50#define CS_COMBUSTION_MAX_COALS 5
53#define CS_COMBUSTION_COAL_MAX_OXYDANTS 3
56#define CS_COMBUSTION_COAL_MAX_GLOBAL_SPECIES 25
59#define CS_COMBUSTION_COAL_MAX_ATOMIC_SPECIES 5
62#define CS_COMBUSTION_MAX_CLASSES_PER_COAL 20
65#define CS_COMBUSTION_COAL_MAX_CLASSES CS_COMBUSTION_MAX_COALS \
66 * CS_COMBUSTION_MAX_CLASSES_PER_COAL
69#define CS_COMBUSTION_COAL_MAX_ELEMENTARY_COMPONENTS 20
72#define CS_COMBUSTION_COAL_MAX_TABULATION_POINTS 8
75#define CS_COMBUSTION_COAL_MAX_SOLIDS CS_COMBUSTION_MAX_COALS * 4
const double cs_coal_prefth
Definition: cs_coal.cpp:105
const double cs_coal_trefth
Definition: cs_coal.cpp:102
Definition: cs_coal.h:75
void cs_coal_mass_transfer(void)
cs_coal_model_type_t
Definition: cs_coal.h:84
@ CS_COMBUSTION_COAL_NONE
Definition: cs_coal.h:86
@ CS_COMBUSTION_COAL_STANDARD
Definition: cs_coal.h:88
@ CS_COMBUSTION_COAL_WITH_DRYING
Definition: cs_coal.h:89
cs_coal_model_type_t cs_coal_model_get_type(void)
Return coal combustion model type.
Definition: cs_coal.cpp:876
const int cs_coal_atom_id_s
Definition: cs_coal.cpp:116
const double cs_coal_volmol
Definition: cs_coal.cpp:109
void cs_coal_setup(void)
Specific setup operations for pulverized coal combustion model.
Definition: cs_coal.cpp:1029
Definition: cs_coal.h:65
const int cs_coal_atom_id_h
Definition: cs_coal.cpp:113
Definition: cs_coal.h:59
Definition: cs_coal.h:72
cs_coal_model_t * cs_glob_coal_model
Definition: cs_coal.cpp:96
Definition: cs_coal.h:53
const int cs_coal_atom_id_o
Definition: cs_coal.cpp:114
void cs_coal_rad_transfer_st(const cs_field_t *f, cs_real_t *smbrs, cs_real_t *rovsdt)
Take in account the radiative source terms in the particle equation of a given class for pulverized c...
Definition: cs_coal.cpp:1145
const int cs_coal_atom_id_c
Definition: cs_coal.cpp:112
Definition: cs_coal.h:50
const int cs_coal_atom_id_n
Definition: cs_coal.cpp:115
cs_coal_model_t * cs_coal_model_set_model(cs_coal_model_type_t type)
Activate coal combustion model.
Definition: cs_coal.cpp:895
Definition: cs_coal.h:56
Definition: cs_coal.h:69
const double cs_coal_epsilon
Definition: cs_coal.cpp:119
Definition: cs_defs.h:542
Definition: cs_defs.h:342
Definition: cs_defs.h:543
int icnorb
Definition: cs_coal.h:683
int ifnh3d
Definition: cs_coal.h:674
int ifnoth
Definition: cs_coal.h:679
int icnonh
Definition: cs_coal.h:682
int ifnh3c
Definition: cs_coal.h:675
int ifhcnr
Definition: cs_coal.h:680
int ighcn2
Definition: cs_coal.h:667
int ignh32
Definition: cs_coal.h:670
int ignh31
Definition: cs_coal.h:669
int ifhcnd
Definition: cs_coal.h:672
int ifhcnc
Definition: cs_coal.h:673
int ifnohc
Definition: cs_coal.h:676
int ignoth
Definition: cs_coal.h:668
int ifnoch
Definition: cs_coal.h:678
int ifnonh
Definition: cs_coal.h:677
int ighcn1
Definition: cs_coal.h:666
int icnohc
Definition: cs_coal.h:681
int immel
Definition: cs_coal.h:606
int igrb
Definition: cs_coal.h:608
int irom1
Definition: cs_coal.h:605
int ibcarbone
Definition: cs_coal.h:654
int iboxygen
Definition: cs_coal.h:655
int ibhydrogen
Definition: cs_coal.h:656
int if8m
Definition: cs_coal.h:554
int if5m
Definition: cs_coal.h:550
int iynh3
Definition: cs_coal.h:537
int iyhcn
Definition: cs_coal.h:536
int ihox
Definition: cs_coal.h:540
int if6m
Definition: cs_coal.h:551
int iyco2
Definition: cs_coal.h:535
int if7m
Definition: cs_coal.h:552
int if4m
Definition: cs_coal.h:549
int ihgas
Definition: cs_coal.h:533
int if9m
Definition: cs_coal.h:556
int iyno
Definition: cs_coal.h:538
int ifvp2m
Definition: cs_coal.h:559
real(c_double), dimension(:), pointer, save th
temperature (in K)
Definition: ppthch.f90:119
real(c_double), dimension(:), pointer, save wmolat
molar mass of atoms
Definition: ppthch.f90:136
real(c_double), dimension(:), pointer, save wmole
molar mass of an elementary gas component
Definition: ppthch.f90:130
real(c_double), dimension(:), pointer, save hch
Definition: cpincl.f90:69
real(c_double), dimension(:,:), pointer, save crepn1
real(c_double), dimension(:), pointer, save xashch
