_DELETE | CS_LAGR_PART_FIXED | CS_LAGR_PART_DEPOSITED \
71 | CS_LAGR_PART_ROLLING | CS_LAGR_PART_IMPOSED_MOTION)
417 assert(particle_set->
p_am->
count[0][attr] > 0);
419 return (
unsigned char *)particle_set->
p_buffer
437inline static const void *
442 assert(particle_set->
p_am->
469 assert(particle_set->
p_am->
count[time_id][attr] > 0);
473 + particle_set->
p_am->
displ[time_id][attr];
490inline static const void *
496 assert(particle_set->
p_am->
500 + particle_set->
p_am->
525 return (flag & mask);
575 flag = (flag | mask) - mask;
599 assert(particle_set->
p_am->
626 assert(particle_set->
p_am->
630 + particle_set->
p_am->
displ[time_id][attr]));
650 assert(particle_set->
p_am->
654 + particle_set->
p_am->
displ[0][attr])) = value;
677 assert(particle_set->
p_am->
681 + particle_set->
p_am->
displ[time_id][attr])) = value;
701 assert(particle_set->
p_am->
728 assert(particle_set->
p_am->
732 + particle_set->
p_am->
752 assert(particle_set->
p_am->
756 + particle_set->
p_am->
779 assert(particle_set->
p_am->
783 + particle_set->
p_am->
803 assert(particle_set->
p_am->
830 assert(particle_set->
p_am->
834 + particle_set->
p_am->
854 assert(particle_set->
p_am->
858 + particle_set->
p_am->
881 assert(particle_set->
p_am->
885 + particle_set->
p_am->
979 assert(attr_map->
981 return (
unsigned char *)particle + attr_map->
displ[0][attr];
996inline static const void *
1001 assert(attr_map->
1003 return (
const unsigned char *)particle + attr_map->
displ[0][attr];
1025 assert(attr_map->
1027 return (
1043inline static const void *
1049 assert(attr_map->
1051 return (
1052 + attr_map->
1072 assert(attr_map->
1074 return *((
const cs_lnum_t *)( (
1075 + attr_map->
displ[0][attr]));
1098 assert(attr_map->
1100 return *((
1101 + attr_map->
1121 assert(attr_map->
1123 *((
cs_lnum_t *)((
displ[0][attr]))
1147 assert(attr_map->
1149 *((
cs_lnum_t *)( (
1150 + attr_map->
1170 assert(attr_map->
1172 return *((
const cs_gnum_t *)( (
1173 + attr_map->
displ[0][attr]));
1196 assert(attr_map->
1198 return *((
1199 + attr_map->
1219 assert(attr_map->
1221 *((
cs_gnum_t *)((
displ[0][attr]))
1245 assert(attr_map->
1247 *((
cs_gnum_t *)( (
1248 + attr_map->
1268 assert(attr_map->
1270 return *((
const cs_real_t *)( (
1271 + attr_map->
displ[0][attr]));
1294 assert(attr_map->
1296 return *((
1297 + attr_map->
1317 assert(attr_map->
1319 *((
cs_real_t *)((
displ[0][attr]))
1343 assert(attr_map->
1345 *((
cs_real_t *)( (
1346 + attr_map->
1369 return (
cs_real_t *)( (
1393 return (
1496#if defined(__cplusplus)
1498template <
typename T>
1504 assert(particle_set->
p_am->
1506 return (T *)( particle_set->
p_buffer
1511template <
typename T>
1517 assert(particle_set->
p_am->
1519 return (
const T *)( particle_set->
p_buffer
1524template <
typename T>
1531 assert(particle_set->
p_am->
1533 return (T *)( particle_set->
p_buffer
