#include "cs_coal.h"
#include "cs_zone.h"
◆ cs_coal_bc_inlet_state_t
◆ cs_coal_boundary_conditions()
| void cs_coal_boundary_conditions |
int |
bc_type[] | ) |
Automatic boundary condition for pulverized coal combution.
- Parameters
| [in] | bc_type | type of boundary for each face |
◆ cs_coal_boundary_conditions_get_inlet()
Return pointer to coal boundary conditions inlet structure.
If no such structure was previously present, it is created and linked to the matching open boundary condition inlet.
- Parameters
| [in] | zone | pointer to associated zone |
- Returns
- : pointer to structure associated with zone
◆ cs_coal_boundary_conditions_inlet_density()
| void cs_coal_boundary_conditions_inlet_density |
void |
Compute density at inlets for pulverized coal combustion.
This is based on boundary condition definitions, but is called at an earlier stage in the time step.
◆ cs_coal_boundary_conditions_inlet_set_air_mass_flow_rate_by_func()
◆ cs_coal_boundary_conditions_inlet_set_air_mass_flow_rate_by_value()
| void cs_coal_boundary_conditions_inlet_set_air_mass_flow_rate_by_value |
const cs_zone_t * |
z, |
cs_real_t |
q |
Assign a constant air mass flow rate to an inlet.
The total mass flow rate will also include that of the pulverized coals.
This is otherwise similar to cs_boundary_conditions_open_set_mass_flow_rate_by_value.
- Parameters
| [in] | z | pointer to associated zone |
| [in] | q | associated constant mass flow rate |