real(c_double), dimension(:), pointer, save a1ch
Definition: cpincl.f90:79
real(c_double), dimension(:), pointer, save eh0sol
Definition: cpincl.f90:91
integer(c_int), dimension(:), pointer, save igmdv2
Definition: cpincl.f90:152
real(c_double), dimension(:), pointer, save nch
real(c_double), dimension(:), pointer, save wmols
real(c_double), dimension(:), pointer, save diam20
Definition: cpincl.f90:99
real(c_double), dimension(:), pointer, save ehetwt
real(c_double), dimension(:), pointer, save d1
Definition: cpincl.f90:109
real(c_double), dimension(:), pointer, save thcdch
real(c_double), dimension(:), pointer, save f1
real(c_double), dimension(:), pointer, save rho20
real(c_double), dimension(:), pointer, save e1
integer(c_int), dimension(:), pointer, save ixck
Definition: cpincl.f90:128
real(c_double), dimension(:), pointer, save ock
real(c_double), dimension(:), pointer, save ahetch
integer(c_int), dimension(:), pointer, save ighco2
Definition: cpincl.f90:150
real(c_double), dimension(:), pointer, save ehetch
real(c_double), dimension(:), pointer, save ehetc2
real(c_double), dimension(:), pointer, save cch
real(c_double), dimension(:), pointer, save e2ch
integer(c_int), dimension(:), pointer, save igmhet
Definition: cpincl.f90:148
real(c_double), dimension(:), pointer, save f2
real(c_double), dimension(:,:), pointer, save crepn2
integer(c_int), dimension(:), pointer, save iy2ch
Definition: cpincl.f90:77
real(c_double), dimension(:), pointer, save rho2mn
real(c_double), dimension(:), pointer, save c1
integer(c_int), dimension(:), pointer, save iash
Definition: cpincl.f90:90
integer(c_int), dimension(:), pointer, save ioetwt
Definition: cpincl.f90:78
integer(c_int), dimension(:), pointer, save iochet
real(c_double), dimension(:), pointer, save af7
Definition: cpincl.f90:174
real(c_double), dimension(:), pointer, save af6
Definition: cpincl.f90:173
real(c_double), dimension(:), pointer, save ahetwt
integer(c_int), dimension(:), pointer, save igmdv1
Definition: cpincl.f90:151
real(c_double), dimension(:), pointer, save e1ch
real(c_double), dimension(:), pointer, save af8
real(c_double), dimension(:), pointer, save a2ch
real(c_double), dimension(:), pointer, save b2
integer(c_int), dimension(:), pointer, save ix2
Definition: cpincl.f90:146
real(c_double), dimension(:), pointer, save dia2mn
real(c_double), dimension(:), pointer, save af3
real(c_double), dimension(:), pointer, save h02ch
integer(c_int), dimension(:), pointer, save iwat
integer(c_int), dimension(:), pointer, save igmsec
Definition: cpincl.f90:153
real(c_double), dimension(:), pointer, save af4
integer(c_int), dimension(:), pointer, save ixwt
Definition: cpincl.f90:132
integer(c_int), dimension(:), pointer, save idiam2
Definition: cpincl.f90:145
real(c_double), dimension(:), pointer, save c2
real(c_double), dimension(:), pointer, save ahetc2
real(c_double), dimension(:), pointer, save d2
integer(c_int), dimension(:), pointer, save ih2
Definition: cpincl.f90:131
integer(c_int), dimension(:), pointer, save ixch
Definition: cpincl.f90:129
real(c_double), dimension(:), pointer, save xmp0
real(c_double), dimension(:), pointer, save pcick
real(c_double), dimension(:), pointer, save sch
real(c_double), dimension(:), pointer, save cp2ch
real(c_double), dimension(:), pointer, save af9
real(c_double), dimension(:), pointer, save xwatch
integer(c_int), dimension(:), pointer, save itemp2
Definition: cpincl.f90:143
real(c_double), dimension(:), pointer, save nck
integer(c_int), dimension(:), pointer, save irom2
Definition: cpincl.f90:144
real(c_double), dimension(:), pointer, save hck
real(c_double), dimension(:), pointer, save chx1
integer(c_int), dimension(:), pointer, save ick
integer(c_int), dimension(:), pointer, save ichcor
Definition: cpincl.f90:98
integer(c_int), dimension(:), pointer, save if1m
Definition: cpincl.f90:119
real(c_double), dimension(:), pointer, save chx2
integer(c_int), dimension(:), pointer, save ichx2c
Definition: cpincl.f90:107
real(c_double), dimension(:), pointer, save xashsec