1535 + particle_set->
p_am->
displ[time_id][attr]);
1538template <
typename T>
1545 assert(particle_set->
p_am->
1547 return (
p_buffer
1549 + particle_set->
p_am->
1552template <
typename T>
1558 assert(particle_set->
p_am->
1560 return *(T *)( particle_set->
p_buffer
1565template <
typename T>
1572 assert(particle_set->
p_am->
1576 + particle_set->
p_am->
displ[0][attr]) = value;
1579template <
typename T>
1586 assert(particle_set->
p_am->
1588 return *(T *)( particle_set->
p_buffer
1590 + particle_set->
p_am->
1593template <
typename T>
1601 assert(particle_set->
p_am->
1605 + particle_set->
p_am->
displ[time_id][attr]) = value;
1608template <
typename T>
1610cs_lagr_particle_attr_get_ptr(
void *particle,
1614 assert(attr_map->
1616 return (T *)((
displ[0][attr]);
1619template <
typename T>
1621cs_lagr_particle_attr_get_const_ptr(
const void *particle,
1625 assert(attr_map->
1627 return (
const T *)( (
1628 + attr_map->
displ[0][attr]);
1631template <
typename T>
1633cs_lagr_particle_attr_n_get_ptr(
void *particle,
1638 assert(attr_map->
1640 return (T *)((
1643template <
typename T>
1645cs_lagr_particle_attr_n_get_const_ptr(
1650 assert(attr_map->
1652 return (
const T *)( (
1653 + attr_map->
1656template <
typename T>
1658cs_lagr_particle_attr_get_val(
1662 assert(attr_map->
1664 return *((
const T *)( (
1665 + attr_map->
displ[0][attr]));
1668template <
typename T>
1670cs_lagr_particle_attr_set_val(
void *particle,
1675 assert(attr_map->
1677 *((T *)((
displ[0][attr]))
1681template <
typename T>
1683cs_lagr_particle_attr_n_get_val(
1688 assert(attr_map->
1690 return *((
const T *)( (
1691 + attr_map->
1694template <
typename T>
1696cs_lagr_particle_attr_n_set_val(
void *particle,
1702 assert(attr_map->
1704 *((T *)( (
1705 + attr_map->
cs_datatype_t
Definition: cs_defs.h:300
Definition: cs_defs.h:542
Definition: cs_defs.h:342
uint64_t cs_gnum_t
global mesh entity number
Definition: cs_defs.h:325
Definition: cs_defs.h:543
Definition: cs_defs.h:335
void cs_lagr_particle_attr_in_range(int attr)
Check if a particle attribute is in a valid range.
Definition: cs_lagr_particle.cpp:1177
unsigned long long cs_lagr_get_n_g_particles_max(void)
Get global maximum number of particles.
Definition: cs_lagr_particle.cpp:1263
cs_lagr_attribute_t
Definition: cs_lagr_particle.h:80
@ CS_LAGR_DEPO_TIME
Definition: cs_lagr_particle.h:143
@ CS_LAGR_QUATERNION
Definition: cs_lagr_particle.h:117
@ CS_LAGR_FLUID_TEMPERATURE
Definition: cs_lagr_particle.h:149
@ CS_LAGR_HEIGHT
Definition: cs_lagr_particle.h:141
@ CS_LAGR_FOULING_INDEX
Definition: cs_lagr_particle.h:129
@ CS_LAGR_COAL_DENSITY
Definition: cs_lagr_particle.h:162
@ CS_LAGR_MASS
Definition: cs_lagr_particle.h:93
@ CS_LAGR_PRED_VELOCITY
Definition: cs_lagr_particle.h:108
@ CS_LAGR_EMISSIVITY
Definition: cs_lagr_particle.h:166
@ CS_LAGR_AGGLO_CLASS_ID
