1 #ifndef __CS_EQUATION_SYSTEM_PARAM_H__
2 #define __CS_EQUATION_SYSTEM_PARAM_H__
#define restrict
Definition: cs_defs.h:141
Definition: cs_defs.h:528
Definition: cs_defs.h:529
cs_equation_system_param_t * cs_equation_system_param_create(const char *name, int block_var_dim)
Create and initialize a new cs_equation_system_param_t structure.
Definition: cs_equation_system_param.c:91
cs_equation_system_key_t
List of available keys for setting the parameters of a system of equations.
Definition: cs_equation_system_param.h:148
@ CS_SYSKEY_LINEAR_SOLVER_ATOL
Definition: cs_equation_system_param.h:150
@ CS_SYSKEY_N_KEYS
Definition: cs_equation_system_param.h:157
@ CS_SYSKEY_LINEAR_SOLVER_DTOL
Definition: cs_equation_system_param.h:151
@ CS_SYSKEY_LINEAR_SOLVER_RTOL
Definition: cs_equation_system_param.h:152
@ CS_SYSKEY_SLES_STRATEGY
Definition: cs_equation_system_param.h:154
@ CS_SYSKEY_LINEAR_SOLVER_MAX_ITER
Definition: cs_equation_system_param.h:153
@ CS_SYSKEY_VERBOSITY
Definition: cs_equation_system_param.h:155
cs_equation_system_sles_strategy_t
High-level information about the way of solving the system of equations.
Definition: cs_equation_system_param.h:60
@ CS_EQUATION_SYSTEM_N_SLES_TYPES
Definition: cs_equation_system_param.h:64
@ CS_EQUATION_SYSTEM_SLES_MUMPS
Definition: cs_equation_system_param.h:62
void cs_equation_system_param_set(cs_equation_system_param_t *sysp, cs_equation_system_key_t key, const char *keyval)
Set a parameter related to a keyname in a cs_equation_system_param_t structure.
Definition: cs_equation_system_param.c:240
void cs_equation_system_param_log(const cs_equation_system_param_t *sysp)
Log the setup gathered in the structure cs_equation_system_param_t.
Definition: cs_equation_system_param.c:197
cs_equation_system_param_t * cs_equation_system_param_free(cs_equation_system_param_t *sysp)
Free a cs_equation_system_param_t structure.
Definition: cs_equation_system_param.c:174
Structure and routines handling the SLES ((Sparse Linear Equation Solver) settings stored inside a cs...
cs_param_space_scheme_t
Definition: cs_param_types.h:211
Main structure storing the parameter settings.
Definition: cs_equation_system_param.h:72
cs_param_sles_t * sles_param
Definition: cs_equation_system_param.h:113
int block_var_dim
Definition: cs_equation_system_param.h:98
cs_equation_system_sles_strategy_t sles_strategy
Definition: cs_equation_system_param.h:112
int verbosity
Definition: cs_equation_system_param.h:94
char *restrict name
Definition: cs_equation_system_param.h:92
cs_param_space_scheme_t space_scheme
Definition: cs_equation_system_param.h:96
Definition: cs_param_sles.h:64