real(c_double), dimension(:), pointer, save cck
real(c_double), dimension(:), pointer, save pcich
real(c_double), dimension(:), pointer, save af5
real(c_double), dimension(:), pointer, save rho0ch
real(c_double), dimension(:,:), pointer, save ehgaze
engaze(ij) is the massic enthalpy (J/kg) of the i-th elementary gas component at temperature th[j]
Definition: cpincl.f90:162
integer(c_int), dimension(:), pointer, save igmtr
Definition: cpincl.f90:149
integer(c_int), dimension(:), pointer, save ioetc2
real(c_double), dimension(:), pointer, save sck
integer(c_int), dimension(:), pointer, save if2m
Definition: cpincl.f90:120
integer(c_int), dimension(:), pointer, save inp
Definition: cpincl.f90:130
real(c_double), dimension(:), pointer, save xmash
real(c_double), dimension(:), pointer, save cpashc
real(c_double), dimension(:), pointer, save och
real(c_double), dimension(:), pointer, save y2ch
integer(c_int), dimension(:), pointer, save iym1
Definition: cpincl.f90:137
integer(c_int), dimension(:), pointer, save iy1ch
real(c_double), dimension(:,:), pointer, save ehsoli
real(c_double), dimension(:), pointer, save h0ashc
integer(c_int), dimension(:), pointer, save ichx1c
real(c_double), dimension(:), pointer, save rhock
integer(c_int), dimension(:), pointer, save igmdch
Definition: cpincl.f90:147
real(c_double), dimension(:), pointer, save y1ch
real(c_double), dimension(:), pointer, save b1
real(c_double), dimension(:), pointer, save ynoch2
Definition: cs_coal_incl.f90:49
integer(c_int), dimension(:), pointer, save ipci
Definition: cs_coal_incl.f90:38
real(c_double), dimension(:), pointer, save repnlo
Definition: cs_coal_incl.f90:46
integer(c_int), dimension(:), pointer, save ighh2o
real(c_double), dimension(:), pointer, save yhcnle
Definition: cs_coal_incl.f90:47
real(c_double), dimension(:), pointer, save qpr
Definition: cs_coal_incl.f90:42
real(c_double), dimension(:), pointer, save yhcnc1
Definition: cs_coal_incl.f90:48
real(c_double), dimension(:), pointer, save ynh3lo
real(c_double), dimension(:), pointer, save fn
real(c_double), dimension(:), pointer, save ynh3le
real(c_double), dimension(:), pointer, save yhcnc2
real(c_double), dimension(:), pointer, save repnck
real(c_double), dimension(:), pointer, save ynoch1
real(c_double), dimension(:), pointer, save yhcnlo
real(c_double), dimension(:), pointer, save repnle
real(c_double), dimension(:), pointer, save oxyco2
Definition: ppcpfu.f90:41
real(c_double), dimension(:), pointer, save oxyn2
real(c_double), dimension(:), pointer, save oxyo2
real(c_double), dimension(:), pointer, save oxyh2o
int imdnox
Definition: cs_coal.h:168
int n_gas_el_comp
Definition: cs_coal.h:103
int ico2
Definition: cs_coal.h:385
int ichx1
Definition: cs_coal.h:394
int iso2
Definition: cs_coal.h:445
int in2
Definition: cs_coal.h:384
int ih2o
Definition: cs_coal.h:383
int ichx2
Definition: cs_coal.h:397
int ih2s
Definition: cs_coal.h:444
int nsolid
Definition: cs_coal.h:151
int ihcn
Definition: cs_coal.h:446
double wmchx2
Definition: cs_coal.h:519
double pcigas
Definition: cs_coal.h:112
int n_reactions
Definition: cs_coal.h:107
double ckabs0
Definition: cs_coal.h:189
int n_tab_points
Definition: cs_coal.h:110
int ieqco2
Definition: cs_coal.h:158
int inh3
Definition: cs_coal.h:447
int nclacp
Definition: cs_coal.h:149
int ihtco2
Definition: cs_coal.h:164
int ihy
Definition: cs_coal.h:443
int ieqnox
Definition: cs_coal.h:166
int n_atomic_species
Definition: cs_coal.h:105
Definition: cs_coal.h:146
int idrift
Definition: cs_coal.h:156
int n_gas_species
Definition: cs_coal.h:104
int n_coals
Definition: cs_coal.h:148
int io2
Definition: cs_coal.h:382
int irb
Definition: cs_coal.h:184
double wmchx1
Definition: cs_coal.h:516
double xco2
Definition: cs_coal.h:114
double srrom
Definition: cs_coal.h:690
int npoc
Definition: cs_coal.h:456
double xh2o
Definition: cs_coal.h:115
int ihth2o
Definition: cs_coal.h:462
int noxyd
Definition: cs_coal.h:154
int ico
Definition: cs_coal.h:381
Definition: cs_field.h:131