Definition: cs_lagr_particle.h:173
@ CS_LAGR_NEIGHBOR_FACE_ID
Definition: cs_lagr_particle.h:127
@ CS_LAGR_PRED_VELOCITY_SEEN
Definition: cs_lagr_particle.h:109
@ CS_LAGR_CLUSTER_NB_PART
Definition: cs_lagr_particle.h:142
@ CS_LAGR_RADII
Definition: cs_lagr_particle.h:118
@ CS_LAGR_ORIENTATION
Definition: cs_lagr_particle.h:116
@ CS_LAGR_TR_TRUNCATE
Definition: cs_lagr_particle.h:100
@ CS_LAGR_USER
Definition: cs_lagr_particle.h:178
@ CS_LAGR_DISPLACEMENT_NORM
Definition: cs_lagr_particle.h:137
@ CS_LAGR_COAL_MASS
Definition: cs_lagr_particle.h:155
@ CS_LAGR_VELOCITY
Definition: cs_lagr_particle.h:97
@ CS_LAGR_BR_GAUSS
Definition: cs_lagr_particle.h:111
@ CS_LAGR_INTERF
Definition: cs_lagr_particle.h:126
@ CS_LAGR_MARKO_VALUE
Definition: cs_lagr_particle.h:128
@ CS_LAGR_COKE_MASS
Definition: cs_lagr_particle.h:156
@ CS_LAGR_CELL_ID
Definition: cs_lagr_particle.h:84
@ CS_LAGR_REBOUND_ID
Definition: cs_lagr_particle.h:87
@ CS_LAGR_TAUP_AUX
Definition: cs_lagr_particle.h:95
@ CS_LAGR_RESIDENCE_TIME
Definition: cs_lagr_particle.h:92
@ CS_LAGR_TURB_STATE_1
Definition: cs_lagr_particle.h:107
@ CS_LAGR_TEMPERATURE
Definition: cs_lagr_particle.h:148
@ CS_LAGR_TR_REPOSITION
Definition: cs_lagr_particle.h:101
@ CS_LAGR_CP
Definition: cs_lagr_particle.h:150
@ CS_LAGR_RANDOM_VALUE
Definition: cs_lagr_particle.h:89
@ CS_LAGR_SHAPE_PARAM
Definition: cs_lagr_particle.h:121
@ CS_LAGR_RANK_ID
Definition: cs_lagr_particle.h:85
@ CS_LAGR_COAL_ID
Definition: cs_lagr_particle.h:161
@ CS_LAGR_INITIAL_DIAMETER
Definition: cs_lagr_particle.h:159
@ CS_LAGR_ADHESION_FORCE
Definition: cs_lagr_particle.h:135
@ CS_LAGR_STAT_WEIGHT
Definition: cs_lagr_particle.h:91
@ CS_LAGR_N_SMALL_ASPERITIES
Definition: cs_lagr_particle.h:134
@ CS_LAGR_N_ATTRIBUTES
Definition: cs_lagr_particle.h:182
@ CS_LAGR_ADHESION_TORQUE
Definition: cs_lagr_particle.h:136
@ CS_LAGR_ANGULAR_VEL
Definition: cs_lagr_particle.h:119
@ CS_LAGR_VELOCITY_SEEN
Definition: cs_lagr_particle.h:98
@ CS_LAGR_STAT_CLASS
Definition: cs_lagr_particle.h:170
@ CS_LAGR_N_LARGE_ASPERITIES
Definition: cs_lagr_particle.h:133
@ CS_LAGR_P_FLAG
Definition: cs_lagr_particle.h:82
@ CS_LAGR_SHRINKING_DIAMETER
Definition: cs_lagr_particle.h:158
@ CS_LAGR_V_GAUSS
Definition: cs_lagr_particle.h:110
@ CS_LAGR_SHAPE
Definition: cs_lagr_particle.h:115
@ CS_LAGR_AGGLO_FRACTAL_DIM
Definition: cs_lagr_particle.h:174
@ CS_LAGR_YPLUS
Definition: cs_lagr_particle.h:125
@ CS_LAGR_WATER_MASS
Definition: cs_lagr_particle.h:154
@ CS_LAGR_CONSOL_HEIGHT
Definition: cs_lagr_particle.h:144
@ CS_LAGR_DIAMETER
Definition: cs_lagr_particle.h:94
@ CS_LAGR_COORDS
Definition: cs_lagr_particle.h:96
@ CS_LAGR_EULER
Definition: cs_lagr_particle.h:120
static cs_gnum_t cs_lagr_particle_get_gnum_n(const void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr)
Get attribute value of type cs_gnum_t of a given particle at a given time.
