#include "cs_defs.h"#include <assert.h>#include <math.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft_error.h"#include "cs_atmo.h"#include "cs_atmo_aerosol.h"#include "cs_atmo_profile_std.h"#include "cs_air_props.h"#include "cs_field_default.h"#include "cs_field_pointer.h"#include "cs_field_operator.h"#include "cs_intprf.h"#include "cs_physical_constants.h"#include "cs_physical_model.h"#include "cs_physical_properties.h"#include "cs_post.h"#include "cs_prototypes.h"#include "cs_thermal_model.h"#include "cs_turbulence_model.h"#include "cs_velocity_pressure.h"#include "cs_atmo_variables.h"
Include dependency graph for cs_atmo_variables.cpp:Functions | |
| void | cs_atmo_add_variable_fields (void) |
| void | cs_atmo_add_property_fields (void) |
| Add if needed the variables fields. More... | |
| void | cs_atmo_physical_properties_update (void) |
| Update the thermo physical properties fields for the humid air and the liquid Remarques : This function is called at the beginning of each time step. More... | |
Add atmospheric model fields.
| void cs_atmo_add_property_fields | ( | void | ) |
| void cs_atmo_add_variable_fields | ( | void | ) |
Add atmospheric variables fields
| void cs_atmo_physical_properties_update | ( | void | ) |
