268 const char *var_name);
294 const char *var_name,
318 const char *var_name,
350 const char *chain_name,
351 const char *var_names[],
353 double lambda_vals[]);
Definition: cs_defs.h:542
Definition: cs_defs.h:342
Definition: cs_defs.h:543
Definition: cs_defs.h:335
unsigned short int cs_flag_t
Definition: cs_defs.h:344
@ lambda
Definition: cs_field_pointer.h:108
void cs_gwf_compute_steady_state(const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
Compute the steady-state of the groundwater flows module. Nothing is done if all equations are unstea...
Definition: cs_gwf.cpp:1424
cs_gwf_tracer_decay_chain_t * cs_gwf_add_decay_chain(int n_tracers, cs_gwf_tracer_unit_t unit, const char *chain_name, const char *var_names[], cs_gwf_tracer_model_t models[], double lambda_vals[])
Add a set of tracer equations corresponding to a radioactive decay chain in the groundwater flow modu...
Definition: cs_gwf.cpp:1018
cs_gwf_soil_t * cs_gwf_add_aniso_soil(const char *z_name, double density, double k_abs[3][3], double porosity, cs_gwf_soil_model_t model)
Create and add a new cs_gwf_soil_t structure. An initialization by default of all members is performe...
Definition: cs_gwf.cpp:774
cs_gwf_t * cs_gwf_activate(cs_gwf_model_type_t model, cs_flag_t option_flag, cs_flag_t post_flag)
Initialize the module dedicated to groundwater flows.
Definition: cs_gwf.cpp:239
void cs_gwf_extra_op(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_time_step_t *ts)
Predefined extra-operations for the groundwater flow module.
Definition: cs_gwf.cpp:1571
void cs_gwf_compute(const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
Compute the system related to groundwater flows module.
Definition: cs_gwf.cpp:1492
void cs_gwf_set_post_options(cs_flag_t post_flag, bool reset)
Set the flag dedicated to the post-processing of the GWF module.
Definition: cs_gwf.cpp:650
void cs_gwf_init_sharing(const cs_cdo_quantities_t *cdoq, const cs_cdo_connect_t *connect)
Definition: cs_gwf.cpp:1113
void cs_gwf_set_miscible_two_phase_model(cs_real_t l_mass_density, cs_real_t l_viscosity, cs_real_t g_viscosity, cs_real_t l_diffusivity_h, cs_real_t h_molar_mass, cs_real_t ref_temperature, cs_real_t henry_constant)
Set the parameters defining the two-phase flow model in the miscible case. Use SI unit if not prescri...
Definition: cs_gwf.cpp:542
void cs_gwf_extra_post(void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *time_step)
Predefined post-processing output for the groundwater flow module. According to the model,...
Definition: cs_gwf.cpp:1631
cs_gwf_tpf_t * cs_gwf_get_two_phase_model(void)
Get the main structure which manages a two-phase flow model.
Definition: cs_gwf.cpp:473
cs_gwf_soil_t * cs_gwf_add_iso_soil(const char *z_name, double density, double k_abs, double porosity, cs_gwf_soil_model_t model)
Definition: cs_gwf.cpp:721
cs_gwf_t * cs_gwf_destroy_all(void)
Free all structures related to groundwater flows.
Definition: cs_gwf.cpp:303
void cs_gwf_finalize_setup(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
Last initialization step of the groundwater flow module. At this stage, the mesh quantities are defin...
Definition: cs_gwf.cpp:1255
void cs_gwf_hydraulic_update(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts, cs_flag_t update_flag)
Update the groundwater system related to the hydraulic model: pressure head, head in law,...
Definition: cs_gwf.cpp:1318
cs_gwf_tracer_t * cs_gwf_add_user_tracer(const char *eq_name, const char *var_name, cs_gwf_tracer_init_setup_t *init_setup, cs_gwf_tracer_finalize_setup_t *finalize_setup)
Add a new equation related to the groundwater flow module.
Definition: cs_gwf.cpp:962
void cs_gwf_init_values(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts)
Initialize the GWF module (done after all the setup phase and after the initialization of all equatio...
Definition: cs_gwf.cpp:1374
cs_adv_field_t * cs_gwf_get_adv_field(void)
Retrieve the advection field related to the Darcy flux in the liquid phase.
Definition: cs_gwf.cpp:694
void cs_gwf_set_two_phase_numerical_options(cs_gwf_tpf_approx_type_t approx, cs_gwf_tpf_solver_type_t solver, bool pg_pos)
Set the numerical options related to the two phase flow models.
Definition: cs_gwf.cpp:503
cs_gwf_tracer_t * cs_gwf_add_tracer(cs_gwf_tracer_model_t tr_model, const char *eq_name, const char *var_name)
Definition: cs_gwf.cpp:830
void cs_gwf_log_setup(void)
Summary of the main cs_gwf_t structure.
Definition: cs_gwf.cpp:358
void cs_gwf_init_model_context(void)
Initialize the context of the model after the activation of the module and make first settings of the...
Definition: cs_gwf.cpp:1131
cs_gwf_tracer_t * cs_gwf_add_radioactive_tracer(cs_gwf_tracer_model_t tr_model, const char *eq_name, const char *var_name, double lambda)
Definition: cs_gwf.cpp:897
bool cs_gwf_is_activated(void)
Check if the groundwater flow module has been activated.
Definition: cs_gwf.cpp:218
void cs_gwf_init_setup(void)
Predefined settings for the groundwater flow model and its related equations.
Definition: cs_gwf.cpp:1199
void cs_gwf_set_immiscible_two_phase_model(cs_real_t l_mass_density, cs_real_t l_viscosity, cs_real_t g_viscosity, cs_real_t h_molar_mass, cs_real_t ref_temperature)
Set the parameters defining the immiscible two-phase flow model. Use SI unit if not prescribed otherw...
Definition: cs_gwf.cpp:599
Type of approximation used for the computation of unsteady or diffusion properties.
Definition: cs_gwf_hydraulic_model.h:270
Type of solver considered for a two-phase flow model.
Definition: cs_gwf_hydraulic_model.h:255
Flags specifying the general behavior of a tracer associated to the groundwater flow module.
Definition: cs_gwf_param.h:297
cs_gwf_model_type_t
Definition: cs_gwf_param.h:127
cs_gwf_soil_model_t
Predefined hydraulic model of soils used in the groundwater flow module.
Definition: cs_gwf_param.h:280
Type of unit for the expression of the radioactive inventory.
Definition: cs_gwf_param.h:111
void() cs_gwf_tracer_init_setup_t(cs_gwf_tracer_t *tracer)
Generic function to update the first setup stage (the one done before building mesh and its related q...
Definition: cs_gwf_tracer.h:77
void() cs_gwf_tracer_finalize_setup_t(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_adv_field_t *adv, cs_gwf_tracer_t *tracer)
Generic function to finalize the setup of parameters related to a tracer equation....
Definition: cs_gwf_tracer.h:93
double precision, dimension(:,:,:), allocatable density
Definition: atimbr.f90:123
Definition: cs_advection_field.h:151
Definition: cs_cdo_quantities.h:139
Main set of parameters/structures to manage the groundwater flow (GWF) module. This is an explicit de...
Definition: cs_gwf_hydraulic_model.h:622
Structure to handle the modelling of miscible or immiscible two-phase flows in a porous media.
Definition: cs_gwf_hydraulic_model.h:310
Definition: cs_gwf_tracer.h:162
Set of parameters describing a tracer structure.
time step descriptor
Definition: cs_time_step.h:64