Definition: cs_lagr_particle.h:1191
static void cs_lagr_particles_set_flag(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int mask)
Set flag value with a selected mask for a given particle in a set.
Definition: cs_lagr_particle.h:539
static void * cs_lagr_particle_attr(void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr)
Get pointer to current attribute data of a particle.
Definition: cs_lagr_particle.h:975
static void cs_lagr_particles_set_real(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr, cs_real_t value)
Set attribute value of type cs_real_t of a given particle in a set.
Definition: cs_lagr_particle.h:849
static void cs_lagr_particles_unset_flag(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int mask)
Unset flag value with a selected mask for a given particle in a set.
Definition: cs_lagr_particle.h:566
static void cs_lagr_particle_set_lnum(void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr, cs_lnum_t value)
Set attribute value of type cs_lnum_t of a given particle.
Definition: cs_lagr_particle.h:1116
void cs_lagr_particle_set_dump(const cs_lagr_particle_set_t *particles)
Dump a cs_lagr_particle_set_t structure.
Definition: cs_lagr_particle.cpp:1323
static int cs_lagr_particles_get_flag(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int mask)
Get flag value with a selected mask for a given particle in a set.
Definition: cs_lagr_particle.h:516
void cs_lagr_particle_attr_initialize(void)
Define particle map based on defined options.
Definition: cs_lagr_particle.cpp:678
static void cs_lagr_particles_set_lnum_n(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr, cs_lnum_t value)
Set attribute value of type cs_lnum_t of a given particle in a set at a given time.
Definition: cs_lagr_particle.h:671
void cs_lagr_particles_current_to_previous(cs_lagr_particle_set_t *particles, cs_lnum_t particle_id)
Copy current attributes to previous attributes.
Definition: cs_lagr_particle.cpp:1295
static cs_gnum_t cs_lagr_particle_get_gnum(const void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr)
Get attribute value of type cs_gnum_t of a given particle in a set.
Definition: cs_lagr_particle.h:1166
static const void * cs_lagr_particles_attr_const(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
Get const pointer to current attribute data of a given particle in a set.
Definition: cs_lagr_particle.h:438
static void cs_lagr_particles_set_gnum(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr, cs_gnum_t value)
Set attribute value of type cs_gnum_t of a given particle in a set.
Definition: cs_lagr_particle.h:747
static const void * cs_lagr_particle_attr_const(const void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr)
Get const pointer to current attribute data of a particle.
Definition: cs_lagr_particle.h:997
cs_lagr_particle_set_t * cs_glob_lagr_particle_set
static const cs_real_t * cs_lagr_particle_source_term_const(void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr)
Get pointer to 2nd order scheme attribute source terms of a particle.
Definition: cs_lagr_particle.h:1386
static cs_lnum_t cs_lagr_particles_get_lnum_n(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
Get attribute value of type cs_lnum_t of a given particle in a set at a given time.
Definition: cs_lagr_particle.h:621
static cs_real_t cs_lagr_particles_get_real_n(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
Get attribute value of type cs_real_t of a given particle in a set at a given time.
Definition: cs_lagr_particle.h:825
static void * cs_lagr_particles_attr(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
Get pointer to a current attribute of a given particle in a set.
Definition: cs_lagr_particle.h:413
static void * cs_lagr_particle_attr_n(void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr)
Get pointer to attribute data of a particle at a given time.
Definition: cs_lagr_particle.h:1020
void cs_lagr_set_reallocation_factor(double f)
Set reallocation factor for particle sets.
Definition: cs_lagr_particle.cpp:1245
static cs_real_t cs_lagr_particle_get_real(const void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr)
Get attribute value of type cs_real_t of a given particle in a set.
