8.3
atimbr.f90 File Reference
Atmospheric Imbrication module. This module contains the data structure and subroutines to perform atmospheric imbrication or nesting of a CFD domain within a large scale meteorological field. Starting from a set of large scale meteological profiles (in the format of meteo files) an interpolation is performed for each boundary face both spatially and temporally (using Cressman method) More...
Data Types
interface  cs_f_atmo_get_pointers_imbrication
Modules
module  atimbr
Functions/Subroutines
subroutine atmo_init_imbrication ()
 Map Fortran to C variables. More...
subroutine allocate_all ()
 Allocate variables adapted to the number of files and time step to be considered. More...
subroutine finalize_imbrication ()
 Final step for deallocation. More...
subroutine interpolate_all_profiles (the_time)
 Time interpolation of all profiles -. More...
subroutine dump_interpolated_profiles
 Print the interpolated profiles for checking purposes. More...
integer function yo2j (year, ordinal)
 Converts a (year,ordinal) date to julian calendar date for calculating time shifts. More...
subroutine read_files_list (a_file, the_list)
 Reads a file having in each significative line a file name it returns then as 'the_list' the list of lines read a line is significative if it's first char is not / or # or ! The following 3 lines give an example from which one must remove the first two characters. More...
subroutine find_next_line (unilog, current_line, meteo_file, l_iostat)
 Find next validated line. More...
subroutine read_meteo_file (meteo_file)
 Reads a meteo_file for code_saturne Atmospheric Physics option. More...
subroutine check_chronologies
 Checks the time variables to ensure the chronology. More...
subroutine check_positions
 Check that the profiles position is the same over time. More...
subroutine check_altitudes
 Check that the profiles vertical grids heights are strictly increasing. More...
subroutine hydrostatic_pressure
 Compute the hydrostastic pressure by Laplace integration. More...
subroutine potential_temperature_and_density
 Computes the potential_temperature_and_density profiles. More...
subroutine get_index (the_array, the_value, lower, upper)
 Search for the position of a value in an array, assuming that the array is sorted in a strictly increasing order. More...
subroutine time_interpolation (the_time, the_times, the_profiles, interpolated_profile)
 Interpolates a "profile" at a given time. Given a series of profiles varying in time you get the profile interpolated from them at the given time. More...
subroutine altitude_interpolation (the_altitude, the_altitudes, the_profile, interpolated_value)
 interpolates in a profile at a given altitude More...
subroutine red_tape
 Compute radius of influence. More...
subroutine bounds (string, length, b, e)
 Identification of the first and last non white character of a string. More...
subroutine activate_imbrication
 Prepare data for imbrication by reading meteo files. More...
subroutine summon_cressman (the_time)
 Prepare for the cressman interpolation of the variables. More...
logical(c_bool), pointer imbrication_flag
 activation flag More...
logical(c_bool), pointer, save imbrication_verbose
logical(c_bool), pointer cressman_u
 Flags for activating the cressman interpolation for the boundary conditions. More...
logical(c_bool), pointer cressman_v
logical(c_bool), pointer cressman_tke
logical(c_bool), pointer cressman_eps
logical(c_bool), pointer cressman_theta
logical(c_bool), pointer cressman_qw
logical(c_bool), pointer cressman_nc
real(c_double), pointer vertical_influence_radius
 numerical parameters for the cressman interpolation formulas More...
real(c_double), pointer horizontal_influence_radius
integer line_len
 Parameter for "meteo" files. More...
character(line_len) imbrication_files_list
character(line_len), dimension(:), allocatable imbrication_files
integer number_of_files
character *(3) skip_chars
integer thermal_profile_dim
 Profile dimension variable. More...
integer dynamical_profile_dim
integer sections_per_file
 Time sections per files. More...
integer, dimension(:,:), allocatable years
 read data from "meteo" files More...
integer, dimension(:,:), allocatable ordinals
integer, dimension(:,:), allocatable hours
integer, dimension(:,:), allocatable minutes
double precision, dimension(:,:), allocatable seconds
double precision, dimension(:,:), allocatable xpos
 Positions. More...
double precision, dimension(:,:), allocatable ypos
double precision, dimension(:,:), allocatable ground_pressure
double precision, dimension(:,:,:), allocatable zt
 Vertical grid for temperature and humidity variables. More...
double precision, dimension(:,:,:), allocatable tempc
double precision, dimension(:,:,:), allocatable qw
double precision, dimension(:,:,:), allocatable nc
double precision, dimension(:,:,:), allocatable zd
 Vertical grid for wind variables. More...
double precision, dimension(:,:,:), allocatable u
double precision, dimension(:,:,:), allocatable v
double precision, dimension(:,:,:), allocatable tke
double precision, dimension(:,:,:), allocatable eps
double precision, dimension(:,:), allocatable, target times
 derived data More...
double precision, dimension(:,:,:), allocatable pressure
double precision, dimension(:,:,:), allocatable theta
double precision, dimension(:,:,:), allocatable density
double precision, dimension(:,:), allocatable ti_zt
 time interpolated profiles More...
double precision, dimension(:,:), allocatable ti_tempc
double precision, dimension(:,:), allocatable ti_qw
double precision, dimension(:,:), allocatable ti_nc
double precision, dimension(:,:), allocatable ti_zd
double precision, dimension(:,:), allocatable ti_u
double precision, dimension(:,:), allocatable ti_v
double precision, dimension(:,:), allocatable ti_tke
double precision, dimension(:,:), allocatable ti_eps
double precision, dimension(:,:), allocatable ti_pressure
double precision, dimension(:,:), allocatable ti_theta
double precision, dimension(:,:), allocatable ti_density
double precision, dimension(:,:,:), allocatable coordinates_th
 additional variables More...
double precision, dimension(:,:,:), allocatable influence_param_th
double precision, dimension(:,:,:), allocatable coordinates_dyn
double precision, dimension(:,:,:), allocatable influence_param_dyn
integer(c_int), pointer id_u
integer(c_int), pointer id_v
integer(c_int), pointer id_qw
integer(c_int), pointer id_nc
integer(c_int), pointer id_tke
integer(c_int), pointer id_eps
integer(c_int), pointer id_theta
double precision, dimension(:), pointer times_sequence =>null()
 1D array of times at which profiles are given More...
This imbrication reads additional meteo files.
