8.2
cs_equation_system_param_t Struct Reference
Main structure storing the parameter settings. More...
#include <cs_equation_system_param.h>
+ Collaboration diagram for cs_equation_system_param_t:
Data Fields
Generic metadata
char *restrict name
int verbosity
cs_param_space_scheme_t space_scheme
int block_var_dim
Linear algebra (SLES)
cs_equation_system_sles_strategy_t sles_strategy
cs_param_sles_tsles_param
Field Documentation
◆ block_var_dim
block_var_dim
Dimension of the variable in each block
◆ name
name
Name of the system of equations
◆ sles_param
sles_param
Set of parameters to control the (main) linear solver
◆ sles_strategy
sles_strategy
Type of strategy used to solve the resulting system
◆ space_scheme
space_scheme
Associated space discretization. One assumes that all blocks share the same space discretization.
◆ verbosity
verbosity
Level of verbosity (quantity of output information)