Definition: cs_lagr_particle.h:1264
static cs_real_t * cs_lagr_particle_source_term(void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr)
Definition: cs_lagr_particle.h:1362
static const void * cs_lagr_particle_attr_n_const(const void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr)
Get const pointer to attribute data of a particle at a given time.
Definition: cs_lagr_particle.h:1044
static void cs_lagr_particle_set_real(void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr, cs_real_t value)
Set attribute value of type cs_real_t of a given particle.
Definition: cs_lagr_particle.h:1312
static cs_gnum_t cs_lagr_particles_get_gnum_n(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
Get attribute value of type cs_gnum_t of a given particle in a set at a given time.
Definition: cs_lagr_particle.h:723
static void cs_lagr_particles_set_real_n(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr, cs_real_t value)
Set attribute value of type cs_real_t of a given particle in a set at a given time.
Definition: cs_lagr_particle.h:875
static cs_gnum_t cs_lagr_particles_get_gnum(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
Definition: cs_lagr_particle.h:697
cs_lagr_particle_set_t * cs_lagr_get_particle_set(void)
Return pointer to the main cs_lagr_particle_set_t structure.
Definition: cs_lagr_particle.cpp:1194
static cs_lnum_t cs_lagr_particle_get_lnum_n(const void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr)
Get attribute value of type cs_lnum_t of a given particle at a given time.
Definition: cs_lagr_particle.h:1093
static void cs_lagr_particle_set_real_n(void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr, cs_real_t value)
Set attribute value of type cs_real_t of a given particle at a given time.
Definition: cs_lagr_particle.h:1337
static void * cs_lagr_particles_attr_n(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
Get pointer to attribute data of a given particle in a set at a given time.
Definition: cs_lagr_particle.h:464
static void cs_lagr_particles_set_gnum_n(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr, cs_gnum_t value)
Set attribute value of type cs_gnum_t of a given particle in a set at a given time.
Definition: cs_lagr_particle.h:773
static void cs_lagr_particles_set_lnum(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr, cs_lnum_t value)
Set attribute value of type cs_lnum_t of a given particle in a set.
Definition: cs_lagr_particle.h:645
static void cs_lagr_particles_attributes_fill_zero(cs_lagr_particle_set_t *p_set, cs_lnum_t p_id)
Definition: cs_lagr_particle.h:902
static cs_real_t * cs_lagr_particles_source_terms(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
Get pointer to 2nd order scheme source terms for an attribute of a given particle in a set.
Definition: cs_lagr_particle.h:924
void cs_lagr_set_n_user_variables(int n_user_variables)
Set number of user particle variables.
Definition: cs_lagr_particle.cpp:1351
static const cs_real_t * cs_lagr_particles_source_terms_const(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
Get const pointer to 2nd order scheme source terms an attribute of a given particle in a set.
Definition: cs_lagr_particle.h:950
void cs_lagr_particle_finalize(void)
Destroy main particle set and map if they exist.
Definition: cs_lagr_particle.cpp:1021
static const void * cs_lagr_particles_attr_n_const(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
Get const pointer to attribute data of a given particle in a set at a given time.
Definition: cs_lagr_particle.h:491
void cs_lagr_set_n_g_particles_max(unsigned long long n_g_particles_max)
Set global maximum number of particles.
Definition: cs_lagr_particle.cpp:1280
void cs_lagr_part_copy(cs_lnum_t dest, cs_lnum_t src)
Copy attributes from one particle to another.
Definition: cs_lagr_particle.cpp:1040
int cs_lagr_particle_set_resize(cs_lnum_t n_min_particles)
Resize particle set buffers if needed.
Definition: cs_lagr_particle.cpp:1214
void cs_lagr_particle_set_create(void)
Definition: cs_lagr_particle.cpp:1004
static void cs_lagr_particle_set_gnum_n(void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr, cs_gnum_t value)
Set attribute value of type cs_gnum_t of a given particle at a given time.
Definition: cs_lagr_particle.h:1239
int cs_lagr_check_attr_query(const cs_lagr_particle_set_t *particles, cs_lagr_attribute_t attr, cs_datatype_t datatype, int stride, int component_id)
Check that query for a given particle attribute is valid.
Definition: cs_lagr_particle.cpp:1112
static void cs_lagr_particle_set_lnum_n(void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr, cs_lnum_t value)
Set attribute value of type cs_lnum_t of a given particle at a given time.
Definition: cs_lagr_particle.h:1141
static cs_real_t cs_lagr_particle_get_real_n(const void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr)
Get attribute value of type cs_real_t of a given particle at a given time.
Definition: cs_lagr_particle.h:1289
static cs_lnum_t cs_lagr_particle_get_lnum(const void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr)
Get attribute value of type cs_lnum_t of a given particle in a set.
Definition: cs_lagr_particle.h:1068
void cs_lagr_get_attr_info(const cs_lagr_particle_set_t *particles, int time_id, cs_lagr_attribute_t attr, size_t *extents, size_t *size, ptrdiff_t *displ, cs_datatype_t *datatype, int *count)
Get data extents for a given particle attribute.
Definition: cs_lagr_particle.cpp:1075
static void cs_lagr_particle_set_gnum(void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr, cs_gnum_t value)
Set attribute value of type cs_gnum_t of a given particle.
Definition: cs_lagr_particle.h:1214
const char * cs_lagr_attribute_name[]
const cs_lagr_attribute_map_t * cs_lagr_particle_get_attr_map(void)
Return const pointer to the main particle attribute map structure.
Definition: cs_lagr_particle.cpp:991
static cs_real_t cs_lagr_particles_get_real(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
Definition: cs_lagr_particle.h:799
static cs_lnum_t cs_lagr_particles_get_lnum(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
Definition: cs_lagr_particle.h:595
Definition: cs_lagr_particle.h:189
ptrdiff_t(* displ)[CS_LAGR_N_ATTRIBUTES]
Definition: cs_lagr_particle.h:209
int(* count)[CS_LAGR_N_ATTRIBUTES]
Definition: cs_lagr_particle.h:206
size_t lb
Definition: cs_lagr_particle.h:193
ptrdiff_t * source_term_displ
Definition: cs_lagr_particle.h:213
int n_time_vals
Definition: cs_lagr_particle.h:197
size_t extents
Definition: cs_lagr_particle.h:191
Definition: cs_lagr_particle.h:223
cs_real_t weight_merged
Definition: cs_lagr_particle.h:237
cs_lnum_t n_part_merged
Definition: cs_lagr_particle.h:228
cs_real_t weight
Definition: cs_lagr_particle.h:234
cs_lnum_t n_particles
Definition: cs_lagr_particle.h:225
cs_lnum_t n_part_new
Definition: cs_lagr_particle.h:226
cs_real_t weight_out
Definition: cs_lagr_particle.h:236
cs_real_t weight_failed
Definition: cs_lagr_particle.h:241
cs_real_t weight_dep
Definition: cs_lagr_particle.h:238
unsigned char * p_buffer
Definition: cs_lagr_particle.h:247
cs_lnum_t n_failed_part
Definition: cs_lagr_particle.h:232
cs_real_t weight_fou
Definition: cs_lagr_particle.h:239
cs_lnum_t n_part_resusp
Definition: cs_lagr_particle.h:231
cs_real_t weight_new
Definition: cs_lagr_particle.h:235
cs_lnum_t n_part_out
Definition: cs_lagr_particle.h:227
const cs_lagr_attribute_map_t * p_am
Definition: cs_lagr_particle.h:245
cs_lnum_t n_part_fou
Definition: cs_lagr_particle.h:230
cs_lnum_t n_part_dep
Definition: cs_lagr_particle.h:229
cs_lnum_t n_particles_max
Definition: cs_lagr_particle.h:243
cs_real_t weight_resusp
Definition: cs_lagr_particle.h:240
